Question about Acer Aspire 5610-4648 Notebook
I installed a new Netgear wireless router. My old G router didn't cover the whole house, so I got a N600 N/G router. My Acer 5610 hooked up the the old router with 128 bit WEP encryption fine, as did my other PC's and Laptops. Now my hard wired, and laptops with Vista work perfectly. The Acer with XP hooks up to the router, can share files and printers,.but It can't get on the internet... blanc_chat@yahoo.com
  • Acer Master
  • 1,606 Answers
This could be a few things. all are simple settings.
If you can see other computers but can't get out, your acer needs the gateway ip number. If you are running DHCP this should be automatically set but you can also manually edit the IPV4 settings
TCP/IP and add the gateway as well as the other settings. The gateway is the ip# of your router that is connected to the cable modem or the dsl modem.
As long as you don't have the number range set you can fairly safely add any number in the allowable range. So you could edit the tcp/ip settings with something like the following:
adress: 192.168.2.25
netmask: 255.255.255.0
gateway: 192.168.2.1 ** insert actual addy of router.
DNS servers can be found on your isp's info page. You can use any dns server that will let you connect. Without the dns you won't get out on the net either unless supplied by DHCP.
Posted on Jul 30, 2010
Why is my wireless connection being so slow?
Check you have your cable modem plugged in to the WAN port, not the LAN port on the router.
The manual s here
http://www.downloads.netgear.com/files/GDC/WNDR3400V3/WNDR3400v3_UM_8FEB2013.pdf
If it is still a problem consult your ISP about the set up.
Apr 27, 2014 | NetGear WNDR3400 N600 Wireless Dual Band...
I have Hughs net HN7000S hooked up to my desktop I want to use my laptop I have a netgear N600 how do I hook it up? As o WAP or router?
You connect the ISP modem to the main port on the Netgear router. You should now see a wireless network on the laptop.
Passwords / keys / paraphrases are located in the wireless part in the web admin to the router. Same thing for the user / SSID.
Jan 08, 2013 | NetGear Computers & Internet
Netgear n600 software wont install says we dont have the right OS . We have windows xp
eh, that disc is just bloat ware anyway (you don't need it)
1) connect hard line to your router (that big phone line looking cord goes from port 1,2,3 OR 4 to your computer)
2) open your web browser (IE, chrome, safari, whatever)
3) go to "192.168.1.1"
4)should ask for username and password (use "admin" and "password" for netgears... "admin" and "admin" for cisco linksys)
5) go to your wireless tab
6) choose a name and type in at SSID then click "save settings"
7) maybe same tab or maybe under "wireless security tab" choose WPA WPA2 personal and choose a password and save settings again.
9) now hook everything up normal and connect to your new wireless network!
hope that gets you pointed the right way
Oct 02, 2012 | NetGear N600 Wireless Dual Band Router...
Trying to make my Dell Inspiron 580 computer wireless with Netgear N600 adapter. I run Windows 7,
hello,
check if the router has support for win 7 ,if not search for win vista,the instalations(i mean the configuration page you should run in internet explorer) look at the link provided with the router and follow the instruction
Sep 22, 2012 | Dell Inspiron 580 Desktop Computer (Intel...
Lost passkey to my Netgear N600 Double Band Router wndr 3400
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.or passphrase etc.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Apr 04, 2012 | NetGear N600 Wireless Dual Band Router
My HP G60 laptop with Vista won't connect to Netgear router
Usually there are 2 types of wireless connections, 2.4 GHz and 5 GHz. Your laptop may not be able to connect to one of these connections, so it may be incompatible with your router. You can try buying a USB networking card (no more than $20). It will plug into one of your USB ports and should allow you to connect to your router. Hope this helps!
Jun 22, 2017 | NetGear N600 Wireless Dual Band Router
I have several computers in my house, and just purchased a Netgear N600 High Performance Router. All computers easily pickup the signal and connect to the new router. However, one of my computers using a...
you might try moving your computer closer to your router
make sure your routers and your dell 1450 settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet if applicable
hope this helps
Jan 26, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I just got a NETGEAR n600 dual band router, ran the resource cd to set up the network, and everything was successful. Whenever i connect to the wireless network my computer says its connected to an...
My Friend ,
Seems that the router is producing the wireless signal the problem is only with the computer.
What i can suggest you is to delete all the wireless networks from the list and then try to add the network again.
Dec 09, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
My internet keeps goin on and off with my new netgear N600 wireless dual band router. is my home too large for this unit? any help or suggestions? thanks.jomanfitz3@aol.com
Never buy Netgear. They design product so it won't work unless you pay more for technical support. They told me the technicians during the 90 day warranty are not good enough to fix problems, so you can't get solution until warranty runs out and you have to pay extra!
Nov 26, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
Acer Aspire 5610-4648 Notebook Logo
91 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
