Question about Whirlpool GEW9250 Electric Dryer
I have a duet electric dryer. It isn't getting hot air
I have a duet electric dryer. It is blowing out cool air out of the vent and is not heating up.
  • Whirlpool Master
  • 8,220 Answers
This video shows how to get into the machine. Your heater slides out and is easy to replace by removing the bottom panel. Looks like this:
Posted on Jul 30, 2010
My Whirlpool duet electric dryer seems to get too hot and stops working
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Oct 12, 2014 | Dryers
Whilpool duet gas dryer not heating
CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Aug 18, 2014 | Whirlpool Dryers
Lg dryer is overheating blowing the thermal fuse
you have an airflow problem. Check the vent hose all the way out and the outdoor vent hood.
a simple verification can be performed by disconnecting the vent hose from the dryer and see if this solves the problem.
Mar 03, 2014 | LG DLE5977 Electric Dryer
Whirlpool Duet dryer runs way too hot, even during air only cycle.
sounds like restricted air flow to me . check filter and the vent for plugged pipe
Apr 18, 2012 | Whirlpool WED9400S Electric Dryer
Dryer is only 5 yrs old. Started to blow cool air. Not heating. Vent was blocked from outside. Cleared vent, flab is open, but dryer still not blowing hot air. Is there a reset on this machine? Why...
There is a device in the circuitry for the heating element which shuts off power to the heating element when the dryer gets above a certain temperature which is ealsily reached with a clooged vent hose. This device, a thermal limit switch or thermal fuse, cannot be reset, it has to be replaced.
If you want to do this yourself, let me know -- if not, you will need to arrange for someone to repair the dryer. The device costs about $20 -- a service tech will probably charge up to $150 for the repair.
Charlie
Jul 26, 2011 | Kenmore 600 7965 Dryer
Will not get hot. just blows cold air. was wondering how many heating eliments are in the dryer?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 30, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The dryer is not fully drying clothes
Here are a few basic trouble shooting things to try to get you started. Is this a gas or electric dryer? I will assume electric. Check to make sure the heating element is heating up. You can do this by taking off the vent hose on back, putting the dryer on a hot dry cycle and feel the air coming out. You should have a very strong flow and after just a few minutes you should have hot air. If the air flow is weak, you need to clean the vent and lint tray with a flexible brush to clear any lint and debris from the air path. If the dryer is not blowing hot air it could be a thermostat, the heating element itself or even a bad circut breaker only allowing half of the 220 volt electric to work.
If you have a strong air flow, and hot air the next step is to hook the dryer up to the vent again, go outside and find where the dryer vent exits the home. At the vent exit if you have flaps covering the exit they should blow out fully when the dryer is running, and if there is no vent cover the air flow should be just as strang as it was at the back of the unit. If it is a weak flow you will need to clean or replace the vent from the dryer to outside the home. The most common cause of slow dry or incomplete drying is restricted air flow or the heater not working. Please let me know if any of this helped or fixed the problem. If not we can look into more possible solutions.
Mar 08, 2011 | Maytag Neptune MAH5500B Front Load Washer
Turns on & tumbles but no heat. top got really hot b4 it quit drying
You may have a clogged vent.your machine gets to hot and safety switch kicks in or you lost the blower fan
when drying does it sound like air is blowing.... let it cool down and see if it starts again
Dec 19, 2010 | Frigidaire Electric Dryer
My Whirpool Duet Gas Dryer is no longer heating up.
This is probally the coils. They tend to fail as the dryer heats. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the troubleshooting. It's a different model but the testing of the parts will be the same.
Mar 24, 2010 | Whirlpool LGR5636L Gas Dryer
Whirlpool GEW9250 Electric Dryer Logo
372 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
