Question about Epson Stylus NX300 All-In-One InkJet Printer
Epson NX300 won't let me print black ink only -- new black ink cartridge; other 3 colors (C,Y,M) are low/empty. Tried every printer preference setting to no avail. Can I print in black ink only or MUST I replace all four cartridges?? Ugh. Thanks!
punker0204
  • 54 Answers
SOURCE: Epson C66 won't print without color cartidges
epson printers won't really print if one cartridge is not detected or detected as empty. the only option that i can suggest to you is that, buy a continous ink kit at any ink refilling station in your place. i highly recommend that dont leave a cartridge empty with ink cause it might clog your printhead. using a continous ink system's cartridge is auto reset, whenever the printer says that the cartridge is empty, it will automatically resets itself. ink refill kit comes with 100+ml of ink per color i think. and it is much cheaper using original epson ink.
Posted on Sep 26, 2007
SOURCE: Epson aculaser c1100 cant access empty ink cartridge.
go to the reset menu (right arrow and then down arrow until reset menu is displayed) on the lcd display and then choose change toner #(right arrow until the desired toner is displayed) Hope this helps
Posted on Oct 04, 2007
SOURCE: Printer will not print black, but will not let me replace black cartridge
Had the same problem but this worked for me. To force a cartridge change, press and hold down the PAPER FEED button for at least 5 seconds as suggested here:
http://esupport.epson-europe.com/ViewArticle.aspx?lng=en-GB&kbid=313630&data=qBjAbS6NcI3fNMgp8+fHGGs5vImpFwyM
I then changed the black cartridge, even though I hadn't used much ink from the old cartridge and the computer was showing it as three quarters full.
Posted on Apr 22, 2008
worldvet
  • 859 Answers
SOURCE: Printer will not read ink cartridge
This is a common problem in the Epson line. You may attempt to resolve this first, by powering off the printer. Then remove the power cord and leave it unplugged for an hour. Then plug it back in and power on the Printer. The error may reset itsefl on its own.
If it doesn't please refer to this Tip Page on how to obtain and use a utility to reset your Epson. Even if your printer is not listed as those this will work with this method usually will work today.
If you have any trouble getting this resolved please contact me by using the Comment Box bleow.
Regards,
Worldvet
Posted on Nov 12, 2008
  • 3 Answers
SOURCE: Epson Stylus DX8400 empty ink cartridges but actually new
Sometimes there is a coating on the chips (even original epson ones!) - Old wives tales say dont touch the chips with your fingers - but take the carts out one by one and wipe your finger over the chips (1 finger for one chip - dont reuse the same finger on a different chip)
Reinstall them and that worked for me on a dx4500 with original epson carts in
Posted on Dec 29, 2008
Epson black ink only won;t work unless I have full color cartridge as well. What a piece of garbage! Never buy Epson again unil they solve this problem. I'm out of blue but I can't use a bl
The way around Epson ripping you off is to use compatible cartridges. They are much cheaper than Epson and will work in most printers. You can buy them in bulk from places like Amazon. As for the print quality I have not noticed the difference. Some printers might say that you are not using Epson ones, but you can dismiss them and carry on.
Aug 18, 2017 | Epson Stylus NX300 All-In-One InkJet...
I have enough black ink to print a few pages in black, but the printer won't print. What do I do?
I had a Epson printer that would not print or even allow me to use the scanner because the colored ink was out. Even though I had full black ink, it still would not let me print until i replaced the colored ink.
Sep 25, 2012 | Lexmark 90T6005 Prospect Pro205 All-in-One...
My printer is low on Magenta ink, so it won't print... even with black and white documents.
The Nx300 printer needs to have all the colosr and the black with ink in them so that they will print. For the printer will not print unless there is ink in all the cartiages
Aug 23, 2011 | Epson Stylus NX300 All-In-One InkJet...
Out of Magenta but just want to print in black and the Epson nx300.won't let me.
strangely enough, epson printers require all cartridges to have ink in or they don't seem to work.
Jun 01, 2011 | Epson Stylus NX300 All-In-One InkJet...
I have a new Epson Stylus NX300 Series. When I
Diane,
We try to steer people away from new Epson printers unless they plan on purchasing a professional model. The new Epson cartirdges have little ink and finicky. I would try power cycling the machine with the cartridges removed (unplug it for 30sec.) then reinstall the cartridges. If the problem persist call Epson and let them know what you think. If they don't help you, buy an HP. But but an HP that takes integrated print head cartridges or you'll be in the same situation.
Pat.
Feb 02, 2010 | Epson Stylus NX300 All-In-One InkJet...
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson stylus cx4200 all-in-one?
1. Make sure the printer is turned on.
2. Make sure the document cover is closed, then closed, then open the scanner.
(Do not open the scanner when the document cover is open).
3. Press and release the ink button. The 'On' and 'Ink' lights flash.
If one of the cartridges is low or empty the printer moves that cartridge to the 'ink out' mark. Go to step 4.
If no cartridges are low or empty the ink cartridge holder moves to the ink replacement position. Go to step 5.
4. Pree the 'ink' button again.
If more than one cartridge is empty or low the next cartridge moves to the 'ink out' mark.
Once the printer identifies all the empty or low ink cartridges the print head moves to the ink cartridge replacement position.
5. Open the cartridge cover, squeeze the tab at the back of the empty cartridge and lift it out.
6. Before you open the new cartridge package shake it four or five times and remove it from the package .
(Don't remove or tear the label on the cartridge otherwise ink will leak out) .
(Don't touch the green chip on the front of the ink cartridge - you could damage the cartridge).
7. Place the new ink cartridge into the cartridge holder and push it down till it clicks into place.
8. Replace any other cartridges that need replacing.
9. Close the ink cartridge cover and press it until it clicks into place.
10. Close the scanner.
11. Press the 'ink' button. The printer starts charging ink and the 'on' light starts flashing . This takes about a minute . When it's finished the 'on' light stops flashing and remains on and the 'ink' light goes out.
You'll see all the above, with helpful pictures, at
this Epson support page
Mar 19, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Prints grey not black
I solved this problem but probably not what the printer manufacturer would recommend! The reason you are just getting grey is that the black ink cartridge is either empty or dried out from non use and only the color cartridge is working. I had the same problem after being away for 5 months. I put the printer cartridge in a bowl of warm water to disolve the dried out ink on the print pad. I dried off the cartridge with a soft cloth and then it worked perfectly.
Feb 25, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Sep 26, 2007 | Epson Stylus C66 Inkjet Printer
Epson Stylus NX300 All-In-One InkJet Printer Logo
2,309 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
