Insigna ns-dxa1 converter
I purchase the above converter box to add off air digital signals to my tv with only an analog tuner. However this TV is also used to receive Directv programing. The problem. When the converter is installed the converter works well with the common feed coax, ie off air signals and Directv , when tuning the local tv digital channels. However the Directv receiver outputs on either ch 30 or 40 and all of those signals are blocked by the converter. Turning the Insignia converter off, pull power plug etc nothing allows the Directv signal to reach the tv unless I reconnect the tv to the antenna lead thus bypassing the converter box. Local customer service at Jefferson City MO assured me that this converter would allow the directv sigals to pass when tuned to the correct channel.
  • Anonymous Mar 26, 2014
    I have no digital reception on my TV, I have been experiencing bad reception for a while so tried to reset by retuning and now it is showing a blue screen saying no signal and will not tune any digital channels
    Sergeant:
    Champion:
  • 319 Answers
You might try useing a higher bandpass diplexer
Posted on Apr 24, 2008
Does my Curtis Mathes Tronics model 19001 have a digital tuner?
No,all small tvs CRT tubes analoge tvs design under 35" none of the tvs have a digital tuner inside of it tv Tuner signal board.Must get a signal through a Digital Converter box to recieve a free on AIR broadcating channels from a Digital broadcasting signal.Tvs that are analoge CRT tubes design that have a Digital Tuner design inside of it are only some DLP tvs analoge CRT tube design 40" and above have it only.
Aug 09, 2011 | Curtis-Mathis CM19011 TV
I own an Insignia flat screen tv, NS-LCD27, & I was given the Insignia converter box, NS-DXA1; how do I program tv remote for the box? Thanks, frances b.
The digital to analog converters did not exist when the TV was built and the remote programmed. Thus you will have more luck programming the converter box's remote to control the TV. (At least with my converter box, the included remote could only turn on and off the TV. It would only change channels on the converter.)
Most universal remotes only have codes for devices released 6 months or more before the TV was programmed. So a new universal remote will probably control both the TV and the converter box. (Program the converter box using a code for LG or Zenith set top boxes if Insignia isn't listed. LG makes Insignia video products for Best Buy.) The remotes that are programmable by a USB connection to a computer are the fastest to set up.
A replacement remote for your TV is available here: http://www.mcmelectronics.com/partfinder.aspx?brand=&mdl=NS-LCD27&mode=part . An exact replacement remote for the converter box can be purchased at: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13055197980390&smodel=NSDXA1&brand_pn=INSIGNIA_NSDXA1 . The manual for the converter box (as a PDF) is here: http://cbsdallas.files.wordpress.com/2011/01/insignia-ns-dxa1-manual.pdf .
I hope this helps.
May 16, 2011 | Insignia Televison & Video
RCR Universal Remote Code for Insigna HD Converter Box NS-DXA1
Try 189 or 244 or 309..........Hope that was helpful Thanks for using Fixya.com.............enjoy your evening!
May 30, 2009 | RCA 3-Device Universal Remote
Can I receive a digital signal and if so, how?
I'm pretty sure this TV already has an NTSC/ATSC/QAM tuner in there, and should need no converter box whatsover... I say this because I own one...
Mar 09, 2009 | Insignia NS-27 TV TV
Insignia NS-DXA1 APT remote control doesn't work
Set your TV input to match the input your have your Insigna connected to. Then run the Insignia setup. You are getting a distorted screen because you probably have the Insignia connected to channel 3 and the TV on channel 4.
Dec 30, 2008 | Insignia Digital-to-Analog Converter for...
Insignia digital converter box NS-DXA1 saying no signal
Connect your Insigna unit to your television video 1 input. Connect your antenna to the Insigna. Turn on the television to video 1 source. Power on the Insignia. Now go through the auto-detect routine to set up your television stations.
Dec 29, 2008 | Insignia Digital-to-Analog Converter for...
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Insignia NS-DXA1 - Digital to Analog converter box
I have had my converter box 5 days now. I hooked it up to the TV and set it up. No Problem. Except there are no instructions on how to set up the VCR/DVD player with it, which we use more than we do watching TV. Everything worked fine until on the second day we had it I read I could program the remote to turn the TV on and off. I followed the instructions and the TV went off. When I turned it back on, my remote went berserk. If I try to change a channel it will quickly flip through all the channels until I turn the converter box off. Same with the volume, it goes up and down, up and down until I shut off the box. The remote does not work unless you are about 1 foot away from the box. And the remote has never turned the TV on or off except that first time I programed it.
May 19, 2008 | Insignia Digital-to-Analog Converter for...
96 people viewed this question
 Grubhead
Grubhead
