Question about Vizio VP322 32 in. Plasma TV
Faint transparent horizontal lines on screen of Vizio 32" Plasma HDTV VP32. There are 5-6 lines which each kind of look like 2-3 smaller lines stacked on top of eachother. They are spaced 4-5 inches apart and are only present when I'm using the component cables to play Xbox 360 or watch my Comast cable in HD. Again, these lines are really faint, and are only noticeable when the picture being displayed is one solid color (most prominently when the screen is all black). I believe the problem arose after I had to take the back off of the television because a peg of my component cable broke off inside the the red (component) socket/plug. I had to remove the peg that had been pushed all the way through after I tried to pull it out. When I inspected the inside of the television, I noticed the small strip of metal that was supposed to be in the inside end of the red (componant) socket/plug had been bent outwards, so i pushed it back in and screwed the back of the television back on. I plugged my cable back in with a new set of cables and everything seemed fine until I noticed the lines about a week later.
SOURCE: Discolored lines within picture 32 inch LCD TV
I have the same tv, if you turn up the brightness and turn down the contrast that should help a little bit.... Hope this helps
Posted on Sep 01, 2008
dsacco86
  • 1077 Answers
SOURCE: 50" Vizio Plasma reads "No Signal" on all inputs?
Well, your TV is still under warranty. That's the good part.
The only thing I can recommend without voiding the warranty is leaving the TV unplugged for 30min. That way, the TV can reset itself and hopefully correct the problem.
If that doesn't solve the problem, it's time to use the VIZIO warranty.
Here's contact info if you need it.
Technical Support
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
techsupport@vizio.com
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Posted on Jun 17, 2009
maatmartin7
  • 1229 Answers
SOURCE: CUSTOMER WITH A BRAND NEW VIZIO VA 320M KEEPS SHOWING SIDEBARS
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
Posted on Aug 12, 2009
SOURCE: 2/3 Inch Faint Horizontal Bar through center of screen
A little WARNING!! .. don't open the TV because if you do that the warranty is gone.
Whenever you see a black horizontal bar on the flat panel screen TV, it usually means that the buffers in one of the Horizontal COF chips is dead, not soldered properly or got damaged mechanically during transport or something like that. COF chips are microchips made on the flat cable that are connected from the board to the LCD panel screen, and they lit up certain sectors of the screen. Every X buffer lits up pixels from specific locations in combination with Y buffers, depending on type of panel used in a device. and when one of the Y buffers die ... then the pixels receive only X buffers information and not Y and then the black bar appears with some weird noise dots on the edges or something like that. It is repairable, what you need is an SMD repair (rework) soldering station and an identical Buffer COF chip. Unfortunately this is not a quick fix if you don't have the appropriate equipment, so I would suggest using that extended warranty and get your TV serviced properly by the LCD repair man :)
http://www.epartshub.com/upload/cmpy/00000166/Img/00000166-COF.jpg
...this is the COF chip.
http://www.hotsolder.com/uploaded_images/iron-726250.jpg
... this is the hot air SMD soldering station
depending on the COF chip type, some of the chips are soldered and some are just connected through the flat connectors without soldering.
A little WARNING!! again .. don't open the TV because if you do that the warranty is gone.
Posted on May 11, 2010
budmrtn
  • 11361 Answers
SOURCE: My Vizio 32 model vw32L
Here are the boards for your TV:
http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VW32L
The damages can b extensive when lighting strikes, it can take out the power supply module and the main board.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jul 11, 2011
Random faint horizontal lines scrolling down screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 25, 2017 | LG 50PS60 50 in. Plasma HDTV
Horizontal pink line scrolling up screen
Isolate the ground from the power connection. Use a 3 prong to 2 prong adapter. See if this helps you. Often this is caused by noisy ground connections. I hope this was of some assistance.
Mar 23, 2010 | Vizio L32 32 in. LCD HDTV
We also have a Vizio with red horizontal lines and our TV is new
It's possible that the motherboard or the controller board for the screen is defective. At this point, I would use the warranty from Vizio. It should be no doubt that it covered. Here's the info you will need from the Vizio web site.
http://www.vizio.com/support.aspx?id=1588
Jun 13, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
I have red lines up/down on my Vizio, how can I correct this?
Your sympton need to be more specific, but if what you see is 1 or more tiny lines running from top to bottom of screen (verticaly) and those lines change colors (red/green) depending on the background color on the screen, then your control board need to be replaced, you will need your TV model and product code, both located in the back of the TV next to serial number
Jun 03, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Samsung Plasma Lines and Colors on Screen
yes it can fix. its only loose connections from LCD connectors. trust me. romsky79@yahoo.com
May 29, 2009 | Samsung HP-R4272 42 in. Plasma HDTV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Vizio P2 42 in. HDTV-Ready Plasma
Search Google "Screen Burn-In."
Mainly Plasma screens are affected by it.
Sep 20, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Aug 15, 2008 | Vizio L32 32 in. LCD HDTV
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Vizio VP322 32 in. Plasma TV Logo
580 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
