Question about Maytag MSD2656G Side by Side Refrigerator
Water leaking out of water filter connector Maytag MSD2657HEB
The water line in my fridge at my lake cottage froze when the temperature in the cottage got too low. I presume it cracked the connector, but I don't know how to release the water lines to get it out to replace it. I would also need the Part #. Any help would be appreciated. Thank You, Denny
  • Sailor Denny Apr 25, 2008
    Thank You! I looked at all the diagrams, but didn't see the water filter like mine. It is the one in the upper right hand corner. I have it loose but don't know how to release the tubes running into it. Denny
  • 487 Answers
HERE you will find all your answers as to parts etc follow the drawings and you know how to take it apart. Site takes a little to load
Posted on Apr 24, 2008
My fridge just started running water from under,not just a Lil drip,I even have to shut the main water line off....what do I do now?.
My refrigerator did this when the fridge temperature control door got stuck open and froze everything in the refrigerator. I tracked down the problem to a connection in my water supply filter. I just removed the filter and spliced the line. I doubt the same thing happened to you but you can probably find the leak by tracing the water supply to the ice maker/water dispenser.
Feb 21, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
We just had a new RO Unit installed at our sink, and a line run to our Maytag fridge. The water filter is inside, at the top. We don't really need the filter anymore, as the RO water is more tha
Take the filter to the hardware store and get the necessary fittings (and maybe a short piece of tubing) to connect the in and out lines without the filter. Perhaps easier deal is a new filter which should NEVER become clogged on RO water.
Aug 02, 2017 | Maytag MSD2734GE Side by Side Refrigerator
No water to the ice maker
filter cracked because it froze . changing the filter is not enough change the housing . as the lines are frozen and wll brake . mm
Apr 18, 2010 | Frigidaire FRS26H5AS Side by Side...
Water leak after winter at the cottage
Why did they didn't respect the creation of Jesus christ ?
Apr 14, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerator leaking water
This sounds like the water line from the icemaker and the cool water reservior inside the refridgerator side. The line is a rigid plastic hose and could be a leak at one point that is small enough to allow water to run along the line. Also sounds like you have a humidity problem. Check the door seals and wipe them off and apply a thin coat of die-electric grease to the seal. this will help keep it pliable and soft.
The water in the bottom leaks into a trough that is made into the fridge. This usaully evaporates, This is for the auto-defrost. It keeps the water from getting on the floor.
Check to see if the outer door gets hot at the edges. If not, It may not be auto-defrosting.
I would first check the water line first as this seems to be a more serious issue right now. The line is probably loose at one of the connections between the ice maker and water reservior.
Jun 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Maytag MSD2456GEB fridge leaks from the first set of solenoids
It's the conection to the valve, thats you'r problem. onece the line come out of the conection, it's next to imposable to put it back in. fact-seals brock. never realy seals back around the hose. I had the same problem only at the base of the door. eazier to fix then where you'r is. I had to replace the nuckle. you have to change the valve. it's the only way to stop that leak. hope this helps
Mar 20, 2009 | Refrigerators
Water leak at filter
I had this with a Kitchenaid Superba and wanted to get rid of the filter holder assembly entirely as I have an undersink unit which serves the fridge. I removed the plastic line (nut) at the back of the fridge (which led to the filter holder at the front) where the flexible copper tubing inserted (this was a 3/8' compression fitting-plastic) and also the returning line (1/4" copper compression nut on a plastic line) at the manifold (again in the back of the fridge) where it gets split between the water line and the ice line. I then just connected the 1/4" flexible copper directly to the manifold (1/4" nut, compression sleeve, male-male connector) using a pre-made 1/4" flexible compression line. Sounds complicated but after seeing how the water routes it was fairly quick work.
Dec 02, 2008 | Whirlpool GS6NBEXR Side by Side...
Water filter in fridge leaks
if the filter froze, its probably cracked the housing.
Jun 05, 2008 | Maytag MZD2766GES Side by Side...
Fridge is leaking
Your plastic line which carries water to the dispenser has a crack in it.  Activate the dispenser and have another person pinpoint the lead and splice two pieces together with plastic connector.
Oct 15, 2007 | Amana ACD2232HR Side by Side Refrigerator
FILTER CUP&HS CRACKED,WATER LINE FREEZE
are you setting the stat right? lower the number, higher the temp. lots of folks think its the other way round. set stat to 2 or 3 and should be about the right temp
Jun 21, 2007 | Frigidaire FRS26KR4A Side by Side...
Maytag MSD2656G Side by Side Refrigerator Logo
89 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
