FixYa.com
Tags:
Denon DRM-740 Single Dual Cassette Deck
Denon DRM-740 Design Problem??
By Bray - usenet poster
Just got the Denon back from the shop and the tech says that it's the
2nd 740 he's seen that clips at record levels above +3db. Says it's a
design problem that has something to do with the muting transistors, and
that Denon knows about it and aren't addressing.
Anyone have any info on this??
......Douger
"The 'hound broke down left us all stranded in downtown Birmingham"
 douger.bou @unix.asb.com - remove .bounce to email
       http://bertha.wwimpact.com/gdt apelists
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 10, 2005
Helpful (85)
lawyer
lawyer - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Why do you want to be above +3 anyway?  Don't all decks "clip" as you say,
or distort at levels more or less just above +3?
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
: Just got the Denon back from the shop and the tech says that it's the
: 2nd 740 he's seen that clips at record levels above +3db. Says it's a
: design problem that has something to do with the muting transistors, and
: that Denon knows about it and aren't addressing.
i have no technical info on this, but i do have a drm 740 that i have
used extensively for recording onto metal and have seen nary a clip at
levels of +5 and beyond.
i would be curious to know what you are using to generate the signal for
input to the deck.  you can generate a clip problem if your input gain is
to high.
r.
                                             ric @netcom.com
Solution #3
Not Rated (0)
Jimmy NY
Jimmy NY - usenet poster
Rating: 0%, 0 votes
No deck should ever clip. I'm told that the tape is the weak link in the
recording process. Metal tapes for example, are generally rated for +5db
recording. A deck can put out a tremendously larger signal than any tape
could handle. A clean signal should appear across the record head, even
as the levels are maxed out, but the tape just can't store that much
energy. Remember, the tape itself is a passive device, as opposed to the
deck which is an active device.
I never noticed a problem with the deck, but my tech uses the standard
sine wave to test the signal path and showed me on the scope how it
starts to clip at +3db. It's not a problem for recording on XLIIS tapes,
which is why Denon has been turning a deaf ear. And for me, no big deal
as the 740 is about to be demoted to play deck status anyways. Signals
played are perfectly reproduced, even over +3db.
I'm just curious if anyone else has ever heard of this. And any experts
are encouraged to chime in with corrections/comments/adjustmen­ts to any
technical info I've posted here. Hey, it's nice to be pushing 40 and be
really green at something :)
......Douger
"If I had a gun, for every ace I've drawn"
Can you Help with these Tape Decks problems?
Tape Decks
Sony SB 300: Instructions...
Looking for instructions /... Answer This...
Tape Decks
Pioneer DVD Cassette Deck...
My Pioneer DVD Cassette Deck... Answer This...
Tape Decks
scsi port
I have a akai dps16 and a teac... Answer This...
Tape Decks
adat
i am not able to record to my... Answer This...
Repair Service
Find Tape Deck Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
