Question about Kicker KX Series 04KX1200.1 1200w RMS Monoblock Amplifier
Kicker amp 1200.1
Yes tech guru my kicker one day working next not having any out put to the subs. I took it to the stereo shop and they checked the power supply and everything running 12-14 rms. So what's the problem? should i pulled the amp and sending it to the factory for repair? help me if you think there's a fuse or something i can pull and plug and play again?
5 Suggested Answers
Garfunkel01
  • 56 Answers
SOURCE: Red light on Amplifier
if your amplifier has the internal Kicker card dealie "little computer card on the side that you can change out crossover settings and such," Turn off the vehicle, remove this device and make sure the contacts on the card are clean and free from black soot (showing a spark). clean the contacts with a pencil eraser or something hard but soft... and put the little card back in place, start the car again and see if that helps, I used to lose one speaker every once in a while with the same amp. I ended up replacing the module with a different one from my dealer and it worked fine (still does and it's been in my car 6 years). Check that little module. if this doesnt work, while the car is running and the music is "playing" wiggle the card and see if it works sometimes and not others. Likely is the little module.
Posted on Aug 15, 2007
SOURCE: Kicker KX150.2 amp problem
How man ohms are your subwoofers, how many are there and how do you have them hooked up? It sounds like to me, you had too low of a load for the amp to handle. However, the amp should have automatically shut down and gone into thermal protection mode. Since it didn't it, it overheated and turned into jelly. I hope you have a warranty! Before you try to return it, be sure you meter the ohms of the subwoofers, or they won't honor the warranty. Let me know! Be sure to leave feedback or I don't get paid.
Posted on Oct 03, 2007
SOURCE: kicker kx1200
I am having the same issue, my kicker kx 1200 watt amp was pushing two JL Audio W6 12's and amp has power but no speaker out put, sending my amp to kicker for the thrid time. I tryed in my friends car with no luck.
Posted on Sep 02, 2008
t1randa
  • 27 Answers
SOURCE: Does a 1200W amp run 2x800W subs
ya youll be fine 800watts is at peak power on the speakers
Posted on May 29, 2009
  • 11 Answers
SOURCE: i have 2 kicker l7 12 dual voice coil subs.. i
it all depends on the impendance of your subs if u have duel 4ohm or duel 2ohm, 2 duel 4ohm speakers can be wired at 1ohm to the amp, and with a kx1200.1 that would be pushin 2400 peak and 1200rms
if ya have 2 duel 2ohm speaker than you can only wire them to 2ohm and would be pushing 1200 peak and 600 rms with the kx1200, so if you have the duel 4ohm i would go with the kx1200.1 and if u have the duel 2ohm i would go with the hifoncs
Posted on Jun 16, 2009
Need to know if my equiptment can push another kicker
yes you can add another sub to your amp. hopefully it has another terminal to let you do so if not you can just use one and splice the wire to each woofer. and yes get a capacitor itll save your battery alternator ect... i waited to long and fryed my heated seats from my car power surging
Dec 04, 2013 | Kicker KX Series 04KX1200.1 1200w RMS...
Can you run a 1200w pioneer sub and 2x9x9 inch car speakers to a 600w pioneer 4 channell amp??
depends on what the RMS is for the subs because although the subs are 1200 watts, there is a minumim standard you have to follow. If you don't atleast run the lowest wattage thru them, then you will most definately damage the speakers....you should also be aware of the fact that your "600w Pioneer-4 channel amp doesn't even push a true 600 watts... Your best bet is to upgrade ur amp, or add an additional amp to your set-up. And you really need to pay close att to over or under running your power to your stereo system because you'll burn out ur altenator rather quickly. Use proper wattage , and you should also look into getting a power-cell which lessens the chances of destroying your altenator and helps to ensure that your stereo system sounds to its full potential.....
Feb 15, 2011 | Pioneer DEH-P6400 CD Player
My kicker solo baric is moving to the bass but is not putting out any sound. I've swapped the subs to see if it was the sub but it wasn't. I believe it is the amp but im not sure. The amp is in protection...
YOU HAVE A SHORT CIRCUIT WITH THE RCA CABLES THAT ARE GOING THO THE SUB WOOFER AMP CHANGE THE RCA CABLES FOR A NEW ONES!! AND IF YOU CAN BUT IT HEAVY DUTY
Feb 10, 2010 | Kicker Car Audio & Video
I have a Kicker 2500.1 monoblock amp. I am going to run 4 15 inch Kicker L5 subs to this one amp. What ohm subs do I need to purchase? Dual 2 ohm, or dual 4 ohm? Also, how would I wire these subs to pull a...
make sure that you get dual 2 ohm subs. to get a 1 ohm load, wire each sub in a series. that means the positive from one coil, connected to the negative of the opposite coil. then the other two leads will be your active speaker wires. that will give you a 4 ohm load for each sub. once all 4 are wired like this, you simply take all of the positive wires that you have left, and combine them at the amp. do the same with all of the negative wires. that will give you 1 ohm. just be extra careful to make sure every sub is wired exactly the same, otherwise your sound quality will be greatly reduced.
also, 2500 watts isnt as much power as these subs will take if wired together. it will still sound awesome, but I reccommend turning the level on your amp up just until you hear a bit of distortion, then back it off a hair. being slightly underpowered will cause you to have some distortion in your bass. playing distorted notes builds up alot of heat in the voice coils, and these subs are VERY sensitive to overheating.
Aug 05, 2009 | Tomtom GO 700 GPS NAVIGATION BRAND ONLY...
Protection light comes on went the amp is turn on and it stays on for four seconds and then the amp turn on
Disconnect any speaker from the amp then re-power. If it still goes into protection, your amp needs serviced. Shorted output transistors most likely. And check your Sub for shorts as well. If the voicecoil on the sub is burnt, it will short any amp. If you can use a meter, check the resistance on the sub. Hope this helps
Jun 02, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
May 29, 2009 | Kicker KX Series 04KX1200.1 1200w RMS...
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
The first thing to try is disconnecting ONE of the two subs. See if you get more bass with a single sub than with both. If you do, re-connect the second subwoofer, but reverse the (+) and (-) wires.
Jun 19, 2007 | Panasonic MXE CQ-C7401U CD Player
Kicker kx1200
Nov 20, 2006 | Kicker KX Series 04KX1200.1 1200w RMS...
Kicker KX Series 04KX1200.1 1200w RMS Monoblock Amplifier Logo
95 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
