Question about Sony Playstation 3 (PS3) Console
Ps3 wont turn on at all.
My ps3 wont turn on at all checked the switch in the back and its on checked the connections all ok... what would cause my ps3 to not turn on at all?!
    Problem Solver:
  • 7 Answers
Maybe its the cable, or the power brick inside the ps3.
Posted on Jul 30, 2010
  • clay Oct 01, 2013
    i stored my ps3 for about t3months it worked worked when stored but will not power on now
HELP... I have a big problem with my PS3. My system was okay when I took it apart for cleaning but i completely disassembled it and cleaned the dust. I put it back together and now it wont work! When I...
I fix PS3 Yellow Light of Death.
When you say you completely dissasembled it i guess you mean EVERYTHING?
Well did you make sure you plugged the battery back in? and Made sure all connections were placed back?
If you took off the heatsink and fan from the chips then that is why it switched off!
You should have put new paste on if thats the case!
The PS3 seems it is shutting down to protect itself from overheating and burning the chips!
The baby scratch should be ok unless it has destroyed a copper track?
Goodluck let me know how it goes and please rate!
Apr 08, 2011 | Video Game Consoles & Games
My playstation 3 : everytime i turn it on it goes green then back to red and wont turn on? When it was working it just froze so i turned it off and since then it hasnt turned back on
Your PS3's problems are actually being caused by a connection error between the hard drive and motherboard. Without a correctly working hard drive connection your PS3 is unable to function and goes into shutdown mode, with the flashing red light warning .
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
PS3 Console switches on for no reason. I turn it off and sometimes 5 minutes later, sometimes 4 hours later it switches itself back on.As it is connected to the TV by HDMI it switches on the TV as well....
glenn_caroli
What most likely is causing this is another device grounding back to the PS3. Note with modern electronics they have contact switches. The work by competing the circuit to turn the device on or off.
So to test to see if it is a device causing this or an actual problem with the PS3 is to unplug all connections from the system. This includes your HDMI connection. At this point all you should have plugged in is the power cable.
Let the system set to see if it turns on. If it does not then we know it is not the PS3 that is the problem. Next start adding back in the other device until you figure out which one is causing the problem. Note I have had seen several cases where people had bad HDMI cables so you might test those first.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Aug 09, 2010 | Sony Playstation 3 (PS3) Console
PS3 wont stay on
Your PS3 may be overheating. Check the exhaust of the ps3 where the hot air comes out for any excessive dust. If you have a 60GB PS3, you can blow them out by turning off the PS3 by the back switch and then turning it on using the back switch with you finger on the eject button. The PS3 should beep 3 times and your fans should go at full tilt for about 30sec to 1 min.
Dec 28, 2009 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 the xmb menu wont show....
am sure about the computer part but for the xmb i can help reset ur ps3 by turning it on then turn it off by holding the buttonthen it back on by holding the power button it should beep pause and beep 2x this will reset ur display option back to normal then ur cables make a difference if ur using a SD TV use regular cables if HDTV use hd cables only on hdtv if use on SDtv it won't display or ur ps3 is set to an hd setting like 1080p it won't display on a sdtv so reset ur ps3 by holdin power button hope this help u
Jul 16, 2009 | Sony Playstation 3 (PS3) Console
My ps3 works with a hdmi cable but it will not display to any tv.
hold your finger on the restart button(the button next to disc eject button) for 5 sec to reset the settings
Jun 05, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont turn on
is it plugged in and switched on at mains, is the cable fully fixed in to back of ps3 and socket? is the fuse in the plug ok? (might sound like a stupid question but you wouldnt realize how many people dont check
Mar 14, 2009 | Sony Playstation 3 (PS3) Console
PS3 no longer works
are you able to see the cable/sat...or dvd? if so the input your ps3 is on may be bad try another input on back of tv..if this does not work you may have to call sony
Feb 23, 2009 | Sony Playstation 3 (PS3) Console
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
PS3 starts but wont turn on
you could have a problem with your power cord which is causing your ps3 to short before the system can power on fully. try using a different power cord or check the ports of both the outlet and the ps3 to make sure there is nothing blocking anything. also, try using a different outlet.
Oct 14, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
366 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
