Question about Insignia NSNAV01 GPS Receiver
My gps will take me to the home page but when i press on map to show my location i can't find any gps signal
  • 268 Answers
While on that screen, pls reset it from the small pin hole reset button.
Hopefully it should come back to normal.
good luck.
Posted on Jul 30, 2010
My gps freezes when on speedo
Okay. I have to explain what happens when you use the speedometer option. While it is off, the GPS use using less cycles per minute to get the location from the satellites and sometime from ground beacons. When in speedo mode, it now needs more processor, memory, graphics speed and the power needed for the receiver. Now the unit is running about twice the cycles per minute to provide an accurate location to judge your speed.
How to work around this.
Best answer: Dont use this option! Its simple and you dont have to burn your noodle worrying about it.
2. If you must use it, then go into your display and map options and turn the map details and quality down. This will free up memory and CPU speed.
3. Turn tracking off. This will free up memory and CPU speed.
4. Use Garmin's mapping program to only load necessary map locations.This will free up memory space.
5. Be sure you are updated to the latest map data and firmware.
6. This can also be caused by the location of the GPS in the vehicle. On the main screen of most Garmin's, you press and hold on the corner near the icon showing the GPS signal. It will go to a more detailed screen of the satellites and signal strength. Stay in one place in an open area like a parking lot. Let the GPS locate itself first. Then relocate it where you can easily see it and you see 40% of signal or more from 4 or more satellites.
Have fun with what I gave you and good luck. VicFixx
Oct 27, 2014 | Garmin nuvi 1250 Car GPS Receiver
My navigation system in my 07 camry keeps telling me the address doesn't exist when I know it does. It won't find any address
If your GPS is not finding any address, then the most likely cause is that the wrong country map is loaded or the map is corrupted as finding an address does not rely on getting any satellite signals (your GPS should at least show your home location or the last known position on the 'correct' map): I suggest that you look at your specific GPS user manual to find how to check that you have the correct map loaded: if it is the case, then find the instruction on how to 'reset' your GPS as its software may be corrupted.
Hope it helps.
Jul 15, 2010 | 2007 Toyota Camry
Change home deststion
Switch on the GPS at your home location. Verify that the location shown on the map correspond to your Home location (The street or avenue you are standing matches with that shown on the GPS). Once this is settled, tap on the screen. Tap on :change preferences. Tap on :arrow (on Preferences 1 of 6 page). Tap on: change home location (on Preferences 2 of 6 page). Tap on: arrow. Tap on: My location. You should see Home location changed info and pop into the main screen.
May 04, 2010 | Tomtom XL 330 Car GPS Receiver
Can't view downloaded sections from Garmin Topo
In Map Setup page, scroll over to blue 'ball' icon (second from right), press lower left button on side of GPS unit, use Thumb switch to scroll down to "Show None", click Thumb switch in. All maps will disappear. Press lower left button on side of GPS unit again, scroll down to "Show Topo.....", click Thumb switch in. Your Topo maps should now show onscreen.
The reason your Topo map might not have shown is because, if you leave the Navigator map showing, and then just press "Show Topo", the layer showing Topo will still be under the Navigator map. This is why I always tell it to show none, and then load whatever map I need to see onto a bare screen.
If this solved your problem, please come back and rate our answer as this assists others. Thank you.
Feb 04, 2010 | Garmin eTrex Legend GPS Receiver
Home location keeps showing a different location. reloaded home address still showing a different location.
On the TomTom One, this is impossible unless you have several maps.
Each time you switch to another Map, the preferences such as Favorites and Home addresses only apply to that specific map.
Let me know if it helps or let me know exactly what you are doing to change and set your Home address.
(hint: Change preferences -> Change Home location ?)
Jan 06, 2010 | Tomtom ONE XL GPS
How to change home address
using your touch screen, go to tools> my data> set home location> you can use your current position or you can enter it. then it will be save as a home address
Sep 27, 2009 | Garmin nuvi 265 Car GPS Receiver
How do I reset GPS to original setting
hi,
thank you for using Fixya.com
click on this site you be directly connected to the manual including to solved your problem how to reset your unit general..
http://www.scribd.com/doc/249380/TomTomONE-Manual
hint go to page 39 of the page GENERAL Reset guide.
May 21, 2009 | Magellan Maestro 3200 GPS
Resetting Home
I'm not sure I understand the question. When you take the unit outside and turn it on, does it show you in Tampa, or Decatur? If it still shows you in Tampa check the satellite status in the tools menu, you may not be acquiring your current location.
If you're talking about the home location that is saved into your GPS as a waypoint, go into your favorite places list and delete the place named "home" then go to the location you want to save as your new home and press "where to" and then "home". Since there is no home saved, the GPS will ask if you want to save your current location as home. That should do it for you.
Feb 08, 2008 | Garmin Nuvi 660 GPS Receiver
How to change home map on used Garmin i3 street pilot
Hello. Had the same problem and just solved it.
Do this.
Tools -> Manage My Data -> My Locations. Position to Home and then click Manage -> Change Location ..
Cheers.
Sep 15, 2007 | Garmin Map Source City Navigator
Insignia NSNAV01 GPS Receiver Logo
172 people viewed this question
Top Insignia GPS Experts
Marvin
Marvin
Computer Links
NOEL
NOEL
Are you an Insignia GPS Expert? Answer questions, earn points and help others
