Question about Fedders X Chassis A3X05F2B Air Conditioner
Replace fan motor overheating fan is fyk-62s helix motor ltd
My ac motor no work at all is a FYK-62-S ,how much cost to buy a new fan motor?
Posted on Jul 19, 2012
Volume on Garmin 62s ? Does it have one?
Honestly, I don't know, but check owners manual:
Garmin GPSMAP 62s Manual
Jun 08, 2015 | Garmin GPS
Bissell bagless vacuum just stopped working
the most likely to be overheated the motor, or cut the cord.
for the first unplug the power supply and let it COLD, ALSO CAN SWITCH AUTOMATIC OVERHEATING or proving or proving MANUAL. for the second take the machine to an electrician to check out the cable.
Nov 28, 2013 | Bissell PowerForce Helix Bagless Upright...
Garmin gps sistem software missing 62s?
my gps 62s sowu system software missing
Dec 19, 2012 | Garmin GPSMAP 62s GPS Receiver
LWS21AW -3062 transmission
you will find that the cog driving the spindle has a worn spot and jumps every time it gets to the same spot the best thing to do is find the same machine in a scrap yard and swop the affending part or look on gumtree for a replacement machine altogether eric
Dec 19, 2017 | Washing Machines
My 99 Honda Accords keeps overheating on and off when my car is on park or at a long stop. What can be the problem?
FIRST OF ALL I WOULD REPLACE THERMOSTAT AND RADIATOR PRESSURE CAP THEN CHECK SEE IF COOLING FAN RUNNING.WHILE CAR OVERHEATING. IF NOT CHECK COOLING FAN FUSE AND RELAY.IF ALL IS GOOD THE ENGINE COOLANT TEMPERATURE SENSOR COULD BE FAULTY.HOT WIRE SEE COOLANT FAN WORKS IF NOT, COOLING FAN MOTOR BAD NEED REPLACING.IF COOLING FAN MOTOR WORKING PROBLEM COULD BE IN FAN MOTOR WIRING OR PCM FAILED.
Sep 20, 2011 | 1999 Oldsmobile Alero
Troubleshoot 97 olds achieva overheating
REPLACE THERMOSTAT AND RADIATOR PRESSURE CAP.IF STILL OVERHEATING CHECK TO SEE COOLANT COMING ON IF NOT CHECK COOLANT FAN FUSE AND RELAY.IF BOTH GOOD.HOTWIRE COOLANT FAN TO SEE IF IT WORKS IF NO REPLACE FAN MOTOR.IF FAN MOTOR RUNS FAN MOTOR WIRE HAS SHORT OR COOLANT TEMPERATURE SENSOR FAULTY.
Aug 20, 2010 | 1997 Oldsmobile Achieva
FAN MOTOR CUTS ON AND OFF. FINALLY QUIT RUNNING.
As you are looking into the engine compartment from the front it is to the left of the blower motor.
Here is a diagram to help you find it.
Jun 01, 2010 | 1997 Buick LeSabre
My car is overheating and i need to know how to put in the water pump?
Is the water pump leaking coolant? If not, then why do you think it's bad?
If the engine is overheating, there are several other things to look at before you consider the replacing the water pump.
Are the fans electric motor driven, or fan belt driven? If fan belt driven, replace the fan clutch. If electric motor driven, check the fan control module and/or fan motors to make sure all is good there. Fan control module tend to fail in weird ways, so if nothing is wrong with the motors, replace the module.
Always, always, replace a thermostat that has overheated. Once overheated, they consistently fail. Make sure you properly refill the radiator with coolant after the stat is changed.
Check that the bottom radiator hose does not collapse.
Check the radiator for corrosion. Boil the radiator out, or have it done, or replace the radiator.
Dec 18, 2009 | 1997 Buick Skylark
Maytag washer sav2555
the pulley will not remove very easily , it wold require removine the milk stool, motor and some other parts, not the easiest hing to do especially if not needed, the helix you removed, take a look at it , the sloped ends of it should create a pretty sharp angle, then a 90degree drop off, the slopes om the pulley should be the same, they should not apppear to be rounded off,helix is probly 10 bucks if needed and if its at the helix that you see the "slipping" and "clicking noise, before condeming the tranny i would start with tthe helix, if after re-installing it it still clicks up and over pully perhaps try adding another spacer under the bolt before tightening. the idea behind the pulley and helix is that depending on rotation of the transissiion, the helix "pushes against" the pulley adn spreads the brake plate, releasing the brake allowing the tub tospin freely
Apr 06, 2008 | Maytag SAV2555A Top Load Washer
Fedders X Chassis A3X05F2B Air Conditioner Logo
326 people viewed this question
Top Fedders Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
