Question about Electrolux Dishwashers
Electrolux dishwasher wont lock but still runs, water sprays out of the door
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
Check that the top basket wheels are not broken a rogue wheel in the runner can stop you pushing the top basket in. this stops you closing the door. also that the retainers on the end of the runners are in the right position and not jamming the door action. failing that you will need a new door lock..
Posted on Jul 30, 2010
Electrolux dishwasher won't run through a cycle?
So it would be desirable to write the ERROR appeared in
Dado
Aug 02, 2014 | Electrolux 24 " White Built-In Dishwasher...
Electrolux dishwasher esl 6114 door does not lock
Hi Peter Gumbrell - Often when the dishwasher door does not lock, it is because the of door lock assembly. The door lock or latch may either be faulty or damaged. If I was in your position, I would personally recommend consulting a professional to accurately diagnose the dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Mar 20, 2013 | Electrolux Dishwashers
Dish washer wont wash properly
You should check the levels for the salt and rinse aid they need topping up weekly if your dishwasher is used a lot,when the machine is empty give it a good clean with kitchen spray all around the door and underneath the panels you will be surprised how much gunk gets stuck in their ,also clean out the filter ,when all sparkling run the dishwasher on empty to give it a good wash out, do this on its hottest setting ,if this does not work then you will need to get a technician out.
Jun 02, 2011 | Electrolux Dishwashers
I have an Electrolux ESL6115 dishwasher model and although there is water coming out and the spray blades seem to be turning the dishes are always wet after the cycle has finished and there appears to be...
Its possible that if you live in a hard water area that limescale buildup is causing this problem if salt levels got low. The first thing that can be done is to run it with 2 or 3 cups of vinegar added & see if it cures it. If it won't accept opening the door to add this after wash has started then add it in a wide dish to catch water & wash it out during cycle. Adding a dose (half cup) of bicarbonate of soda alongside should work even better. This has worked really well for washing machine about to give up on & do regularly to prevent problem. Hope this helps.
Apr 28, 2011 | Electrolux 23 in. ESL6114 Built-in...
My dishwasher electrolux esl6115 is leaking from the bottom of the door during the cycle.
My dishwasher electrolux built in unit was leaking, turned out to be the plastic nut inside on right hand side where water feeds the top rotar was loose. I actually took side off and found it running down inside and flooding out the feet and sides. Solution in my case was to wrap PTFE around the threaded section and rescrew nuton tightly..Problem solved. Simples.
Nov 15, 2010 | Electrolux EDW5505ESS Built-in Dishwasher
Dish washer will not latch
Latch is locked, but the door is open, panel will not light up. Tried to close door after loading, wouldn't close, water started running, tried to figure out what was wrong, something in the way, etc, but nothing. Then water sprayed all over, started pushing buttons, and finally it quit, now latch is locked, but the door is open.
Jul 01, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
My dishwasher is just three years old. The other night my wife said it made a loud noise while it was running and now it is full of water at the end of the cycle. Any ideas?
The pump attached to the end of the motor shaft inside the tub may have broken. If it doesn't spin the water wont pump out but usually the water wont spray on the dishes either. Watch it run a second with the door open and the door switch make to see if it's spraying.
Mar 22, 2010 | Bosch 24 in. SHX46A05UC Built-In...
Water keeps running
Hi
Sounds like the inlet valve has failed. You need to replace the part that the inlet hose is attached to
Feb 16, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Frigidaire professional series electric oven door won't open
MY OVEN DOOR WONT UNLOCK ON MY FRIGIDAIRE PROFESSIONAL SERIES STOVE 31606390
Jan 22, 2009 | Electrolux Frigidaire Professional Series...
The top rack is not getting clean.
This is one common possibility
It may be the food chopper assembly. Mine broke last year from a toothpick,
the food doesn't get chopped because the blades are broken, then the filter clogs and water wont spray high enough.
Heres a test--turn on the dishwasher and wait until you can hear water running then open the door really fast and look at how high the water is spraying--there should be alot of water all over the top rack running down
Jan 31, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
324 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
