Question about Beverage-Air MT27 Beverage Cooler Commercial
I have to turn the thermostat dial to 9 before the AC compressor kicks on. them Moments later it shuts off, temp remains the same ( doesn't go down ) After a few moments it turns back on automatically only to shut off in a couple of minutes again. what to do?
    Genius:
  • 1,075 Answers
Sounds as if you have a perfict working unit,its doing what it says on the tin.adrian,,,,
Posted on Jul 30, 2010
Maytag m6x06f2a like new but doest blow cold air
Make sure the Thermostat is set correctly! The problem with mine was the temp in the house was colder than my A/C lowest thermostat setting.I had my AC temp setting on 66 degrees.The temp in the house was a little lower so the AC didnt kick on just the fan blowing cool air and no compressor working. The next day it was warmer out and the house temp was 79. So when I powered up the AC set at 66 i heard the compressor kick in and the AC worked fine.
Aug 27, 2013 | Maytag M6X06F2A Air Conditioner
Will not stop running
Are you referring to the compressor not shutting off down below or the evaporator fan inside the cooling area not shutting off? Evaporator fan always runs the compressor is controlled by the thermostat you could have a bad thermostat if the compressor never shuts off.
Mar 13, 2013 | True GDM-7 Beverage Cooler
Dometic roof top AC unit compressor turns on even if T-stat is off. Only way to get the compressor from turning on is to turn the breaker off. Unhooked T-stat wires to see if issue was there but the...
Sounds like you may have a couple of problems there. First, have you checked incoming voltage to make sure you are getting 100-120 VAC at the AC control board in ceiling? If that's ok, try removing/disconnecting Ac compressor wire at ceiling control box and see if compressor shuts off then. May be a capacitor for compressor going or shot, and possibly relay in control box sticking, or bad wiring to thermostat. Have you had any lightning in the area prior to all this happening?
Jan 23, 2013 | Dometic Rooftop RV Air Conditioner
Compressor will not kick off
My first guess would be that the thermostat got bumped in the move and is turned all the way down...
Get a thermometer in there and see what the actual temp. is...also check to see if it will shut off if the t-stat is turned up...
Worst case the t-stat went bad and it will not shut down on temp.
heatman101
Apr 16, 2010 | Amana 16.9 cu. ft. / 479 liter Upright...
AC ROOF TOP CYCLING EVERY 5 MINS
well most unite will go to 54 degrees but 43 that coooool man what complain about. the compressor dose shut down at certain temp so as not to turn into one hunk of ice. that what they are design to do.
Jul 06, 2009 | Dometic Rooftop RV Air Conditioner
Ac set at 74 room temp up to 78 and no Ac kicking on.
it could be the thermostat is loose on the subbase or if you went from OFF to COOL and the stat is a digital stat It will not come on for five min. This is a delay set by the manufacture to protect the compressor. during normal operation you will not notice because thier will be more than 5 min from the time it shuts of till it need to come back on but if the system switch is set to off and you switch to cool or unit just shut off it will always delay 5min. usualy there will be some insdiction on the screen that it is in delay like a flashing COOL or SNOW FLAKE or the word WAIT. the unit will not be running until the flashing words go solid
Jun 26, 2009 | Honeywell Programmable Thermostat Heater
If you set the temp to 74 it will not cool down to that temp the compressor will kick off on eather the energy or regular mode lg model number lwhd1009r
compressor shuts down air is cool but unit does not stay long enough to cool lower the thermostat down little lower if the compressor starts up then bad thermostat
May 19, 2009 | LG Heat cool Window Air Conditioner
HI: We have a 6-7 yr old TRUE single door, stainless steel fridge. We noticed yesterday ..that at "4" on the temp dial, the fridge is freezing milk in glass gallon jars. We backed the temp down to "2" and...
With the refrigerator, the fan inside the conditioned space should always run. This is normal for most all commercial refrigerators. Need to check to see if the unit is shutting off the compressor after the conditioned space reaches a good temp, usually 35 degrees. If not, probably a bad thermostat.
Apr 11, 2017 | True Food VWR Storage Refrigerators with...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Beverage-Air MT27 Beverage Cooler Commercial Logo
108 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
