Question about Haier HPRD12XC5 Air Conditioner
Unit runs but does not cool - Haier HPRD12XC5 Air Conditioner
Rtu model# 50TCQDO8A2A5AOAOAO how to figure out if why its not running on cool even there is a cooling call
There could be a lot of reason why unit is not running in cooling .First is the unit low on refrigerant, if it is and system have a low pressure switch it would not run.
Are you getting 24 volts on R to ground.
Does the unit have a econimizer
May 25, 2017 | Heating & Cooling
Norcold 6120 gas heats and electric warmer heats still doesn't cool has no ammonia smell
Only offering I have for a consumer is to run a "highpot" test on the cooling unit. This will bypass all the controls from the board and test the function of the cooling unit. Remove the leads from the board for the heating element and connect leads directly to 110 volts. Run for 3 hours to see if cooling is stating in the freezer. If cooling detected let run for 6 hours. So on and so forth. DO NOT RUN FOR MORE THAN 12 HOURS LIKE THIS!!!!!!! If no cooling detected in the first 3 hours the unit is "stopped up" and will have to be replaced.
Oct 04, 2015 | Refrigerators
I meant the AC does not cool
Make sure the mode is set to freeze and temperature is set to below the room temperature.
If it is a split system, check the outdoor unit whether it is running. If it is running, see if you can reach and feel the temperature of the pipes connecting between the indoor and the outdoor unit. It should be cool.
If it is not cool, you may need to get somebody to check the refrigerant.
May 22, 2014 | Dometic 57915531 Air Conditioner
Unit runs and blows air but does not cool, can it be recharged?
check to see if compressor running if ok bad cooling unit or temp sensor
Jul 03, 2012 | Dometic Rooftop RV Air Conditioner
Hi i have a roof top LG LS- k1830 HL 18000/19000btu heat & cool mini split air conditioner. my ? is the condenser fan wont run and the after the unit is on for a while the high pressure line does...
the condenser fan will start as soon as the compressor turns on( that is the outside unit)
the inside fan will run regardless if the compressor is running or not
Jul 15, 2017 | LG LS-K1830HL Heat Cool Mini Split Air...
Global.netOur ac/heating unit is approx 2 years old. The unit triped the breaker resulting in the fan continueing to run, but the cooling unit no longer cooled.. Re set the breaker and unit immediately...
I would check all the connections at the breaker panel, and in the disconnect and in the control panel of the unit, the connections must be tight. If the breaker is sized to small a dirty coil could be to blame if so give it the hose, a full solid stream and be thorough is cleaning it.
Jul 02, 2011 | Heating & Cooling
True GDM-12 - Unit runs, but won't cool below 60 degrees,
Is it very hot out side the unit.recharging may not hurt is it cleaned the lint could be trapping the radiator were the coolan goes through to cool down try cleanning underneath before recharging
Jul 26, 2010 | True GDM-12 Refrigerator Commercial
Lower unit does not cool
check for conditioned space fan not running. Does top cool and not the lower or are both not cooling properly. If fan is running, it could either be that the thermostat is not set low enough, evap is frozen up, the unit is low on freon, the compressor is not running. Start checking as much as you can and let me know.
Mar 22, 2009 | Carrier Beverage AirĀ® DP46 Commercial...
Haier HPRD12XC5 Air Conditioner Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
