Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Top half of center agitator stripped. How do I remove/replace/tighten?
  • Anonymous Mar 26, 2014
    how do I remove stripped screw from the top where the agitator dogs are
  • Whirlpool Master
  • 2,605 Answers
Hi, Welcome to FixYa. You'll need to remove the top of the agitator, (the cap) and then the 9/16" or 1/2" or possibly a 7/16" bolt in the center...it may look nothing like a bolt, it may be a plastic block, but it still screws off counter-clockwise. Once you have the agitator unfastened, you'll expose the hub/retainer which hold's the gears in place. Now you need to install new dogs ( alone part # 80040 ) or part # 285751 as a kit with new hub too. These are availble at most brick & mortar parts depot's as well as on-line vendor's such as"repairclininc.com" or "searspartsdirect.com" to name a couple. I`ve also attached a helpful link which is a youtube video on "how to". The machine may have slight differences and features, but is the same basically. http://www.youtube.com/watch?v=V5wIN1J70-Y Hope that help's, let me know if I can assist you further. Thank's for visitng "fixya" today. Please take a second to rate this solution & leave a testimony. Good luck, macmarkus :)
Posted on Jul 30, 2010
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • Mar 22, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
    Agitator seems "broken" in half.
    You will need a set of adjatator dogs about 5.00 for a set..get them and we will show you how to replace.czerney@msn.com thanks for voting good luck.
    Mar 15, 2011 | Whirlpool Washing Machines
    Agitator for whirlpool washing machine
    The plastic dogs are stripped inside the center of the agitator. To remove agitator pop off the top center cover(slot for screwdriver) There is a 7/16 inch bolt with standard thread, remove it and pull out agitator. Pull the agitator apart, you can stand on the bottom half and pull on the top, you have to reassemble it with the new dogs replaced(there are four in a package) Fairly simple, no special tools needed,
    good luck.
    May 27, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool top-loader LSQ9200LQ0 The top half of the agitator is not turning. I am assuming it is a stripped part. What would be the best way to take this apart??
    You have what bad "agitator dogs". Yes this is a stripped out part. To get to the dogs, you will need to take the fabric softener dispenser off the top of the agitator (if your unit does not have a dispenser, then just take the cover of the agitator). Under that you will see a semi transparent cap that fits inside the shaft of the agitator, pull that straight up and out of the agitator. Now you can see the bolt that hold the agitator to the transmission shaft, this is a 1/2" or 9/16" bolt. You will need a socket with a long extension to reach this. Take a digital picture, or sketch the position of the dogs inside the agitator, this will help with the reassembly process. Once the bolt is out, the agitator will lift off. Turn the agitator upside down and depress the tabs up inside the shaft of the agitator, this will release the top of the agitator from the bottom, be careful, there are small parts that will fall out. Try to separate it in one piece, as this will make it easier to reassemble. Once separated, remove the old dogs and replace with the new, reassemble in reverse. When tightening the bolt, only tighten snug, the black rubber gasket should not bulge out when tightened. Also make sure the "o" ring on the semi transparent cover is in place and not broken. If you have questions, write me back. Hope this helps!
    Dec 14, 2009 | Whirlpool LXR9445JT Top Load Washer
    The top agitator does not work. It seems that
    This problem is generally caused both by by overloading the machine and time. The kit to repair it is called an "Agitator dog kit" and can be purchased at any parts outlet for likely less than $10.
    To replace the Agitator Dogs, follow these steps:
    1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
    2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
    3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
    4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
    5. Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
    6. With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
    7. With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
    8. Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
    9. Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
    10. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
    Good Luck
    Oct 03, 2009 | Kenmore Washing Machines
    Stripped gears
    It wasnt necessary to remove the shell. The agitator dogs can be replaced from the top through the lid.
    The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
    What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
    SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
    1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
    2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
    3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
    4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
    5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
    6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
    7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
    8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
    9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
    10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
    These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
    Washing machine agitation problem?
    The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
    What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
    3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
    6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
    Feb 14, 2009 | Kenmore Washing Machines
    Agitator gear is stripped
    just place both feet on the agitator as it sits on the floor and lift up on the top half. there are plastic tabs on the bottom half that hold the two pieces together. you will need to remove the 2 tabs before putting the 2 pieces together. the bolt that you screw the agitator down with will hold the 2 pieces together. Joe
    Dec 03, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Kenmore Washer Model #82881110
    Remove the dispenser cap by pulling it straight up. Under the dispenser cap, there may be another cap. If so, remove the center cap exposing the agitator bolt. Using a socket and ratchet remove the agitator bolt and the top half of the agitator can be lifted out as one piece. With the top portion of the agitator removed, grasp the lower agitator by the bottom flanges and pull straight up. The remaining section should lift off the center post. For a helpful illustration of what I'm talking about, go to searspartsdirect.com and type in your model number as "110.82881110". Go to the "Agitator, Basket and Tub" heading. There's an exploded view illustration of the agitator and all the components. If you require parts, all the part number and pricing information is available, as well. I hope this helps you.
    PS When re-installing the agitator DO NOT over tighten the agitator bolt. This can cause damage to the agitator and create slow rotation problems. Just make sure you tighten the bolt snug, and then give it about a 1/4 turn.
    Oct 09, 2008 | Washing Machines
    Agitator barely moving and the bolt is not stripped
    rethread the center post and use a smaller nut thats what I do but use a lock nut product to ensure the nut and that solve your problem...good luck,,,and rate me...oh I forget,, use silicone glue to put the factorie nut just to cover the ugly of this repair...
    Jan 05, 2008 | Washing Machines
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    342 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
