Question about HP Officejet 9110 All-In-One InkJet Printer
Paperfeed error paper stall
got a 9110 and when i print or copy it takes the paper from tray 1 and stops and errors up paper stall, cant stop it.
please help.
gary
Hi , I have a hp 9110 and wa getting the same problem paper stall . There is a sensor located on top right hand of the feeding ,these rollers located when you open the cover undeneth the carriage. Switch off the printer and put a few drops of rubbing alcohol on the sensor wait a couple minutes for it to dry. Then power up and test.
Posted on May 13, 2009
    President:
  • 4,402 Answers
Try new feed rollers
Posted on Apr 24, 2008
I use a CM2320nf MFP connected to Windows XP. The unit seems to be defaulted to print 2 pages - and for double sided copies, it stops after 2 pages, then the Cleaning window pops up, then I get an error...
Problem 1 :
As far as the machine printing 2 pages per job. To fix this it's usually the default number of copies the printer is set to. To change/ confirm the setting is set to one:
Press the menu button
Arrow down to -> Printing, Press the green check to enter the menu
Arrow down to -> Copies Press the green check to enter the menu
Change or confirm the value = 1, (Based on your question this might be set to 2) Press the green save the value.
* If your number of copies is set to 1 and the machine is still printing 2 copies, then the problem relays in your print driver.
Problem 2: General Misprint Error message something like 41.3
2 things to check:
1st - Press the menu button
Arrow down to Paper Handling, Press the green check to enter the menu
Now you will see options like Tray 1 size - Tray 1 type. Here their will be a option for each tray installed on your machine. You will go into each tray option and confirm the paper size and type.
Example
Tray 1 Size = Envelope #10 (This is the manual feed tray)
Tray 1 Type = Envelope
Tray 2 Size = Letter
Tray 2 Type = Plain
To perform arrow down to tray X size press the green check to access the menu, arrow up or down to select your paper size. Once the paper size is selected press the green check to save it. repeat for each tray.
2nd -
Pull out your tray and remove the paper, towards back of the tray you will see a guide (Tab) in the middle of the tray which allows you to expand the tray to accept various paper sizes, Please confirm the guide is set to the correct type. If your using letter, make sure the guide is set to letter (LTR) you can see these codes by looking at the base of the guide, their is a little arrow pointer.
Hope this helps
Jan 14, 2011 | HP LaserJet 2420 Printer
Service call error 125 Pulls paper to print then jams and stops Also multipurpose tray won't go into the down position.
125: Error
Error detected in MT home position.
1) is an Error Message displayed? Yes
Turn ON power again.
2)Does the Error take place again? yes
Replace MT
Oct 27, 2010 | Xante Ilumina Digital Color Press Printer
Prints one page double sided, then goes to error light and stops printing
what is the error ?
does it says Paper jam, Open the print cover and remove paper jam..
If this the error repeating then make sure,
1. u r not overfilling the paper tray
2. put the printer on a hard surface (not on a half out surface)
3. from now on be gentle with the paper tray.
4. unplug the printer everytime u r done or atleast overnight.
thanks
Jul 30, 2010 | HP LaserJet 1320 Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
HP COLOR LASREJET 3500 41.3 ERROR
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
RK2-0247-000CN
chris
May 27, 2009 | HP Color LaserJet 3500 Printer
913 service motor error
If this is the first time you have seen this error, do the following:
  1. Power off the printer.
  2. Remove all installed paper trays.
  3. Make sure the paper is loaded correctly in each tray. If it is not, reload the paper into that tray.
  4. Look up into the printer where the paper tray slides in and out. Check the feed (autocompensator) assembly for any damage.
  5. If everything is fine, reinstall the tray and power on the printer.
  6. Try printing a few print jobs.
  7. If the error does not return, continue using the printer as before. Keep an eye on it for the next few days. If the error does not return, it may have been an isolated incident.
  8. If the error returns just as soon as you power on the printer or when you try to print again, you will need to find out which paper tray/paper source is causing the problem.
  • If the printer has only the one integrated paper tray, the problem will be with either the tray 1 pick arm/autocompensator assembly or the printer's engine/system board.
  • If the printer has more than one paper tray installed, try printing from each paper tray one at a time. The best way to do this is to have all of the paper trays empty and then proceed as follows:
    1. Put paper in tray 1 only.
    2. Print from tray 1.
    3. If tray 1 works fine, empty tray 1 and put paper in tray 2 and so on until you encounter the error message.
    4. If you receive the error when printing from one particular tray, power off the printer to clear the error.
    5. Power the printer back on.
    6. Skip the faulty paper feed slot and move on to the next one (if another one is present). If you can print from all but one of the paper trays, this is the source of the problem.
      If you have extra paper trays/drawer units installed and the error occurs from only one particular source, there are some things you can do as a temporary fix.
      • If the error is occurring from an OPTIONAL paper drawer/source, power off the printer and remove the defective drawer from the printer. You will then need to set up the printer to print from a different tray. For information on removing an optional drawer, click here.
      • If the error is occurring from the integrated paper tray (tray 1) AND you have optional paper trays installed, take all of the paper out of tray 1 but leave tray 1 installed. Set up the printer to print from one of the other paper tray sources (tray 2, tray 3, multi-purpose feeder, etc.).
    7. And if your getting the same error then you need to get it serviced...
Sep 09, 2008 | Lexmark Optra SC 1275 Laser Printer
Error code 6000 is showing on the lcd screen
I had the same problem and went searching - all the feedback suggested that something may be stuck of blocking the paper path. Took the tray out, checked underneath etc - and yes - the problem was a couple of sheets of paper stuck inside. Was able to retrieve these by accessing them from the rear of the printer - and when plugged back in it started up ok!
I believe the cause here was that a print job was sent to the printer while it was also being used to copy stuff - though i cant be sure of this. Either way, it was a blockage that cased the problem.
All the best - JB
Apr 29, 2008 | Office Equipment & Supplies
Konica 7155 Main Error Code : 74 ,printer stops for no reason
There are a few code 74's, and Konica has a bulletins on them.
DESCRIPTION: Code 74-0 from the E-mail alert system. SOLUTION ID: 154045
SOLUTION: CAUSE: Paper remains at finisher main tray paper exit opening.
DESCRIPTION: Code 74-1 from the E-mail alert system. SOLUTION ID: 154055
SOLUTION: CAUSE: Booklet tray is full.
SOLUTION: Remove the paper from bottom exit of the finisher.
DESCRIPTION: Code 74-4 from the E-mail alert system. SOLUTION ID: 154058
SOLUTION: CAUSE: Paper remains inside finisher.
SOLUTION: Please remove copies from the finisher.
DESCRIPTION: Code 74-5 from the E-mail alert system. SOLUTION ID: 154059
SOLUTION: CAUSE: Punch trash box is full.
SOLUTION: Trash basket of punching unit is full. Please empty trash basket.
DESCRIPTION: Code 74-6 from the E-mail alert system. SOLUTION ID: 154066
SOLUTION: CAUSE: Sub-tray (first tray) is full.
SOLUTION: Sub tray is full. Please remove paper.
I'm guessing it just means the finisher thinks it's full, and wants you to take the copies / prints out.
Apr 23, 2008 | Office Equipment & Supplies
Lexmark E232 - Tray-1 Paper Problem
Have the same problem after 1,500 pages! This was Lexmark's solution (and it worked)...
Take the paperfeed tray out and you will see a red lever , press it
downwards and you will see the paperfeed rollers coming down , you need to
pull the rubber tyres off those rollers and place them inside out over
them and then try printing any document. Check the paper weight and
the paper type you need to use 20 pounds regular paper and try runnning a
can of compressed air inside the machine.
If rubber tyres on the paper feed rollers are totally worned out you
need to replace the feed rollers.
Oct 31, 2007 | Lexmark E232 Laser Printer
HP Officejet 9110 All-In-One InkJet Printer Logo
245 people viewed this question
Ben Johnson
