Question about Radio Communications
COBRA 21 GTL NO MODULATION NO RX. BUT IT WILL TX AT 3 WHATTS.I HAVE TRIED 3 DIFFERENT.MIC ON THIS RADIO CAN YOU HELP ME
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 184 Answers
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike.
Posted on Sep 01, 2010
Where can I find a new replacement modulation transformer for a cobra 29 ltd classic?
simple,just chech the input resistance and out put...they should have even small resistance always example .5ohms .3 ohms it counts...
Feb 01, 2014 | Cobra 29 LTD CB Radio
148 mic wiring white d104
five pin /4 pin? (white D-104?)
five pin= 1-audio,2-shield,3-RX,4-comm,5-TX
4 pin=1-shield-comm,2-audio,3-TX,4-RX
Jan 03, 2014 | Cobra 148 GTL 120-Channels Base CB Radio
Radio quits after 15-30 seconds
without more detailed info, quick suggestion - thermal fault, if all TX audio works when in this fault condition, it may be fair to assume audio IC is ok and check electrolytic capacitors and dry joints.
Nov 28, 2011 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 18 wx st, Rx & Tx is ok but no modulation
Hi, my name is John. Welcome to FixYa..Try a different mic., if that fail,s, we need to look at your audio chip, also a few capacitors..let me know , we are always here to help you. thanks for choosing FixYa...John
Nov 20, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
I have a Cobra 18 wx st. I am not able to transmit anything on it. I have checked the antenna cables and and all external connections. I receive all the wb just fine but the CB gives me nothing. I tried a...
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike. With the WX band working, the above may not apply.
See if you have a carrier...signal going out, but no modulation. Get your Tech to check the mike wiring/circuitry inside the radio, also.
Jul 06, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
I need to know if it's possible to convert the cobra 148 gtl 5 pin mic jack to 4 pin mic jack.
5 pin to 4 pin as follows, from the Cobra website.
1.->2 Audio
2.->1 Shield and common
3.->4 RX
4.->also goes to pin 1
5.->3 TX
Apr 21, 2010 | Radio Communications
148 cobra with no modulation
possably corrosion on the pins of the plug into the radio, unscrew, push in and out a couple of times, and try again, maybe a break in the cable where it flexes the most. or faulty antenna
Oct 23, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra gtl 148 seems to have no power til i push on mic connecter.
cobra 148 shows no wattage output on external meter but does show good modulation.
Dec 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL steady tone though speaker
try rerouting your coax cable and make sure it's long enough
Jul 07, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
121 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
