I have a problem with my pc it will not boot up it starts to boot then just turns off I cant get and diag done to troblem shoot the problem PC specs Win XP sp3 3gb ram DDR2 Celeron D Processor Gforce 4 graphics card 1TB Sata HDD
  • 700 Answers
Now, this sort of shut down is difficult to diagnose on remote, i would suggest downloading your motherboard manual beforehand. before you do anything, i would suggest read in manual where is reset pin and how to reset bios to original state, but do not do that yet, it will lost all your mods settings and return m/b - bios to original state. there are several possible causes of that fault.
1. faulty memory stick
2. thermal or fault on power supply
3. thermal or fault on motherboard
4. corrupted bios
we will start with easiest to check re 1.
a. switch off your computer,
b. remove power cable from power supply,
c. remove side wall,
d. remove memory sticks and replace them with known working ones from another computer
e. reconnect power supply and switch computer on, if computer works correctly, you solved your problem and need to replace memory sticks
power supply is not much more difficult re2.
c. remove power supply cables from motherboard and all accessories, do not remove power supplly from it's craddle yet
d. connect cables from new power supply to your motherboard and processor fan, connect them to your hdd and cdrom,
e. connect power cable to new power supply and start your computer, if computer run correctly, switch it off, remove old power supply and replace with new one
most tiddly bit... when you arrive here that meant that previous two did not solved your problem, re 3:
c. disconnect all cables from your m/b
d. connect power supply to m/b and processor fan
e. connect ps2 keyboard
f. connect monitor if "all in one" m/b, video card and then monitor in any other case
g. insert power cable to power supply
h. switch on your computer
i. acess bios (that is usually done by tapping "delete" key, find in your manual) if possible, if not then:
i1. switch off power supply
i2. remove power cable from power supply
i3. re-set bios (you need to locate reset pins/switch/button on you motherboard in manual)
i3. reconnect power supply cable \
i4. switch on the computer
j. acess bios and set your thermal to 75centigrade or 80 centigrade and 5min
k. close bios saving changes
l. re-boot your computer and leave it for 10min, if computer still run, that will indicate your problem lies elsewhere.
checking auxiliaries:
c. connect cd-rom
d. reinstall power cable and re-start your computer
e. allow 10min run and check if computer is still running
switch off. remove cable and connect your hard disk drive, run or switched off? if off, you need to check your hdd...
any other auxiliaries need to be connected again in steps and if finaly you find one which terminated boot up, this meant that this particular element is responcible and need replacing. you need as well consider that your power supply maybe perfect on the bench, but will be too small for load required adn simple upgrade to more powerfull mother board can solve the problem.
hope that half book on problem solving solve yours :-)
Posted on Jul 30, 2010
When i turn it on it shows no operating system not found
boot record has been corrupted, or the hard drive is toast!....problem is that you have no cd/dvd rom so you cant insert a restore disk....if you wanted to test it yourself you would have to learn to boot from USB(flashdrive)....unless you have a external USB dvd that you can hook up to it to attemot to rebuild the boot record!
Jul 17, 2011 | Dell Inspiron Mini 9 Notebook
I have had problems when starting from cold - the workstation dell Precission 670 starts to boot then it gets to the window screen for only a few seconds and the screen goes dark and the "B" & "C"...
B and C usually indicate a drive failure. if issue only occurs on COLD boot and successive boot attempts gain access to the OS, then the most likely issue is that the HDD is slow to come to operating speed, (Drive has to be at Approx 97% of rated rotation speed before is can successfully read) on drives where the spindle is slow to come to speed, a cold boot then successive warm reboot will often gain access to the HDD/OS
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
One problematic issue on diagnosing this is that you only have 1 opportunity to run diags (The cold boot) and get a reading on if the drive is failing to read (also because diags are generally slower to load, the drive may come up to speed before the diag actually runs)
If issue is problematic and getting worse, I'd replace the HDD
Oct 22, 2010 | Dell Precision Workstation 670 PC Desktop
The pc starts and the Dell logo comes up but no windows boot
press the Fn Key and the power button see if the diags will run. You may have a hard drive problem or an issue with the operating system
Jul 09, 2010 | Dell Inspiron 1545 Notebook
Hi I have Inspiron 6400 laptop and the problem, it...
Here are some tips
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
If the system is posting but will not boot to Windows, then try re-seating the drive, resetting BIOS defaults and running diags on the HDD (Fn+Power Button to start diags)
May 21, 2010 | Dell Inspiron 6400 Notebook
Its just stuck on the Dell screen at the begining energy starpage
if the system doesn't boot past the Dell Screen, the most likely issue is the hard drive.
See if you can bring up the F12 menu at boot and run HDD diags.
If you can't do that and have the dell resource cd, you can try booting to that CD, and run diags there
Apr 09, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
I cant get it to turn on I have tryed to charge it multiple times but it wont and i tryed the on button but it just wont work
possibly a dead dc jack on the laptop. common issue, not to pricey to repair. should be done by a pro. if you have a secondary power cable or access to one identical, use it first to make diag easier on whoever works on it
Dec 28, 2009 | HP Pavilion dv9000t 17" Notebook Laptop PC...
Dell laptop will not boot up?
Turn system on by pressing FN and the power button, this should start the system diagnostics. If hard drive diags pass, then new would be boot to the WIndows CD and Run Repair (Vista) or boot to recovery console (XP) once in recovery console, run the command CHKDSK /R
If running Vista repair, you may need to run the repair tool up to 5 times (Each pass makes a partial repair, it make take more than one to complete all issues)
If Diags fail, replace the hard drive.
Dec 06, 2009 | Dell Inspiron B130 Notebook
Vista not start !!!!!
Use your "Vista start up DVD" There is a trouble shooting part when it boots off the DVD.
Jul 14, 2009 | eMachines E620-5885 Notebook PC
Hi I have a inspiron 6400 - when it turn on only restart on boot logo.
first try and run diags Hold Fn Key while pressing power button, and see if you get a failure running diagnostics.;
If diags will not run, then remove HDD, and boot to the resource CD and see if diags will run there.
If diags pass, try booting to the XP CD, press R at the 1st prompt to enter Recovery console, and run CHKDSK /P then reboot and see if you can get to the OS.
If you can't get to recovery console or if you get a diagnostic failure on the Hard Drive, then you will need to replace the hard drive (around $100)
Jun 28, 2009 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
110 people viewed this question
Alun Cox
David Payne
David Payne
