I have a Motorola WR850G i am looking to open my nat type for my ps3 system i also have a DSL Verizon cable modem which i have open the nat type for that now I'm trying to figure out how to open my nat type for the Motorola router i play this game called call of duty modern warfare 2 and even though i have enable my nat type when i log onto the game i still get Nat Type:Moderate which i am trying to figure out how to have my Nat Type:Open so i can join any room's without a restriction
  • 532 Answers
If your using a router, you have to ENABLE the UPnp within your router settings. Once enabled your NAT should be OPEN.
If you do not know how to get into your router, you will need to ask someone you trust to do this.
Posted on Jul 30, 2010
Reset password
The Motorola WR850G is a wireless router that attaches to a cable or DSL modem. The WR850G has two reset options.
Users can reset the router and retain the settings or reset it back to factory specifications to clear all settings.
Resetting the router can help with network issues such as dropped connections.
It can also resolve situations where the user has made changes to the router's settings and can no longer connect to the router.
Look at the back of the Motorola WR850G router and locate the reset button. It is a red button located to the left of the Ethernet ports.
Press the reset button on the Motorola WR850G router, and release it immediately to reset the router without changing the settings.
Press the button on the Motorola WR850G router and hold it for longer than five seconds to reset the router to factory specifications.
This setting resets the router's IP address and subnet mask along with the user ID and password you use to log in to the router.
http://broadband.motorola.com/consumers/products/WR850g/downloads/WR850G_userguide.pdf
May 15, 2013 | Arris WR850G Router (DHWR850G)
Open my nat for ps3
You may need to change some settings on the router.
Also you may need to open the ports on the router for PS3.
If you are using DSL Internet service then make sure that modem is in Bridge or PPPoE mode.
Read How to change NAT type to open for gaming devices
Jun 23, 2012 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How do you bridge a modem ? i have a problem trying to change my nat 3 to nat 1. i have opened my router settings and reset my ps3 settings.i have been told that my problem can be fixed by bridging the...
Bridging the modem actually disables the dhcp server on your modem...
If you bridge the modem, then the dhcp will get disabled which in turn disables NAT on your modem...
If you contact your ISP they will help you to bridge the modem... because bridging varies according to the ISP...
Jan 23, 2011 | Arris High Speed DSL Modem
Change nat type
To reduce the NAT
1 ) Disable the firewall in the router
2) Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
Mar 31, 2010 | Arris WR850G Router (DHWR850G)
How do i open nat for modem
hi you can enabel the NAT on your zoom modem or motorola router from here
http://www.portforward.com/english/routers/port_forwarding/Zoom/X5/X5index.htm
just select the modem and router and then select the application and you are good to go.
Mar 30, 2009 | Zoom X5 5654 DSL Modem (DH5654)
PS3 NAT type problem using Zyxel P-660R-D1 series DSL Modem
thanks for help , the error was from user that have viruse on his pc , thanks again
Nov 11, 2008 | Zyxel P660HW-D1 Router
Motorola WR850G
Right off the top I can imagine that the laptop is smirking because it has a battery to get it through the power outage. What may be happening is that the desktop loses it's ip address or the router defaults back to DHCP rather than PPPoE which is where it belongs for DSL. 3 ways to fix this:
1) Reset the power on the DSL modem and wait a minute or two.
2) Go to Start>Run>type 'cmd', Enter, type 'ipconfig /release' then 'ipconfig /renew' then 'ipconfig /all' to see all of the ip addresses for each adaptor and gateway.
3) Go to Start>Run type 'http://192.168.10.1' and a logon window appears. User name is 'motorola', Password is 'admin'. A webpage appears showing you are now talking to your router. In the LAN tab choose PPPoE for automatic DSL control settings. You can also temporarily select DHCP to use the 'Release' and 'Renew' buttons here which is the same as the ipconfig commands you did at the Command Prompt in step 2 but reselect PPPoE before you leave the router control panel. You can also select STATIC if you already know your ip addresses but for DSL you normally use PPPoE. If you haven't done this before then peruse all of the other controls that you can access here. (If you are a gamer this is where you set up your DMZ and so on.
Have a nice day, Steve Medley
Aug 06, 2008 | Arris WR850G Router (DHWR850G)
Connecting to internet
i am connected and signal strength is strong but i still cannot get on the interned (time-warner cable)
"dsl server error"
Aug 06, 2008 | Arris Wireless G Broadband Router (wr850g)
Motorola router
Modem light goes RED if No external Ethernet device has been attached and detected OR The Ethernet link is down.
in your case it is going to be the DSL MODEM ....
Second cause could be The WAN interface has been disabled by the firmware.
TO enable it log on to your router's address http://192.168.10.1.
and look for WAN options.
http://broadband.custhelp.com/cgi-bin/broadband.cfg/php/enduser/std_adp.php?p_faqid=17058&p_sid=rTOCxT5j&p_lva=17178&p_accessibility=&p_redirect=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODAsODAmcF9wcm9kcz02MzAsNjQ0JnBfY2F0cz0mcF9wdj0yLjY0NCZwX2N2PSZwX3BhZ2U9MQ%2A%2A&p_li=
Thanks ,, please let me now it worked or not
Jun 09, 2008 | Arris WR850G Router (DHWR850G)
Computers & Internet Logo
648 people viewed this question
David Payne
David Payne
