Question about Olympus VN-480 PC Digital Voice Recorder
Cant down load audio form device to PC
The program doesn see the recorder. Cant transfer
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Device manager and update driver
Posted on Aug 20, 2008
How to transfer audio files from Memorex Digital Voice IC Recorder
Probably you could vist the manufactorers web site and download a user manual there. http://www.memorex.com/en-us/support/
Dec 07, 2012 | Memorex MB2059B Voice Recorder
Tip
How to record Guitar sound on a computer
<p>Line-in <br /> <p>1. Buy a software package for recording music, if your budget allows. Recording music software is specifically designed for recording musical instruments formed. He cannot offer features found in common software audio. Alternatively, an audio recording program for free to get the music recording software than your needs and budget. <br /> <p><br /> <p>2. Buying a guitar cable to your computer if you use an electric guitar. Connect the larger end of your guitar amplifier and the small end into the computer microphone / line-in. <br /> <p><br /> <p>3. For an external microphone when a traditional guitar. Plug the microphone into the computer microphone / line-in. A stereo microphone is a natural sounding audio file, due to the dual microphones. <br /> <p><br /> <p>4. Open your audio recording program, which recognizes the device connected to ensure the microphone / line-in. Pull the cord, again if it does not recognize the device. Change the settings for the recording program to your needs to adapt, you can file type for quality change, and the recording is mono or stereo and audio level. Press the Record button, then started playing guitar. <br /> <p><br /> <p>5. Press the "Stop" button when you finish the game. Some programs can automatically be prompted to save the file; others may be the audio file first. Press "control" and saving "S", if not prompted. <br /> <p><br /> <p>Digital recorder <br /> <p>1. Buy a stand-alone digital recorder, if you do not want a guitar cable or an external microphone. A stand-alone digital recorder is small enough to fit in your pocket and can be placed anywhere without the need hampered by a cable. <br /> <p><br /> <p>2. Set the digital recorder on a flat surface. Press the record button. <br /> <p><br /> <p>3. Press the digital recorder, "Stop" when finished. Connect the recorder to the computer with data cable. Open the device by clicking on "Start" then "Computer" and double click on the recorder in the "Removable Devices". Copy the file from the recorder to your computer. Turn off the burner when you are ready to save battery power.<br />
on Jun 21, 2011 | Computers & Internet
I can't find the drivers for my Olympus Digital voice recorder VN-2000PC. What can I do? I can't tranfers my audio files to my PC.
Do you need the software/drivers for the VN-2000PC or the VN-2100PC? The software for the VN-2100PC is available here: http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1270 . Select your OS and you'll find the software.
The VN-2000PC doesn't connect to the computer via a USB port. To transfer your files to a computer, connect the earphone jack to the line In (blue) jack of the computer with a 3.5mm to 3.5 mm audio patch cable. Use a program like Audacity to record the audio track during playback. Make sure to set the Audio input to Line In. (In Windows 7, click Start > Control Panel > Hardware and Sound. Under Sound, click Manage Audio Devices. Then select the Recording tab and set the input device.) Then set the recording device in the software as well. Click the Record button in the software and then start the play back on your VN-2000PC. You should see a flat line for a bit then see a wave form start. If the line stays flat, you haven't set the Line In device properly.
I hope this helps.
Sep 01, 2012 | Olympus VN-2100PC Digital Voice Recorder
How transfer music to nook
First in the OS make sure that recording device is USB (Start > Setting > Control Panel > Sounds and Audio > Audio). Adjust the audio recording volume, as well (Start > Programs > Accessories > Entertainment > Volume Control > Options> Properties. Click on Adjust Volume For Recording, for some versions of Windows). Unfortunately you can't directly listen to the recording on USB in this software. You would need a regular turntable with amplifier and then RCA L/R audio to 3.5 mm audio adapters. Connect this to the Line In of the computer (blue port) on the sound card. Then set the recording device to Line In and unmute Line-In in a similar way as above.
Now try recording in Cakewalk Pyro. (I recommend making a short recording and then playing it back to check the settings.) Try the Windows Sound Recorder (similar to finding the audio recording volume) to record if Pyro doesn't work. You may have a problem with the USB turntable or your USB port. You should see a waveform if the software is recording anything. Adjust the audio so that the entire waveform is consistently less than 100% of the maximum. A flat line in the center of the audio trace is a sign that there is no incoming audio signal. I usually start the software recording and then start the turntable at the correct track. Thus a flat line for a few (~10 seconds on my system) is normal.
After recording, you need to export the file or files as MP3s. (I subdivide a longer recording into tracks but that can be a pain. Identifying the "break points" is not always obvious.) Then File > Export (iirc). Select the MP3 option and the quality. I put all my music into the myusername/music/recordings subfolder (I created the folder) to make them easier to find again.
Connect the USB cable from the Nook to the computer. Access the Nook from the File Explorer. (Double-click on the Computer (My Computer) icon with Windows, it's the Devices icon on a Mac.) Then double-click on the Nook's icon (there may be more than one).
Open a second explorer window to the directory where you saved the MP3s. Then just drag and drop the files/folders to the Nook. If you put the files onto the internal memory of the Nook, make sure to put them in the My Music or My Audiobooks folders. (You can do transfer the files to the memory card without plugging in the USB cable, if you have a card reader. Just be careful not to lock the read/write switch on the card and do not reformat it.)
I've used several programs and found Audacity (free) to be just as good and straight-forward to use. However, the programs all work the same way. If the USB device isn't working (or the default recording device), you get nothing.
I hope this helps.
(I will note that most of my recordings were done from cassettes using Line-in from the headphone jack. Thus I only had to diagnose problems with the patch cable and the default recording device once I checked that my headphones worked for the tape. I saved my recordings as WAV and then burned them to CD as Disc At Once for a player that didn't read MP3s.)
Jun 22, 2012 | Cakewalk pyro 5 Full Version for PC
Cant fand my macrophon an my computer
The internal microphone is located near the top of the notebook LCD display or near the bottom of the LCD display near the hinge. Use the following best practices to capture sound more easily.
Follow the steps below to verify that the recording program on the computer works properly.
  1. Click Start , enter sound in the search field and select Sound Recorder from the list.
  2. Click Record and speak into the microphone. Save the file to an easily-accessible location, such as the desktop.
  3. To play back the recorded sound, open the file using Windows Media Player.
To record sound the internal microphone should be the default recording device.
1. Click Start , enter device into the search field, and then select Device Manager from the list.
2. Expand the Sound, video and game controllers list.
3. Right-click the audio driver , select Uninstall from the drop-down menu, and then click OK to confirm that you want to uninstall the audio driver.
4. After the audio driver is uninstalled, click Start , enter backup into the search field, and then select HP Backup and Recovery Manager from the list.
5. Follow the on-screen instructions to reinstall the audio driver.
The internal microphone is now set as the default recording device.
May 27, 2010 | HP Pavilion dv6000z Notebook
How do I transfer recorded programs from my 622 DVR to my home computer?
http://www.dishnetwork.com/downloads/user-guides/receivers/622_UserGuide.pdf
User guide. above.
You would have to connect up, using a PC & DVR software and some form of TV/Video recording Card, or USB device. Then connect up via AV, Composite, Yellow, Video. White & Red Audio. and "Capture" either live video & Audio, so basically whatever was viewed on the screen, would be "Recorded" on the PC, via the TV/Video interface device, if using a laptop, then a USB "Dongle" & software would be the best. In a Desktop, a PCI-I card would be Best, Then using the Software that comes with the devices, you "Record" with that and "Play" with the Dish DVR, and save, the Streamed Video & Audio to the PC. Now, If you have Component Out, on the Dish, then this is the one to use, If you choose this way, remember the Device you are going to use Must have a Component INPUT as well, as A Stereo Audio Input, so ensure the device you get has that feature.
Mar 30, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Sound
From the manual:
"To hear audio, transfer the video to your computer."
The camera doesn't play the audio, though it records it. You need to transfer the video to a computer in order to hear it.
Jun 07, 2009 | Kodak EasyShare C913 Digital Camera
CANNOT TRANSFER AUDIO FILES FROM WS-100 OLYMPUS VOICE RECORDER TO PC (Windows XP)
I wrote this for the Olympus VN-3100PC although it may work with this device as well.
Try this:
This problem can typically be solved by unplugging the device from your computer's USB port and plugging it in to another USB port on the same computer.
Also be sure you have Olympus Digital Wave Player installed and open with your Transfer Options set to Auto Transfer. To do this, follow the steps below:
Open Digital Wave Player > select Transfer from the menu > select Transfer Options > under Auto Transfer, check the box which reads "Transfer all audio files after detecting Recorder."
Mar 04, 2009 | Olympus WS-100 Digital Voice Recorder
How to down load tape to pc
i have uploaded the driver here:
http://rapidshare.com/files/151262301/Driver.rar.html
un rar and install it on the computer.
when you are done installing the driver proceed with the movie transfer as follows:
1- conect the camera to computer
2- open moviemaker program
3- choose option - capture from video device
4- You will have a choice of devices depending what else ic connected - choose panasonic dv
1e8e85b.jpg 5 -at the selection screen choose - best quality for playback on my computer
b369d7e.jpg 6 - start recording
Sep 14, 2008 | Panasonic NV-DS65 Mini DV Digital...
Transfering music from the H4 handy recorder to the pc.
Make the instalation of cubase LE that come when you buying the Zoom H4.When you instaled this,the driver H4 must appear in the sound/device properties.I hope you can solve
FF
Apr 06, 2008 | Zoom H4 Handy Recorder
Olympus VN-480 PC Digital Voice Recorder Logo
99 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
