Question about HP LaserJet 1320 Printer
Prints one page double sided, then goes to error light and stops printing
  • 268 Answers
What is the error ?
does it says Paper jam, Open the print cover and remove paper jam..
If this the error repeating then make sure,
1. u r not overfilling the paper tray
2. put the printer on a hard surface (not on a half out surface)
3. from now on be gentle with the paper tray.
4. unplug the printer everytime u r done or atleast overnight.
thanks
Posted on Jul 30, 2010
Double sided printing
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 14, 2012 | HP Photosmart Plus All In One Printer b210
How to duplex print with 895cxi
This model printer does not have a duplex unit and cannot print double sided documents automatically.
Jul 08, 2012 | HP DeskJet 895cxi InkJet Printer
HP D7260 will not print two sided
This model printer does not have a duplex unit and therefore cannot print double sided printing automatically.
Jun 13, 2012 | HP Photosmart D7260 Printer
When I want double sided printing with samsung ml2010 printer, the online error stay red after one side is printed. Then i can do nothing but turn off the power button. it goes well when one sided...
I solved it!! Just hold down the Cancel button and I think it acts as the OK button. The red light will go away and turn green and it will print the odd pages. There you go!
Dec 18, 2010 | Samsung ML 2010 Laser Printer
How can I do double-sided printing with my Canon MP460?
Hi there!You printer does not have an automatic duplex(double-sided printing)so you have to make a manual double-sided printing.When you start to print something , in the widow of the printer click on the preferences and look for the option "Print on both sides" or "Manual double-sided printing".When you start the printing the printer will print page page 1,3,5,7..... on the one side of the paper.After the printer finish you have to take the papers and put them back in the printer with the other side of the paper.Then the printer will start print page2,4,6,8,.....If you need any other help please replay!Tghaky for using Fixya!!
Dec 18, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
In this printer u dont have duplex print mode,u can use only manully.
Oct 10, 2008 | Canon PIXMA iP3500 Printer
Double sided printing Pixma MP520
here's how:
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Sep 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
HP LaserJet 1320 Printer Logo
134 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
