Question about Zebra Z4M Printer
Print quality Ive had the printer for 4 years with no issues. There are no lines on the print, so I didnt suspect print head issues, however the edges of the text, especially large test that i print is now very very rough to the point that it looks really bad. The very fine small print is sketchy (ie a line will appear as dots or parts of a letter will be missed, but not all the parts in one row or pass. again, it may be a head issue, but when I read up on what happens when the heads go, it doesnt describe the problem this way. any help would be greatly appreciated thanks
  • drgazsi Apr 25, 2008
    Umm Yes. That was the first thing I tried. They get cleaned about once a month. Tried changing the heat, pressure, slowing the print rate down, looked for bindings in the mechanism, changed the fonts, reset the settings, etc.
    Genius:
  • 3,587 Answers
You cleaned those heads lately?
Posted on Apr 24, 2008
My brother MFC 665CW printer shows a 4F error and unable to clean. How do I get to the head to clean it?
Do the following to clean the print head:
1. Press INK key on the control panel.
2. Press the DOWN arrow key until CLEANING appears on the LCD.
3. Press OK.
4. Press the DOWN arrow key to select BLACK, COLOR or ALL depending on what you want to clean.
5. Press OK.
The machine will clean the print head. When cleaning is finished, the machine will go back to Ready automatically. If you are experiencing a print quality issue, we recommend you repeat the print head cleaning for each color showing an issue at least five (4) times.
If you are experiencing a print quality issue and want to see if the cleanings are improving the print quality, print a Print Quality Check Sheet (PQCS) after the first cleaning and then print another PQCS after repeating the print head cleaning steps at least three (3) more times (4 total cleanings). You can then compare the two Print Quality Check Sheets.
Do the following to print a Print Quality Check Sheet:
1. Press INK key on the control panel. TEST PRINT will appear on the LCD.
2. Press OK. PRINT QUALITY will appear on the LCD.
3. Press OK.
4. Press COLOR START.
NOTE: The machine will generate the Print Quality Check Sheet (PQCS). On the PQCS each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear (from left to right): Black - Yellow - Cyan - Magenta. Cyan is the light blue color and Magenta is the pinkish color.
Feb 21, 2011 | Brother MFC-665CW All-In-One InkJet...
Ive just installed new ink cartridges in my epson stylus nx 115 printer and the print is irregular. It worked fine with the oldink. How do I get itto print properly.
align the heads in the control panel/ printer page for maintaining print cartridges.
You see, everytime you change ink cartridges you must realign them using a printed page that has lines on it, that has numbers that you choose that determines where the edges of the paper is and also helps to calibrate where each color goes relative to each other.
Well, to make a long story short, it's all about lining up different heads with each other.
Jun 26, 2010 | Office Equipment & Supplies
It only prints light color ive replaced branw new
You need a new print head. Don't buy one, though. Phone Kodak (India) and get a new head. Or throw the stupid machine away. Kodak should be sued for producing such poor quality ****.
Jun 30, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Thin black lines on some of the photos I print on my 8150 photo p
align the ink cartridges and clean the heads. change your printer settings when printing photos to more dry time, less ink and quality to normal
Apr 26, 2009 | HP Photosmart 8150 InkJet Printer
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
Lines on pics
Could be either or Both.
1:) Clean the print heads, using the printer toolbox et,c.
2:) Check the head alignment.
3:) check the printer rollers are in good condition.
4:) check the printers general settings, to ensure the settings are correct. paper type. print quality ( Draft-Text-Photo et,c )
Mike @ Compurepair.
Jun 22, 2008 | HP PhotoSmart 7760 InkJet Printer
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Print quality is poor
if you replace the black ink cart with an original one then it's the print head
Solution: Cleaning the Print Head - C555 / C560 / C635 / C530 / C545
Untitled Document Follow this procedure to clean the BJ cartridge print head:
1. Press c755funckey.gif 2. Press c755cleankey.gif 3. Use c755down.gif or c755up.gif to select the [HEAD CLEANING]..
4. Press c755set.gif.
The MultiPASS cleans the print head.
Feb 12, 2008 | Cannon MULTIPASS C530 Printer
Lines along edge of paper
1 of 3 things I can think of off top of my head.
Since they are straight, I would suspect the transfer unit.
If it were just one color it would be that imaging unit.
Unlikely the fuser.
It doesn't sound line an issue called bar coding ,where the machine prints random lines. That would be a software issue.
Take the transfer unit out and inspect it for the marks.
I am assuming the streaks are on all colors correct?
If it isn't on the transfer belt, and on all colors check the fuser and see if its latched.
Jan 16, 2008 | Xerox Phaser 7400DN Laser Printer
Zebra Z4M Printer Logo
103 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
