Question about Emerson Refrigerators
Our brand new Emerson CR 281B mini fridge won't cool. Did we forget to do something to get it started?
My Emerson mini fridge isn't cooling
make sure its leveal if so probably a freon leak need to take the inner core out and epoxy the leak and refill but check the condenser coil for dirt
Jan 02, 2018 | Refrigerators
Emerson compact fridge with freezer compartment freezer is very cold fridge nothing just warm is there any fan to blow air>> thanks
Your freezer fan unit may be frozen behind the inside wall and therefore not circulating the cold air down.
Se if you can remove the screws and back wall to check the fan unit.
Not all modeles can be repaired this way
Jun 04, 2016 | Emerson Cr500 Refrigerators & Freezers
Brand new mini fridge was on it's side before being set up. Plugged in too soon. Now it won't start cooling. Are we out of luck?
It could be that liquid coolant got into the low-pressure part of the cooling system when it was on its side, and is preventing the expansion valve from doing its job converting high-pressure liquid coolant to gas. My recommendation is to unplug it, wait the 24 hours, and plug it back in. Excess fluid should have drained to the bottom of the cooling system by then, and normal cooling can begin.
Dec 19, 2013 | Black & Decker Food Processors
Brand new Kenmore mini fridge is making an annoying whistling noise
If Sears did suggest a solution for the symptom you describe it would probably be to replace the fan.
Nov 21, 2013 | Kenmore Refrigerators
My brand new Emerson 286 mini fridge just stopped working after almost 2 months.
Sounds like there is some warranty left on this unit.
Try unplugging it for some time; return power to it and see what happeng.
Another teat: Join the two wires at the thermostat t see if the fridge starts. If it starts, then the thermostat is bad.
Oct 24, 2013 | Emerson Refrigerators
Emerson mini Fridge will not cool. Electronics?
Sounds like the compressor starting componets or a capacitor is bad.
Jan 03, 2018 | Emerson Refrigerators
Mini fridge doesn't get cold anymore
Is the unit running? If so then,
by shutting the unit down for a long period may have exposed a pinhole leak of refrigerant at an external brazing point. or you may have caused an issue in cleaning it This is something that would require a licensed technician to resolve.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 15, 2017 | Emerson Refrigerators
Can i plug a mini fridge into a surge protector?
you must check the amper ( current) rating as will as wattage of the mini fridge usually at the back portion. if the current and wattage rating of the surge protector is higher capacity so it can hold this fridge.
Oct 02, 2012 | Emerson White Compact Fridge - 1.8 Cu. Ft
Fridge makes a clicking noise everything in freezer melted and fridge won't cool. Model number ED5VHEXVQ03. I replaced the starting relay but not the resistor. Problem is the same still clicks...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 31, 2011 | Refrigerators
Brand new wont get cold
I have a Danby Premiere Mini Fridge. It was sitting in the garage for a while.
I plugged it in and nothing, no sound .. no cooling.
The outlet is definately on. Do I have to push any buttons or reset something?
Thanks for your help.
Mario
Jul 06, 2009 | Danby (DAR604BLS) Refrigerator
Refrigerators Logo
322 people viewed this question
Top Emerson Refrigerators Experts
John Tripp
John Tripp
Johnny 1000
Level 1 Expert
Are you an Emerson Refrigerator Expert? Answer questions, earn points and help others
