Question about Garden
I don't know how to change the blade. - Garden
    President:
  • 1,627 Answers
Chain saws don't have a blade,so i think that you need to give me more info about what your problem is.If you mean the chain bar that the chain runs along,then you need to remove the cover from the chain bar and then loosen the bolts that hold the bar on and then slide the bar back until you can remove the chain,once the chain is off you can then just pull out the bar.
Posted on Jul 30, 2010
Does someone know which # blade to use with the Oster, universal comb set for use with the Oster A5 turbo clipper?
Hi, as far as I know you're suppose to use a size 10 or 30 blade with any combs. I prefer to buy a longer blade like a size 4 rather than using the combs as I find the coat finish not great with the combs.
Feb 06, 2013 | Oster A5 Turbo Clipper Kit-10,40 Blades&5...
Is there a lever or a pin for locking the blade so I can change the blade with ease?
I don't think there is a locking pin or lever for the blade, but it works very well to use a block of wood on the table in front of the blade. It's a lefty thread.
Good luck, be safe!
Jun 15, 2012 | Saws
I have a toyota blade and i want to change the language to english , but don't know how
You can't display English. Bit this site shows what the screens mean. http://au.toyotaownersclub.com/forums/topic/51250-toyota-blade-dashboard-display-japanese-to-english
May 31, 2012 | Toyota Previa Cars & Trucks
Broken blade in dewalt sawzall
Remove broken blade, install new one. These blades don't change themselves, unfortunately.
May 06, 2012 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
How to change blade arm and plastic blade guard
Don't forget that the bolt that holds the blade against the arbor (the motor hub connection point) is threaded COUNTER-CLOCKWISE. This is the opposite of nearly everything else we encounter. Be sure to use the two wrenches you got with the saw, and like the directions always say, "Unplug unit before servicing!"
Mar 15, 2012 | Saws
I think that I over tightened the lock nut on one side (not using a tort wrench) after changing the mowing blades. I don't think it is cutting now. When I take the blades off from cutting, one blade...
there is a star shaped, or other, pattern on the bottom of the mandrel which fixes it into the blade. this has stripped so the blade is freewheeling on the mandrel. if you cannot remove the blade bolt, I think you are going to have to remove the deck and take it to a fabrication or machine shop to have them remove the blade from the mandrel. then you buy a new mandrel and a new blade, at a small engine repair shop, put it back together. take a picture of the top of the deck before you remove the deck belt so you know how to put it back on after you have the new mandrel bolted in. if it is old you may just want to replace all the mandrels while you are at it. they are less than 50 bucks each.
Aug 24, 2011 | Toro Garden
How many seconds of grind for standard drip grind
I've long ago lost the manual that came with my grinder (I actually don't remember if it even had one), but I don't think it listed grinding times. You just grind a few seconds and check, then grind a little more if it's still too coarse. Unlike a burr grinder which is adjustable, in a blade grinder the same grind time may result in different consistencies as you change beans. By now I've just learned how long to hold the button for the different beans I buy, and the first few times I try a new blend or varietal I have to adjust the time. I think you'll just need to experiment and then you'll know what works best for your tastes.
Jun 30, 2011 | Braun KSM 2 Electric Blades Grinder
Two springs broke underneath the riding lawn mower 3800 and we don't know where to replace them at, they engage the gears.
First make sure you can still engage the blades.Many mowers use a cable attached to a spring to engage the blades.If that is one of the springs,you need a new cable.For the other I will need more information,like what kind of mower is it?How many blades?Another thing to look for is worn or torn holes that the springs attach to.
Jun 29, 2011 | Garden
I have a 12" Ridgid
if it is only 2 months old take it back and get another one. if this not an option try some loctite on bolt
Jun 27, 2011 | Ridgid Reconditioned 12 In. Compound Miter...
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
