Question about HP Computers & Internet
I have lost the sound on my computer. I show no default device loaded in the audio section of my control panel. How do I reload or obtain a new device so I can hear sound?
  • 734 Answers
HI There,
Go to HP Support, Drivers & Downloads and enter your model # in the small window where you are prompted to do so.
http://welcome.hp.com/country/us/en/support_task.html
Make sure you choose the correct operating system for you computer when asked. When your Driver list appears, go to the Audio section and download and save the Sound/Audio driver to your Desktop. Close all other windows, double click on the downloaded driver file and follow the prompts. Your sound device should re-install.
If it does not, there are other issues...possibly even failed hardware. I'm trying to help you from very limited info.
Good Luck
Good Luck
Posted on Jul 30, 2010
  • 10,319 Answers
Click on the provided link below and have this program check all drivers. It will down load any not up to date of not working correctly
http://xpdrivers.com/printer/hewlett-packard/_3_2070.cfm?gclid=CNLp5ZT8kaMCFRwhnAodBUJbuA
Beko HDMI no sound
The HDMI audio should be controlled by the video driver. You may need to change the audio output to get the TV speakers to get the audio from the HDMI signal. Open the Control Panel (Start > Control Panel with Windows 7 and Vista) and go to the Hardware section. Find the Sound section and click on the Manage Audio Devices link. In the Playback tab, right click on HDMI Output and try to make it the Default audio device. If you see a test option, check if you hear the audio from the TV speakers.
For laptops, the usual default audio is the built-in speakers.
I hope this helps.
Dec 31, 2017 | HP HDX16t Premium Series Notebook
I have no sound it.it tell me no output device is installed not sure what this means
In control panel go to "system" then "device manager" and see if there is a yellow exclamation mark in the sounds, video & game controller section. (click the + to expand the section).
You probably need to uninstall the sound card driver and reboot so windows can re detect it and reload the drivers. You may have to download the drivers from the support section of your computer manufacturers site. look for a link to support. have the model and serial number ready.
Jul 09, 2010 | Computers & Internet
I am not a computer person but we did install a new Radeon hd 4650 video card in my son's hp. The Best Buy Geeks looked it up for our model and said it was compatible. We put in a new power supply. The...
Are your speakers plugged into the 3.5 mm jack on the system?
When you install the Radeon driver, it can sometimes change the default audio output to the HDMI port on the video card. For various Windows OS versions, you need to set this in the audio section of the Control Panel. The specifics may vary. For versions before Windows 10, Click on Start and select the Control Panel. Then choose the Hardware section. Find the Sound section and Manage Audio Devices. In the Playback tab, right click on the correct audio device (Speakers) and select Set as Default Device. Depending on the system, you'll probably see AMD HDMI Output and Digital Output. For Windows 10 before the Creator Update, right click on Start and look for the Control Panel. After the Creator Update, you'll need to click on Start and expand the Windows System folder.
I hope this helps.
May 06, 2017 | Gigabyte RADEON HD 4650, Video Card
The sound on y t2682 emachine does not work, could youplease help me?
Step 1. Check to see if the sound volume is turned up. You can usually the icon in the lower right system tray of your screen. Also, check to see that your speakers are on and plugged into the computer.
Step 2. Obtain most recent sound driver for your machine and reload it. The newest driver can be downloaded at the computer manufacturerer Web site or perhaps came on a CD with the machine itself.
To reload your sound device, go to Control Panel and find the Device Manager. I don't know your OS setup so I can't give you exact instructions. Once you are in the Device Manager, click on the the Sound, Video and Game Controllers section. Click on the whatever sound device you have. Then click on the Driver tab till you see the option "Update Driver". Follow the instructions from there. The computer will probably ask you where the driver location so it can use it. Hope this helps.
Apr 03, 2010 | E-Machines T2682 (000002965) PC Desktop
Once I installed magic jack my computer speakers stopped working ... got a new sound card ... worked fine ..plugged magic jack back in ... they stopped working again ... online help ... hasn't helped yet...
Windows XP:
1. Click Start
2. Click Control Panel
3. If your Control Panel is in Category View, double-click Sounds, Speech and Audio Devices. If not, go directly to the step 4
4. Double Click on Sounds and Audio Devices
5. Click the Audio tab (the middle one)
6. Under both Sound Playback and Sound Recording, select your default audio device (the one you want to use) from the drop down menu
* Never select Tigerjet as your default device
7. Click the box labeled Use Only Default Device" (located in the bottom left corner of the window)
8. Click Apply and OK
Windows VISTA
1. Click the Windows Button (Old Start Button)
2. Click Control Panel.
3. If your Control Panel is in Classic View, Double-Click Sound. If not, go directly to the step 4.
4. Click on Hardware and Sound.
5. Click Sound.
6. Right-Click on your default device (the one you want to use) and select Set as Default Device
* Never select Tigerjet as your default device.
7. Click Ok.
www.sunwindproducts.com
Jan 12, 2010 | Audio Players & Recorders
Recently installed binatone S1545 onto computer running xp home. works well but unable to stream music (mostly from Spotify) whilst it is plugged in. Get message on Soyify '' There is a problem with your...
On windows got to "START"
Control Panel/Sounds and Audio Devices.
Audio tab select sound card as Sound playback default device
Voice tab select sound playback default device
Open Skype got to tools/options/audio settings.Select USB device under Microphone and speakers section.
Save all settings. Works well.
Dec 27, 2009 | Computers & Internet
My Dell Dimension 4500 XP has no Sound
i) i would suggest you to format ur system or reload OS or reload OS Freshly(dont mess with crashed system)
ii) then try load sound drivers from the mother board CD that came with ur computer which will have video drivers, sound drivers, network drivers......
Dec 27, 2008 | Dell Dimension 4500 PC Desktop
No Sound
first go to start click settings click control panel. then click sound and audio device.go to audio find sound playback see the default device : sample realtek ac97 audio<<most like this
second go to control panel click add & remove program click remove xp services pack 3 then restart pc so you will go sound
Dec 23, 2008 | Dell OptiPlex GX110 PC Desktop
Sound card not detected
ask to expert by calling 18002044427 toll-free number and get quick solution regarding your query...
May 31, 2017 | Computers & Internet
My PC has a AOpen motherboard MX46-533GN and just recently, I have lost my Sound driver and now there is no sound. I reloaded the driver from the CD provided with the PC and hasn't solved the problem. When...
Thats the base properties of the board, in the report does it show as an Intel Pentium 4 with AOpen MX46-533GN that's the board name, if it does then your audio is realtek AC'97 go here http://www.realtek.com.tw/downloads/...tDown=false#AC
Apr 08, 2008 | Computers & Internet
Computers & Internet Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
