Question about Roper RT21AKXKQ Top Freezer Refrigerator
My refrigerator don't start. i check for juice and there is juice in the plug what it can be the problem. thank you
  • Roper Master
  • 3,051 Answers
Hello there
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on. Second, . If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these: Wiring Thermostat Defrost timer Compressor Overload and/or relay
so if you can get each one of these checked out
Posted on Jul 30, 2010
93 lebaron died while running, now clicks when being jumped.
From what you describe, my guess is that eventually you will replace the starter
Apr 24, 2013 | 1993 Chrysler Lebaron
I have a 03 ford f150. yesteray i filled my flat tire with a portable compressor that plugs in my cigarete lighter now today my battery is dead. i got a jump drove around for a while. after i parked i
Hi Ed, Its always a good idea to run the engine while using any high demand accessory. You may like to have your battery and charge rate checked, but I believe just running the engine will solve the problem for you. Connect everything first, start the engine and then turn on the pump. Regards John
Oct 13, 2012 | Ford F-150 Cars & Trucks
My 1999 Kia Sportage won't start. I checked the fuel pump while the key is on the ignition and I get the impression that it is not getting any juice. Fuel pump fuse is OK. Both cam and crank se
Well for starters, you need to diagnose the problem before replacing anymore parts. I say this because you mention both the fuel pump and sensors dealing with the ignition system which are 2 separate main things. Basically it takes 2 things to make an engine start, fuel and spark at the spark plugs. You need to narrow down what is missing because it seems since you replaced sensors dealing with spark and then you mention the other need fuel. I'm not sure as to where to start to help until whatever is missing is diagnosed and then find the cause of the loss. There are a couple of things you can check. Below is a picture of the relay box in the engine compartment. With the help of somebody put a finger touching both the fuel pump relay and the EGI main relay. While touching them have somebody turn the key to the "on" position (no need to try and start). When the key is turned on you should feel a "click" inside both of those relays. The fuel pump relay will click for about 3 seconds and the click again to shut off. The EGI main relay should stay on. If both seem to be fine you need to make sure of the fuel pump gettting "juice" and for power to the ignition system like the coils. You can get to the power/juice wire at the fuel pump pretty easy. You can access the connection at the fuel pump by lifting the lower part of the rear seat. Once the seat is lifted you should be able to see a part in the carpet that is cut to be able to lift the carpet up and access the plate covering the access to the fuel pump and/or the top of the fuel tank. Using a test light, check the green and yellow wires at the fuel pump. You should have power at those wire when turn the engine over or if the key is just turned to the on position you should have power there for about 3 seconds. To begin checking for spark or power to the ignition system you need to make sure you are getting power to the ignition coils. The red and white wires at the coils are your power wires. Check those. Also you can check the power at the fuel injectors. When the key is turned on or when trying to start, you should have power to the green wire at each of the fuel injectors. You should have constant power/juice at each of the fuel injectors. This is where I would start to narrow down the loss. Start here with these tests and let me know how the tests come out by replying/commenting here or you can email me directly at csautomotivecars@att.net ith what you have found out. Once the first tests are done and I know what the results are, we can go to the next step with a couple of other tests to figue the problem out. If one of the relays don't "click" then you have a possible bad relay. The EGI main relay is a common thing to go as well as the fuel pump relay. Don't mind helping and there is no cost to you for it but I don't want to tell you to start replacing parts until the problem is located. Hope this helps get you started.
Apr 23, 2012 | 1999 Kia Sportage
No juice on spak plugs
short in the battery or a ground loose check main ground on battery
Jul 05, 2009 | 2000 Harley Davidson FXST Softail Standard
Viking Professional VWH4848 fan hood not working
Have you tested with a VOM to see if there is juice at the plug in question? If not, trace it back to the control/switch area and test there... Careful!
Mar 16, 2009 | Viking VCSF036SS 36" Professional Free...
Fridge freezes contents
Check the door seal is not split,it may be letting air into the compartment
Nov 12, 2008 | Candy CPCA240FFK Bottom Freezer...
Roper RT21AKXKQ Top Freezer Refrigerator Logo
176 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
