Question about Canon Office Equipment & Supplies
Hi, just find a problem of IR C3200: color off on cardstock, but plain paper very good. thanks
    President:
  • 567 Answers
Hi please tell about the problem? so i can find a solution
Posted on Jul 29, 2010
  • 6 more comments
  • goldcopy Jul 30, 2010
    thanks for response quickly.
    IR c3200 problem: print on plain paper is perfect, but pirnt on thick paper (cardstock) will be color off( seems to be color regist problem),thanks
  • Hilton Bristol Jul 30, 2010
    Hi please try this option: Many people use card stock for a variety of paper crafts, including scrapbooking and greeting cards. From time to time, you will want to print items directly onto your card stock paper to achieve the desired results. When you must print on card stock, make sure you prepare your printer to handle the heavier weight of the card stock. You may also want to print a test page onto regular paper prior to printing on the card stock.
  • Open the design or text you wish to print. Make sure you have centered the design and it that it looks the way you want.
  • Step 2Print the design onto plain paper first to make sure it looks right.
  • Step 3Remove all of the plain paper from your printer and load the printer with three or four pieces of card stock.
  • Print the design onto the card stock. If you are printing on the other side of the card stock, wait while the first side dries completely. Reinsert the card stock back into the printer to print on the second side, if desired (following the paper placement guidelines for double-sided printing according to your individual printer).
  • Step 5Wait while all of the printing on the card stock dries before doing anything further with the card stock.
    print first page on cardstock is good, but continued pages will be cyrn and megenta off.
    is it the first time you notice that?
    Hi there i mean to ask you if you ever notice the it before?
    Hi, it worked well before .thanks
  • Hilton Bristol Aug 02, 2010
    Hi this seem like the drum is not receiving enough toner when you try to print on card stock.
    Canon IR C3200 - Error E000020 0170
    Fault connected withdrum/developer,in this case yellow(E.020-0170)
    ...-0270 is magenta,...0370 cyan and ....0470 black.
    Apr 17, 2013 | Canon Ir C3200 Color Copier netfax N-1...
    Cannon 3200 when machine has warmed up error code 000732-001
    This is a reader communications error. It's been a long time since I worked an IR-C3200 copier but all cables must be plugged in. They will only go where they were intended to go. Reseat all those cables and good luck, other wise you have a professional help problem. Make sure all the cable checks are done with power off. Then power up agai n and see what happens.
    May 07, 2017 | Canon imageRUNNER C3200 Color Printer
    Hello I have an HP 2600n and would like to print on 5x7 paper, is this a possibility with this printer? it seems that it will pull the paper through but nothing is printed
    Copied this from the specification on HP site.
    It would appear not to take 5 x 7. It's the 7" is to small, 8.5 is the smallest.
    Media sizes, std.
    Letter, legal, executive, No. 10 envelopes, Monarch envelopes
    Media sizes, custom
    Tray 1, 2, 3: 3 x 5 to 8.5 x 14 in
    Media types
    Paper (plain, letterhead, prepunched, bond, color, rough, preprinted, recycled), HP Color Laser Glossy Photo Paper, HP Color Laser Glossy Brochure Paper, HP Color Laser Matte Brochure Paper, HP Color Laser Matte Photo & Imaging Paper, HP Color Laser Soft Gloss Presentation Paper, HP color laser transparencies, labels, envelopes, cardstock
    Nov 30, 2010 | HP Color LaserJet 2600n Printer
    How to prink on cardstock on Ricoh Aficio CL2000N
    To print on cardstock:
    - Load the cardstock paper in the paper tray and make sure the fences are snug but not too tight.
    - Press Menu.
    - Scroll down to find Paper Input and select it.
    - Select Paper Type.
    - Select Tray 1.
    - Scroll to find "cardstock" on the list and select it.
    You'll also have to set your print driver for cardstock or auto select, because if the print driver shows plain paper and the printer shows cardstock paper, you'll get a mismatch error.
    Aug 08, 2010 | Ricoh Aficio CL2000N Laser Printer
    IR C320N scaning with MAC OSX
    Use the Irc 3200 drivers on the Canon USA
    Color imageRUNNER C3200 : Drivers & Downloads
    http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2269&modelid=8927
    Feb 08, 2009 | Canon imageRUNNER C3200 Copier
    Canon ir c3200 promts for page setup on each internet document
    I believed when page setting box show out you have to enter the quantity you want print
    Dec 09, 2008 | Canon imageRUNNER C3200 Color Printer
    Canon Color ImageRunner - Tab Instructions
    To be able to print using tab paper from the driver
    Since the tab paper can only be fed from Stack Bypass, single reverse tab paper cannot be
    used. The tab paper must be single forward.
    1. Go to the printer and put some tab paper in Stack Bypass
    2. Press Letter on C3200 LCD panel and press Next
    3. Select Tab paper and press Done
    4. Go to Windows Start menu and choose Settings
    5. Open Printers folder
    6. Select Canon iR C3200 PS3’s Properties
    7. Click on Device Settings tab
    8. Click on Form to Tray Assignment button
    9. Making sure that Stack Bypass is highlighted and Paper Size is Letter, select
    Tab Paper by scrolling down the Paper Type list
    Page 2
    Hint:
    In order to print to Tab paper, it is necessary to select Tab Paper in the Form to Tray
    Assignment dialog box before using this option. Otherwise, the option of printing to Tab paper
    is not available from the print driver.
    10. Click OK to close Form to Tray Assignment
    11. Click OK to close Properties window
    12. Open Word document called “tabs.doc”
    13. Go to File menu and select “Print…”, and change the current printer to Canon
    iR C3200 PS3.
    14. Click on Properties
    15. Click on Paper Source tab.
    16. Select Paper Type option
    17. Choose Tab Paper from Paper Type list. As soon as you select “Tab Paper”,
    Conflict Information dialog will appear. Click on OK.
    Page 3
    Hint:
    In order to change the tab position, click on Tab Position button. Clicking this button opens a
    dialog box for specifying the width for shifting the image data to be printed on the tab part of
    the paper.
    Hint:
    The conflict information displayed pertains to the finishing of the document. Tab paper must
    be grouped, not collated. Since the default value for finishing is Collate, the driver
    automatically adjusted the finishing option to resolve the conflict.
    18. Click on OK to close the Properties window.
    19. Click on OK to print the tab paper.
    20. Go retrieve your output.
    Note:
    Please note that this procedure for printing on tab paper is not the same for all drivers. CCD
    drivers would be similar to this procedure, but depending on the OS Platform, exact buttons
    and steps would vary. However, from such drivers as imagePASS-C1 PS and Macintosh drivers
    would work completely different from this procedure. Although we will not cover each
    procedure step by step, we encourage you to take time to make yourself familiar with the
    procedures.
    Sep 30, 2008 | Canon imageRUNNER C3200 Color Printer
    42 people viewed this question
    old marine
    old marine
