Question about Dell OptiPlex GX620 PC Desktop
I can't get into windows of my Dell Optiplex GX620. I try but the computer gives the following message: <>
  • 2,229 Answers
You most likely have a hardware issue. Very possibly memory.
You'll need to troubleshoot that by disconnecting everything in the case but the video, CPU, and memory and see if it starts OK.
Then hook up the hard drive and see if you can boot into Windows. If you can't, unplug one of the memory sticks and try it. Then the other memory stick and try.
If you have a Windows startup (installation disk), boot from that and opt for system repair. You will want to get to the command prompt and run chkdsk.
See my tip here:
http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
Posted on Jul 30, 2010
Testimonial: "I am not a computer technician so I am unable to do what you suggest. Any idea whee I could get help?"
STOP: c000021a {Fatal System Error} 0xc0000034 0x00000000 0x00000000 HELP?!
This is not an easy one to deal with if you don't have some things like a boot disk. The error is most likely caused by something that was installed or restored wrong. The best windows option is to use F8 and select last known good config. Then if it starts you can uninstall any software that you added just before this error..IF you cannot do that then you need to be able to boot to a separated disk and use file utilities to remove any programs that might be causing this.
Jul 20, 2015 | Dell Inspiron Mini 10 Notebook
Tip
This article is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact Technical Support.
When you use a server or a workstation that is running one of the operating systems that is listed in the "Applies to" section, you may receive the following error message: STOP: c000021a {Fatal System Error}
The Windows Logon Process system process terminated unexpectedly with a status of 0xc0000034 (0x00000000 0x0000000)
The system has been shutdown. Note The parameters in parentheses are specific to your computer configuration and may be different for each occurrence.
CAUSE:
The STOP 0xC000021A error occurs when either Winlogon.exe or Csrss.exe fails. When the Windows NT kernel detects that either of these processes has stopped, it stops the system and raises the STOP 0xC000021A error. This error may have several causes. Among them are the following:
  • Mismatched system files have been installed.
  • A Service Pack installation has failed.
  • A backup program that is used to restore a hard disk did not correctly restore files that may have been in use.
  • An incompatible third-party program has been installed.
Resolution will not fit here so kindly go to:
http://support.microsoft.com/default.aspx?scid=kb;en-us;156669
I hope it helped you. Rate for this information will greatly be appreciated. Thank you!
on Jan 20, 2011 | Computers & Internet
Blue screen error STOP: c000021a {Fatal System Error} The windows logon process System process terminated unexpectedly with status of 0x0000005 ( 0x00000000 0x00000000). The system has been shut down.
It appears that your Windows Registry is corrupted. You can try to use a Registry repair utility like CCleane to fix it. If that doesn't work you will have to reload Windows OS (Operating System). For more info no this error code Google "c000021a".
Feb 07, 2011 | Dell Computers & Internet
I have a dell desktop running Wondows XP 2000.
There are lots of possibilities like faulty ram or may be virus in the system or may be the windows file is corrupt try to repair the windows installation. or take the backup of system and the format the system
Jan 21, 2010 | HP Pavilion a1610n PC Desktop
Stop: c000021a {fatal system error}
start in safe mode with command propmpt and type chkdsk /r/f and let the system get scan.
Jan 20, 2010 | Dell Inspiron Notebook
My pc`s screen is blue and it sais stop:c000021a ,is there? anything I can do to fix it
hello there
here is some information that should be able to explain this error and how to fix it ok?
best regards michael
  1. How to troubleshoot a "STOP 0xC000021A" error ... presents advanced troubleshooting steps for the STOP 0xC000021A error. ... STOP: c000021a {Fatal ... Note Most STOP 0xC000021A errors occur because Winlogon. ...support.microsoft.com/kb/156669
  2. "STOP: c000021a (Fatal System Error)" Error! RE: "STOP: c000021a (Fatal System Error)" Error! Ya, thats what I thought I might have to do ... RE: "STOP: c000021a (Fatal System Error)" Error! just input the ...www.msghelp.net/showthread.php?tid=66202 - 52k - Cached
  3. How I fixed my Windows XP Stop c000021a {Fatal System Error} with ... How I fixed my Windows XP Stop c000021a {Fatal System Error} with Knoppix Linux. 2008 March 14 ... Message: Stop c000021a {Fatal System Error} The Session ...healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-f... - 53k - Cached
Sep 16, 2009 | Microsoft Windows XP Professional With...
Stop: C000021a (fatal system error).The session manager initialization system process terminated unexpectedly with a status of 0xc000003a (0x00000000, 0x00000000)
Most places will tell you you're boned, but there is the option of using a live cd, such as Knoppix. The following website has a little bit of background on the problem, and how he fixed it.
http://healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-fatal-system-error-with-knoppix/
Hopefully that helps.
May 04, 2008 | Edimax EW-7117U Wireless Adapter
Dell OptiPlex GX620 PC Desktop Logo
231 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
