Question about LG Washing Machines
LG Intellowasher (Model WD-1023C)
How do i clean / unblock the inlet filter and drain filter on my LG intellowasher model no. WD-1023C
  • Anonymous Mar 22, 2014
    How do I clean my filter drain on my lg intellowasher?
The water pump can be blocked and thus stop the machine from finishing the wash cycle. In front on the bottom there is as hatch that can be opened with a flat screwdriver, the small black rubber pipe can be used to first drain all the water before the opening the filter. Small objects such as coins coluld be found in here, blocking the pump. Clean the pump by removing these, optionally blowing into the outlet (yuck!), to dislodge anything. If that does not help to fix the problem, you can clean that actual water pump, but this requires you to use a screwdriver to remove the pump.
Tilt the machine on its side, the pump is attached with 3 self-tapping screws. (if you can't figure out what the pump is you should probably let a technician do this). The pump has 2 parts to it, take it apart carefully and clean out all the dirt that has accumulated in there. Plastic friendly, waterproof grease can be applied to the pump spindle and bearing if available.
If the problem still persists a new pump is available from LG at a reasonable cost.
Posted on May 22, 2012
The door is jammed on my LG Intellowasher WD 1023C front loading washing machine. The cycle is finished, ubt the door won't open.
Posted on Jul 13, 2011
  • mikcaau
    mikcaau Mar 18, 2013
    Turn power off at powerpoint for 30 minutes and door lock will release. Machine thinks that it still full of water.
I've got a LG Intellowasher WD-1023C and it spins real slowly or not at all and there is a glow from the bottom, it also stops with 9 minutes left on the 30 minute wash
a glow does not sound good. any error codes. glowing sounds like a hot/shorted wire, maybe the heating element. i think i would unplug and call for professional service.
Oct 25, 2016 | LG Washing Machines
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
Lg intellowasher wd 10160f
Check the Lid Switch Assembly with an Ohm meter for continuity, these switches are a common problem. Replace the switch assembly if faulty.
Mar 18, 2014 | LG Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
Where is the lint filter for the LG Intellowasher 7.5kg (model WD-8016C)?
Hi just read your posting.I have worked on these machines before and I don"t recall this model having a lint filter.I know it has a drain pump filter and filters in the inlet hoses.Are you getting a lot of lint on your clothing?I will endeavor to find out definitively whether your model of machine has a lint filter and I will re post the solution.
Sep 18, 2010 | Washing Machines
Is there a filter in the LG INTELLOWASHER 7kg. If so where is it. The model is WD-8074FHB
its located on the bottom right of the machine front - open the flap and you will see a round filter base. ONLY OPEN THE filter during the last of the spin cycle to clean it, this is when most of the water has been pumped away. Opening it while the machine is off will cause a gush of water over the laundry floor.
Feb 08, 2010 | LG Washing Machines
LG INTELLOWASHER STOPPED SPINNING
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 02, 2008 | Washing Machines
Washing Machines Logo
1,379 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
