Question about Crown XTi 4000 Amplifier
Amp would not turn on after power outages (twice in 30 min), I had it plugged in to the power conditioner, it wasn't hooked to the wall outlet.....please advice
  • 17,130 Answers
Switch off the amplifier for some time and allow it to reset. disconnect the speakers and reduce the volume level before you put it on. If the power does not come on you will need to probe inside. Get help if you are not familiar but check on the power lines coming in for failure of fuse, the secondary power supply section transformer or the smps power. Hope it would not go further to this but check this out.Check for shorting inthe outputs, if so disconnect and test. Good day
Posted on Jul 31, 2010
I have a new Maytag mvwc565fw. The Clean Washer Cycle was interrupted from a power outage and the unit is full of water and the lid is locked (light solidly illuminated). Trying to start any other cycle...
Resolution:If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
Dec 27, 2017 | Maytag Washing Machines
Thermostat friedrich twintemp
try unplugging it from wall and try to reset, power outage might have caused a capacitor to fail
Aug 27, 2013 | Friedrich EL25L35 Thru-Wall/Window Air...
Had a power outage a while ago for 24hrs, so I went around and turned everything off and once the power came back on I went and turn the heating back on at the mains switch. Now it is coming up with...
Pull the controller off the wall, press 3+5 buttons down, then replace on wall while still pushing buttons in.... a group of 5-6 bars will appear, then when it says type in address -turn dial to 1. this will re set it.
Dec 24, 2010 | Heating & Cooling
My wii console wont turn on, its plugged and everything, we had a power outage earlier but now no red light comes on. Please help!
Unplug the wii power cord from the wall and the wii for 5 mins. to reset the brick on the power cord.
Nov 22, 2009 | Nintendo Wii Console
Samsung Air Conditioner will not turn back on after power Outage
disconnect the units from their power source and wait about an hour. Reconnect to power source and see if this has reset the units.
Hope this helped you good luck on the repairs
Dave
Nov 11, 2009 | Samsung AW1403B Air Conditioner
Power outage this am. Wii won't even turn on
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
Try the following steps in this order:
FIRST:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
SECOND:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
THIRD:
- it might be cheaper to replace the AC adapter with another one
FOURTH:
- get the unit repaired
MUST DO:
- buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Hope that helps!
Aug 09, 2009 | Nintendo Wii Console
Air conditioner compressor runs for about 1-2 min, then cuts off
well when u have outages the voltage drops obviously, the one that suffers are the capacitors the capacitor for the compressor might need to change, change it with the same capacity as the old one example if labels say 55 microfarady ( mf ) ( 55 mf ) get one of the same I am not saying it is a 55 mf capacitor vary depending on motor and brand. So check the label
Jul 23, 2009 | Danby Portable Air Conditioner
We had a power outage and the oven will not work, after shutting off the power the panel lit up with all 8888s and will not work
Forgive me for saying this, turn the unit off wait 30seconds, then turn on again (this sometimes works)
There is a very good possibility you have suffered a power surge which has damaged your electronics unit. Please check your manual to see if there is a reset button on the display (this sometimes reolves it).
If there is no way to reset, then you will need to replace the displat/circuit board, this is quite fiddly and i would recommend you call in an appliance expert.
I hope this helps.
Jul 08, 2009 | GE PT956CMCC Profile 30" Built-In Double...
Error E4
try to unplug power from the wall and wait 30 min,
then turn on a.c.
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
AFTER 10 MIN OF TURNING THE HEATER ON OUR POWER OUTLET TURNS OFF WHAT COULD BE THE PROBLEM?
Not knowing what kind of heater this is, I will assume that you are referring to a small plug in 110 volt room heater since you mention power outlet. Check the amp rating of your heater verses the breaker. Remember if it is a wall plug that there are other plugs on the same breaker. Breakers work two ways, as an over current (amps) and thermal protection (heat). It could range from too close of a current draw for the breaker and heating it up or a loose wiring connection at the breaker or wall plug. Loose could also be the problem for a central unit. After it runs a while place your finger on the front of the breaker to see if it feels hot, it should not get warm
Apr 25, 2008 | Heating & Cooling
Crown XTi 4000 Amplifier Logo
401 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
