Question about Electrolux Epic 6500 Vacuum
Won't turn on; no lights, no power.
I vacuumed an apartment with my Epic 6500 and it was working fine. I plugged it back in to hit one more spot and nothing. No lights, no power, nothing. It worked just 10 minutes before with no problems.
    President:
  • 1,673 Answers
Did you try a different outlet? The cord may have gone bad, most of the times I find that people don't pull the plug out of the outlet by the plug, they just pull the cord, or it got yanked out some other way and that will break the wire inside the cord. Other then that, it would have to be taken apart to find the problem.
Posted on Apr 24, 2008
Electrolux Epic 6500 SR - power/cord light not lit, doesn't start & blows house circuit breaker
If your vacuum has had 20 years of service it may be simply too old to repair.
Apr 15, 2017 | Electrolux Vacuums
Compact electra C9 vacuum power head wont turn on
Have you checked the electricity is getting to the motor? You can replace the motor if necessary.
Jan 17, 2014 | Electrolux Epic 6500 Vacuum
I have an Electrolux Epic Model 6500sr canister apart and I need the wiring diagram for it Thanks Jim
Unfortunaly I don't have that wiring diagram. I am sure that the service manual can be ordred thru sears as they are the carriers for this material. What excactly is the issue and maybe we won't need the diagram.
Nov 21, 2011 | Electrolux Epic 6500 Vacuum
I have the electrolux vacuum epic series 6000 SR and bought it used therefore I dont have a manual. I have had it for about a yr and it worked great..it looked like it should have a filter but I didnt...
1. A manual can be downloaded from:
http://www.aerusvacuums.com/support/manuals/.
The Epic 60006500 is located under "Older Models". Download the Epic 6500 manual
2. Check for clogs in the hose and the power nozzle inlet.
3. Disconnect hose. Turn on vacuum. Does it run? If so, place hand over intake? Did it shut off? If it did, the problem is a worn out or broken component inside the vacuum. Generally a result of using generic "made to fit" Electrolux bags. This is a part that needs to be replaced in an authorized Aerus (Electrolux) shop.
Sep 15, 2010 | Electrolux Epic 6500 Vacuum
Parts for Electrolux Epic 6500
You need to look under AERUS Electrolux to find a Dealer with parts.
Electrolux USA sold the brand name back to AB Electrolux of Sweden a few years ago and there is no relation between the two.
You may also find a common component of a different color at a Tri Star dealer as they shared some power head and hose technology in the era of the EPIC although they don`t tell people that
Sep 14, 2009 | Electrolux Epic 6500 Vacuum
Power nozzle motor will not turn on
Try hitting the reset button,It is a small button on the top of the brush and make sure the switch is turned on on the handle.
Jun 22, 2009 | Electrolux Epic 6500 Vacuum
We replaced the motor on our electrolux epic 6500 but the temperture light comes on and machine willnot run.
Check for blockage in the hose or the sweeper. Check the filter located under the grill on the top back of the machine.
Jun 15, 2009 | Electrolux Epic 6500 Vacuum
Electrolux 6500 SR
The cord light just indicates that the machine is plugged in and has power. In other words, you did great!
Nov 20, 2008 | Electrolux Epic 6500 Vacuum
My Electrolux upright worked fine
Are you using the proper bag? There's a kill/reset switch that needs to be pushed down by the rim of the bag before the unit will run.
Jun 22, 2008 | Electrolux Epic 6500 Vacuum
Vacuums Logo
116 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
