Question about Lexmark X500n Color Laser All-in-One Printer
Paper Jams if I use a high gloss Laser printer paper. Looks like an accordian before the fuser.
  • 906 Answers
Good day Sir, If you are using high gloss laser printer paper I suggest load up to 25 sheets.
  • make sure the glossy or the printable side of paper faces you.
  • the paper is loaded against the right side of the paper support.
  • the paper guide rests against the left edge of the paper.
Note: photos require more drying time. Remove each photo as its exits, and allow it to dry to avoid smudging.
have a nice day, hope this will help you.
Posted on Jul 30, 2010
Brother Fuser Unit not feeding paper
It is possible the gloss stock is gumming up the printer.
Jan 08, 2014 | Brother HL4570CDW Printer
Replaced the belt and fuser on a oki c5200, now paper gets jammed and accordians in fuser
This will happen if the belt isn't properly settled, so that the sheet of paper enters at a slight angle and jams. The roller loader will then fold it into an accordion shape.
While I don't understand how the printer let you print (the sensor should have raised an alarm), you could try extracting the belt unit and re-settling it. Verify the blue retainers have been fully rotated (one eighth turn clockwise) and the handle is completely down.
Nov 06, 2009 | OKI C5200n Laser Printer
Samsung ML2552W printer: jams at fuser BUT paper feed motor froze
Samsung printer parts are difficult to source online, I'd try to either get one from an authorized service center or look into a replacement printer, the frozen motor may have shorted out some of the controller boards as well, increasing the overall cost of repair.
Oct 21, 2009 | Samsung ML-2552W Laser Printer
Brother 2820 constant paper jams
Most likely the fuser is worn out, and needs replacement
Jun 02, 2009 | Brother IntelliFax-2820 Laser Fax
Xerox Phasor 6120 jams at top and right in middle of fuser
Most likely just one of the pick fingers has popped out in the fuser and is stuck in between the rollers.
You can remove the fuser and look, they are somewhat pointed fingers and are spring loaded. They make contact with the rollers and often times pop off. You want to look at the condition of the heat roller also. It is a teflon coated aluminum roller. Just check to see if the teflon coating is still shiney.
Looking at the printers if you want to replace it, I would go with the 6180. Don't go with the solid ink color, Extremely expensive to operate.
Dec 09, 2008 | Xerox Phaser 6120/YN Laser Printer
Dell 1700 printer paper jams
if the paper is jamming at the back of the unit, and looks like an accordian after removal, it's more than likely only the paper sensor on the fuser. i dont recall the part number, but it can be had from online suppliers for under $40.
Nov 10, 2008 | Dell 1700n Laser Printer
Oki c5150 fuser jamming
This tells me the one of the Pickers in the fuser is damaged and causeing this Jam , I would replace the fuser and chaces are this most likely will resolve your problem
May 02, 2008 | OKI C5150n Led Printer
OKI c3200 Laser Printer...
There are 3 little black and white rollers under the cover on the back of the printer. They are pushed under the upper rollers. They should be on the outside of the upper rollers. Somehow they got wedged under the upper rollers. This should fix the accordian paper jam.
Apr 07, 2008 | OKI C3200n Led Printer
PAPER JAMS CONSTANTLY
Well, it might be theres something stuck in there. Pick it up and give it a few shakes. I work on printers, and not too long ago I found a wedding ring, paperclip, banana sticker and other things in printers. If that doesn't work, try going to staples and getting a laser cleaner kit. They're basically sheets coated to pick up any paper dust, or bits of paper that might be clogging the path
Mar 11, 2008 | Brother HL-2070N Laser Printer
Labels jamming
Check the entire paper processing path as it sound like either the roller gear is not engaging properly to push the paper out of the top, or the output paper path is somehow blocked, like from a label or something else stuck at the top, the roller gear is damaged, or other obstruction.
Nov 16, 2007 | Konica Minolta magicolor 2300DL Laser...
Lexmark X500n Color Laser All-in-One Printer Logo
130 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
