Question about Exercise & Fitness
How can fix my healthstream LS720T treadmill? my healthstream LS720T treadmill after i turn it on it slowly run then it will go faster then stop and will indicate error message E1, what is wrong with it?
  • imesalv Aug 13, 2010
    " awesome!!!! just briliant.........i just follow the procedure do a bit of adjustment then presto!!!problem solved !!!! thanks a lot !!!!!!!!!!! "
  • Anonymous Mar 16, 2014
    When I turn on my Healthstream Equinox treadmill it lights up but nothing is working? any thoughts please
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 218 Answers
You will need to check the speed sensor for proper alignment and function. it should be located near the front roller or mounted on the motor. It should be within a credit cards width of the magnet or toothed wheel. If properly adjusted check with an ammeter to see if it is opening and closing by manually spinning the front roller or motor flywheel. If it isn't replace the sensor. If it is functioning make sure you are getting 5vdc to it across the wires. If you are not replace the upper control board(console). If you are getting the proper voltage then replace the lower control board(motor controller).
Posted on Aug 11, 2010
Testimonial: "awesome!!!! just briliant.........i just follow the procedure do a bit of adjustment then presto!!!problem solved !!!! thanks a lot !!!!!!!!!!!"
How do I fix E7 error message on Healthstream Elite treadmill?
If you wish to get some details about treadmill error codes; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 04, 2016 | Exercise & Fitness
How to fix e7 on healthstream genesis treadmill
If you wish to get some details; check the site linked here. Pull up older posts.
May 12, 2016 | Exercise & Fitness
Healthstream manual I have a GE3400T healthstream
go please to www.fitness.manualsonline.com or www. retrevo.com
and download for free.
God bless you
Oct 31, 2013 | Exercise & Fitness
I have a T802 Healthstream treadmill that has an error 2 on it? Can't clear it.
follow this steps and fix it. God bless you
Instructions
    • 1 Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
Oct 15, 2012 | Exercise & Fitness
Healthstream Elation HS 2200T - E3 code - incline not working
1) Lube the shaft and gear from elevation motor
2) Tight the connection motor very well.
3) Adjust the potentiomenter from elevation motor
4) Measure the voltage input.
5) Try to RUN the software calibration for diagnose, and troubleshooting see the block diagram.
God bless you
Jun 13, 2012 | Exercise & Fitness
Error E6 on Healthstream treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
Mar 16, 2012 | Exercise & Fitness
Exercise & Fitness Logo
825 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
