Question about O2 Xda II mini
I CAN TURN ON MY XDA ONLY RED LIGHT TURNS ON - O2 Xda II mini
  • marjoriejoy2 Dec 06, 2008
    I am using xda II I am charging and it automatically turn off and I won't open it again
  • Anonymous Jan 10, 2009
    same problem !!
Try remove ur memory card... in some cases its work
Posted on Apr 30, 2008
Tv will not turn on, red flashing light comes then turns off
tv will not turn on, red flashing light comes then turns off.
light flashes six times.
Aug 15, 2012 | Sony KP-53HS30 53" Rear Projection...
Hi i plug unit with battery for charging no display lcd and no light indicator colored orange . I take out battery pack and charge then it produce light orange-red indicator of unit. I noticed charging...
Hi I solved the problem by taking off the battery for around 1 hour.
I attached the battery again.
And press hold switch around 10 seconds.
The unit booted and it proceeded to auto configure and auto installed program soft wares.
I realized that the unit is self shutting off.
Solution is go to setting.go to system.go to back light menu.
on backlight on external power .Be sure to uncheck turn off backlight if devise is not used for 1 minute.
Be sure to check turn on the back light when button is pressed or the screen is tapped.
press ok to activate the setting.
For maximized battery power and optimized power usage .go also to back light and go to brightness level.
Slide the battery and power to almost the 2ndlevel .
Hope this also will be applicable to other o2 xda iis configuration.
Best regards
Jan 17, 2010 | O2 Xda IIs Pocket PC
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
About Xda mini o2 problem, how can i now if my cellphone is fully charged?
tap on the battery icon you can see the percentage of battery charged, on charging orange light turns to green when battery is full.
Oct 26, 2009 | O2 Xda II mini
My O2 XDA mini II gets truns off oftenly , it is not action specefic but ot gets turns off i have to press top right side button and again to startsm please provide solution is this problem in OS or...
It does not turn off.
It gets into the sleep omde.
No need to worry man,
its just to save power.
All windows mobile phones do the same when left for sometime.
Keep cool .
Please Rate.
Oct 11, 2008 | O2 Xda IIs Pocket PC
PDA displays only a white Screen
don't worry just change yur display ic ......
Aug 08, 2008 | O2 Xda IIs Pocket PC
02 xda orbit..
If the light doesnt turn to orange after a few minutes on the charger then the problem hardware related. Try another battery if there is no change then there is fault in the device, and repairs are required.
also you can try
this:
1. Plug it in the Charger without the battery inside.
2. switch on the power.
3. Without removing the charger plug in the battery.
4. Light should turn orange.
5. Wait a moment or two then power it on.
that might get it to work.
May 09, 2008 | O2 Xda IIs Pocket PC
O2 orbit will not charge or turn on just red light
Anyone have a solution to this problem? I have the same thing! please e-mail: mynewemailaddie@yahoo.co.uk
Thanks.
Mar 13, 2008 | O2 Xda Orbit Smartphone
XDA Orbit Help
you need to hard reset your PDA and need to reinstall the OS..this will help you
all the best
Jan 06, 2008 | O2 Xda Orbit Smartphone
Battery problem
preform a soft and if necessary a hard reset back info to pc first http://www.pdacortex.com/pocket_pc_sites.htm Pocket PC Sites
May 10, 2007 | O2 Xda Atom
Computers & Internet Logo
85 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
