Question about Jenn-Air JSD2789GES Side by Side Refrigerator
My JSD2789DES(10yo) fridge slowly begins to not keep the fridge as cold over about a 6 week period then I have to unplug it for 2 days. I seem to be getting a lot of water leaking on the freezer side door down on to the floor. After that it is usually good for a while.I had a repai guy look at it and he said it was the compressor, if that were the case I would think it would not work at all. Any help would be appreciated. C.J. Merlo
  • 2,272 Answers
You are right.If the compressor is faulty then unit will not work.But as you mentioned that after you unplug it for 2 days then reconnect it.The unit leaks water .This problem is all related to defrost problem.In your unit the defrost is not working properly. To check where the problem is check the few possibilities:-- In the frezzer section do you hear a fan running? if not then that fan is the problem.If fan is running properly then check on the back panel off the frezzer do you see frost. If there is frost then there is ventilation problem in the unit that is is not letting the unit to defrost.if there is no frost then the air dampener between freezer/refrigerator needs to be checked. if you are sure that the that evaporator fan motor is running and that there is no frost on the back panel and you remove the frezzer back panel and the evaporator is not a big block of ice then you are going to need a damper control this is the part in the fresh food section usually in the back right top that lets the cold air from the frezzer into the fresh food. The frezzer cools the fresh food the fan pulls cold air across the evaporator and pushes it into the fresh food through the damper it is either got moisture on it and can not open or the motor is bad and it just not opening.The back panel inside the frezzer two screws should hold it on maybe four.It has to be removed from in the freezer not from back of the freezer unit. But if there is frost build up in the inner side of the freezer panel then the problem is of defrost control board and it has to be replaced. Its called "adc" adaptive defrost control board. You can get required board parts from www.repairclinic.com or from www.partsselect.com Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jul 30, 2010
  • cjm3217 Jul 30, 2010
    Well I think you nailed it.The fan works fine so I pulled off the inside cover(2 screws, 2 pieces) and it was 80% blocked full of ice.I looked last night for a part number on the two websites provided but no luck. Is the ADC a generic part for all Maytag/Jenn Air fridges, or do I need one specific to my serial number? Also, where is this ADC located and can I do it myself?? I really appreciate your help. I hope this is the fix. I really like my fridge and it is hard to find one of that CF today. Thanks again.
Mini fridge doesn't get cold anymore
Is the unit running? If so then,
by shutting the unit down for a long period may have exposed a pinhole leak of refrigerant at an external brazing point. or you may have caused an issue in cleaning it This is something that would require a licensed technician to resolve.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 15, 2017 | Emerson Refrigerators
I have an amana bottom freezer fridge. 3 years ago ,y freezer was frosting inside and the fridge temp was not getting cold enought. a repaiman replaced the thermostat. now the freezer is beginning to...
To fix up a frosted up vents, I had a control board replaced for $180. Then 6 months later, the bottom freezer frost up AGAIN. rather than dumping more money to fix it, I was about to buy a new fridge, but had a crazy idea: I disconnected the water to the freezer, bought plastic trays for ice cubes for $3 at walmart. Fridge has worked like a charm for 6 months. no signs of frost. Saved $1000's.
Dec 12, 2011 | Amana ABB1927DE Bottom Freezer...
Electronics stuck. Unplugged and it seems to have
It will only work for a few more months. You'll have to reset it a few more times. Eventually, even keeping it unplugged for a couple of days won't work. Have had ours 7 years -- and have had more than a dozen service calls on it. In the beginning, all was covered. No longer. Piece of **** is going out to the sidewalk on junk day. Will never buy another whirlpool or maytag product again.
Our crappy whirlpool fridge freezes stuff in the back of the refrigerator, while stuff comes out of the freezer a bit soft.
Awful products. Even worse customer service.
Oct 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Fridge slowly gets warmer and stops working
You have one of 3 parts not working.
1.The defrost timer.
2.The defrost element.
3.The defrost themostat.
Jan 11, 2009 | GE Refrigerators
Not cooling or cold
The REFRIGERATOR WAS MOVED TO ANOTHER SITE. AND IT HAS NOT GOTTEN COLD SINCE MOVE, PLUB UP 2 DAYS AGO. iT WAS UNPLUG AND CLEAN 2 DAYS BEFORE MOVE. COULD IT NEED ANTI-FREEZE?
Aug 25, 2008 | Whirlpool ET1FHTXM Top Freezer...
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
Refridgerator isn't keeping cold
its in the freezer when you open yhe door the compressor is in the back take the cover off and see if trhe compressor is running
Apr 03, 2008 | Refrigerators
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
139 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
