Question about LG LDS4821WW 24 in. Built-in Dishwasher
Dishwasher compartment i am using an lg dishwasher for the first time and i dont have any manual there is two slot for the liquid to fill and i dont know which compartment is for which and i appreciate if u please let me know thanks
    Problem Solver:
  • 10 Answers
Pour right into the main opening( under the cap where you see the lever with 1,2,3.. the 2 slots are simply air holes... liquid will drain through..some bubles are normal.
Posted on Feb 05, 2011
How can i use the liquid soap inside the dishwasher
just fill the same holder that you would use for powder.
Dec 17, 2010 | Dishwashers
Tip
White residue on dishes
This has become a huge problem and a big misunderstanding on what the white dried residue is on your dishes.....IS it hard water probably not . Due you use liquid or powder soap and fill both soap compartments !!!!ow<br /> <br /> well here is a solution first stop using to much soap!!! <br /> most people only need no more than a tablespoon of soap.... powder or liquid..total... dont forget that powder soap can go bad in those card board boxes in a humid enviorment,,,( under the sink) remove and discard any soap that's clumpy and pour rest in a tupperware dish...<br /> <br /> so here is how to remove white residue off dishes...<br /> <br /> Fill your kitchen sink with hot water no soap and 1 cup of vinegar let dishes soak dont let water cool scour dishes in sink no soap rinse them and air dry all dishes .... some dishes may be ruined due to how long white residue had been on them called etching..... now we need to clean the dishwasher start dishwashere like normal no soap and let run for few seconds when dishwasher starts to fill open door and pour in atleast 2 cups of vinegar close door and let dishwasher run cycle repeat necessary till residue is of wash arms racks door and cabinet walls ... these steps need to be repeated in most cases a few times ...
on Jan 27, 2011 | Dishwashers
Dishwasher powder
Check inlet water quality. It's hardness level. Use salt meant for dish washers. There will be a salt fill compartment. Refer user guide.
Finally check whether the rinse aid dispenser has liquid for dispensing.
May 26, 2010 | Dishwashers
Greetings from Downunder, i have a HDWSE12 dishwasher Rinse aid light flashes all the time and it won t go. I put dish liquid in rinse aid container - still flashes. Don't normally have to use rinse...
the rinse aid compartment has to be one of the biggest things in your unit. it helps with drying process or you will have wet dishes, helps with spots, and also with the cleaning process, this is what you can do . add jet dry or rinse aid not soap .fill compartment then close door ,then raise and lower door 3times then open the compartment door and add more repeat this process until you cant add anymore. this will pull all of the air out of the dispenser and allow you to fully fill compartment . the light should go off .
Mar 04, 2010 | Dishwashers
Bosch dishwasher leaves water at the end of its cycle cleaned filter and the impeller seams free and not blocked
check for over sudzing. dont use a cascade with jet dry in it. use regular dishwashing liquid and fill jet dry compartment. you can even jet dry level by turning the knob in dispenser.
Nov 12, 2009 | Bosch 24 in. SGS43C12 Classixx...
WHERE DOES JET DRY GO
the turn nob is a cap that you screw out and pour your jet dry liquid in then replace the nob/cap the jet dry will be dispensed automatically.
Sep 29, 2009 | LG Dishwashers
Put rock salt in instead of dishwasher salt wat damage has been done if any
Salt? Why are you using salt to begin with? Why are you not using the liquid soaps etc. If your one of those all natural people i use all natural liquid etc. Salt is corrosive and parts that are not stainless steel will corrode quickly!
Jun 03, 2009 | Dishwashers
Put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Apr 04, 2009 | Kenmore Dishwashers
Dishwashing liquid was placed in the jetdry compartment
hi thanks for the question no its not ruined . just keep filling using vinegar , that will cut down the suds .do it 3 or 4 times problem will go away thanks the appliance doc
Sep 27, 2008 | Hotpoint 23 in. BF41 Built-in Dishwasher
SOAP DISPEN
is the machine heating ok?, if so then the dispenser and or the electronic control board is most likely faulty.
if the machine is still in warranty call your lg service agent and when the tech is on site, request that he change both the dispenser assembly and the control board.
if you are not over filling with powder then using liquid will make no difference.
Feb 19, 2008 | Dishwashers
LG LDS4821WW 24 in. Built-in Dishwasher Logo
66 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
