Question about Maytag Neptune FAV6800AW Top Load Washer
Lr code went into service mode but wont respond to commands model #fav6800aww
  • 526 Answers
Tom,
The LR error code can be a tough one to troubleshoot but I'll see what if any help I can be.
The LR code stands for Locked Rotor.
If you Power Cycle the 120VAC to the machine will the error code clear?
What cycle was the machine in when you took the error code wash, spin?
If you remove the front panel and with the 120VAC power cord removed from the service outlet can you rotate the Clutch Pulley CCW (Spin direction) or CW (wash/agitate) direction.
Sounds like you have the FAV6800A/FAV9800A Service Manual.
Let’s see if the drive system is free and not locked up…………Rich
Posted on Jul 30, 2010
I Have A Neptune Washer Model FAV6800AWW Have error code of LR Lock rotor? what is bad? control board ot motor or both?
Motor for the most part is bullet proof has a 10 yr warranty
I would start with front panel removal and see if you can rotate the Clutch Pulley CW the Wash/agitate direction and CCW the Spin direction. Make sure nothing is seized.
It could be an issue with the Control Board or the Motor Controller. I have working spares for all and that makes troubleshooting easier.
If you decide to troubleshoot further and try a Control Board swap (in the console) or a Motor Controller swap I would buy parts from a supplier that will allow you to return the part for refund with no questions asked.
Google this ""Neptune TL Washer FAV6800AWW"" a forum where I help owners of the FAV6800A and FAV9800A machines.
This is a sticky on a DIY forum at the 5th post down you can link to the FAV6800A/FAV9800A Service Manual. You can post in that forum in the Maytag washer forum for additional help. You will find a link to parts supplier.
I link you to a post on this forum where I was working with an owner who was troubleshooting issues and started throwing a LR error code. He ended up replacing both the Motor Control Board, my 1st suggestion and that did not resolve the issue. A Control Board swap in the Console resolved the issue. Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin ... I won't troubleshoot any further on this forum it's just difficult for me. Can't edit, search post and sometimes pics don't attach. There are better DIY forums out there for working on the FAV6800A/FAV9800A......just mu opinion.
Your machine more than likely is ready for an Tub Seal replacement.....Google this FAV6800A/FAV9800A Outer Tub bearing replacement Another forum I help owners with FAV6800A/FAV9800A machine issues........good luck.
Sep 06, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Yes I just want to know I it's worth fixing this prob. I have a maytag Neptune tl washer model fav6800aww it's starts fine but after 3 minutes it stops on wash cycle an after 5 minutes Lr shows on...
Lr error code is locked rotor. Could be a couple different issues.
Google this phrase and read thru the post ""[FIXED] Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin""
Post in that forum if you want to DIY I do not offer DIY help here any more.
Jul 12, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Fav6800aww machine wont stay balanced move the clothes around it starts back up for about one minute then stops code comes up dc thanks earl
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
In that Sticky I discuss what is the cause of DC or UC unbalance errors and the fix.
Apr 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I keep getting error code dc and it wont spin
Somewhere on this forum I have a response to DC or UC unbalance errors and the fix. It's hard to find my past post on this forum.
This is a DIY Appliance repair forum and you can get the Service Manual and repair support posted in the sticky at that site.
Apr 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl what is code Lr
LR is the error code for Locked Rotor.
This could be an issue with the Motor Controller or Control Board.
I have not seen Drive Motor cause this issue to date.
If you want to investigate further I would suggest getting the FAV6800A/FAV9800A Service Manual.
This is a sticky for the FAV6800A/FAV9800A washer DIY support. Go to the 5th post down in the Sticky and you will find a link for the Service Manual.
If you want to go further in troubleshooting and possibly a DIY fix just open a new thread in that DIY forum with Model number and Serial number. That info is found tag behind the console right back side as you face the machine console.
Feb 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I don't know the model code
Hello
You are a technician and you whats to know the model service code I thinks, and posts this solution.
Use the Remote Commander (RM-Y183, RM-Y184) to perform the circuit adjustments in this section
SETTING THE SERVICE ADJUSTMENT
MODE
1. Standby mode (Power off).
2. Press the following buttons on the remote commander within one
second of each other:
DISPLAY Channel 5 Sound Volume + Power
READING THE MEMORY
1. Enter into service mode.
2. Press 0 on the remote commander.
3. Press ENTER to read memory.
ADJUSTING THE PICTURE
2. Press 2 or 5 on the remote to select the device item.
3. Press 1 or 4 on the remote to select an item.
4. Press 3 or 6 on the remote to change the data.
RESETTING THE DATA
Note: Be careful when using the remote! It will clear and re-initialize
ALL NVM data including defl ection adjustment data if not reset
properly as follows:
5. Press MUTING then ENTER to write into memory.
RESETTING THE DEFLECTION NVM DATA
2. Press 7 , then MENU, and then press ENTER on the remote.
RESETTING THE SYSTEM NVM DATA
2. Press 7 , then 9 , and then press ENTER on the remote.
2. Press 8 and then press ENTER on the remote.
MEMORY WRITE CONFIRMATION
METHOD
1. After adjustment, pull out the plug from the AC outlet, then replace the
plug in the AC outlet again.
2. Turn the power switch ON and set to Service Mode.
3. Call the adjusted items again to confi rm they were adjusted.
Ok.
Nov 30, 2010 | Sony KV-32XBR250 TV
Went on trip, drove a little over 500 miles to destination. When went from one freeway to another car seemed to go into a limp mode after slowing to bout 20- 25 mph. I reset by putting it in park turning...
PO456 is most times a gas cap or gasket,
to get an incorrect gear ratio the transmission has probably started to slip.
Change the fluid and filter first off in the transmission and use only atf+4 fluid and possibly the govenor pressure sensor,and change gas cap.
Jun 02, 2010 | 2003 Dodge Intrepid
Maytag washer top load neptune
See this post for troubleshooting the Lr error code. . http://www.fixya.com/support/t2419091-maytag_neptune_top_load_fav6800aww_tub
Lr is locked rotor. My first thought was that this could be a Motor Controller issue. This owner replaced tried that and it did not resolve the issue. He then replaced the main Control Board and that fixed his machine. Without known good parts (Control Board Motor Controller) this might be difficult for a DIY fix.
The Service Manual for reference. Sears Parts Direct for reference.
If you are going to try to DIY the repair I will see if I can help……Rich
Apr 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl fav6800aww wont dispense fabric softner
Test mode? Do you mean Service Mode and you turn on the solenoid for the water valve to divert water to the Fabric dispenser reservoir and it is flushed in Service Mode?
See if this solution will help with your trouble shooting.
Let me know if I can help……Rich
Apr 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
493 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
