Question about Ovens
I have a Frigidaire gas oven with an electric igniter (5-10 years old). When I go to heat the oven, the igniter comes on and i smell gas, but the burner never fires. i can't say how hot the igniter is (orange, but dull around the edges). And I cant say how strong the gas smell is (after about 10 minutes you can smell it in the next room). The range works fine. What do you think?
  • Ovens Master
  • 6,826 Answers
The ignitor may have to be replaced and placed in a spot that ignites the gas. There should be a safety feature known as a thermocoupler that doesn't allow the gas to go to the next room when it doesn't light, I would think. Kind of like a gas water heater's.
I would have an appliance professional fix this one for you. Don't want any gas explosions, you know.
Posted on Jul 30, 2010
  • 1 more comment
  • tpoc81 Jul 30, 2010
    Thanks for the quick reply. I'm wondering if it is worth getting a repair or whether i should just get a new oven. The repairman want $65 just for diagnostic.
  • Duane Wong
    Duane Wong Jul 30, 2010
    $65 isn't bad for a diagnostic, and he might be able to direct you more specifically to fix the problem.
    In most cases if it doesn't light, but the ignitor is on, the gas flow isn't hitting the ignitor at the right 'spot,' but in some cases the ignitor isn't getting hot enough (even though it gets orange which is pretty hot- like a glow plug in a diesel engine).
    I would go for the repair for a 5-10 year old oven, unless you have a couple of thousand or more to spare for a new one.
    Good luck on this repair.
  • Duane Wong
    If the range still works, then the oven should be an easy fix for the appliance guy, since there's only one or two burners in there.
I have a Jenn Air gas oven (range) model JGS9900CDS01. I have been smelling gas only when the oven is on..It seems to cycle from worse to not so as the oven cooks. My repairman just replaced the igniter...
it's still under warranty for 1 year but by him working on it you could have voided the warranty i would call whoever you bought it from or call the factory and tell them it's under a year old what will you do for me.
Feb 07, 2018 | Frigidaire FGB24S5A Gas Single Oven
Gas oven stopped working
Sure i will be able to provide you solution
Apr 15, 2008 | Ovens
I have a 30 inch Frigidaire self cleaning oven. The oven will no longer heat up in a normal amount of time using the bake function. Sometimes I can smell gas when using bake. It cant reach the desired...
Sorry to read about your problem, I hope this helps you out.
Bad gas control valve or oven temp control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My gas oven heats very slowly and sporadically. It often smells like burning plastic when heating. The oven is about 9 years old and did not have this problem until recently. What could be wrong? Might...
Good morning, your oven most likely has a weak igniter. That would keep the gas safety valve from opening properly. It will get close to the required amperage but valve will only flutter and not allow enough gas to ignite. Hope that helps.
Jan 29, 2018 | Maytag CWG3100A Gas Single Oven
Frigidaire gas oven, 5 years old, oven pre-heat light comes on and stays on, oven gets warm but not up to temp (it was like this for about an hour), also smell gas when oven door is opened. Burners work...
I don't have a solution, but I was wondering if it constantly beeps until you press the start button? I am having the same problem with my oven preheating. Until we can figure out how to stop this we unplug it and shut the gas off when not in use.
Aug 20, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
On the oven, you can hear the gas come on but the oven will not light...the ignition starter?
Sounds like the igniter, Here is a video that shows you how to test it. Scroll down to How to Troubleshoot a gas oven that won't heat.
Mar 03, 2010 | Frigidaire FEB27S5A Electric Single Oven
My oven which is only 5 years old won't warm up on bake or broil
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Feb 03, 2010 | Ovens
I replaced the igniter (glow bar)on our Kenmore
IF THE UNIT IS 14 YEARS OLD BE CAREFUL THE GAS VALVE MAY BE GETTING TO THE POINT WHERE IT IS NOT SHUTTING OFF AS QUICK AS IT USE TOO, YES THIS WOULD CONCERN ME ,YOU DON'T KNOW IF ONES OF THESE TIMES THE GAS VALVE MAY NOT SHUT AND GAS BUILD UP COULD BE POSSIBLE ,NOT A GOOD THING. PLEASE BE CAREFUL
Aug 31, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
WHY WON'T MY OVEN HEAT UP?
Most modern gas ovens and many broilers use a "glow-bar" style of igniter that glows red-hot to ignite the gas. If the igniter doesn't reach the proper temperature, the gas valve won't open. You may need to replace the igniter.
Oct 30, 2007 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
29 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
