When tv is turned on no sound or picture. checked the cable connection and that is working fine. we checked the electrical outlet and that is fine also so we have power to the tv set.
    Problem Solver:
  • 11 Answers
This is only based on upon the information you provided; i would say your main board needs to be replaced.
Posted on Jul 29, 2010
My tv is not working right with picture.
Press the TV button on the remote, make sure the TV is plugged in, check the electrical outlet to make sure it is live if the TV does not turn on. If these actions do not solve the problem, press the Power button on the front of the TV. If the TV turns on, replace the batteries in the remote control and reset it by pressing the number 1 button for 60 seconds. If necessary, reprogram the remote.
Unplug the TV for two minutes, then plug it back in if the buttons on the remote don't work. Make sure the remote is in TV mode.
Change the settings on the sleep timer if the TV turns off unexpectedly. Unplug the TV and wait five minutes before plugging it back in if necessary.
Check your antenna connections and cables if the sound is okay but the picture is poor. If all the connections are good, adjust the sharpness function.
Jul 21, 2011 | RCA 20F512T 20" TV
My Panasonic TV/DVD/VCR Combination has a dull buzz sound on all channels. How can I stop that Dull Buzz? Model number PV-DM2719. LBV
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc.
Jan 17, 2011 | Panasonic Televison & Video
No sound output need sound unit
Jan 14, 2011 | Mintek DTV-233 23 in. TV/DVD Combo
How can i exit from service menu code,picture is blinking and there is no sound.Service menu is appearing when set is power on. set is 14''philips vardaan . please shortout my problem.
Jan 13, 2011 | Philips 20DV6942 20 in. TV/DVD Combo
Frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Dec 09, 2008 | LG 37LC7D 37 in. LCD HDTV
Television has sound but no picture
Check the cables first that connect to your video device, are they in tightly?  Test the cables on another TV to make sure they haven't gone bad, which is common.  Also check the input selection on the TV to make sure it matches with the video input the cable is connected to.
Dec 06, 2008 | Philips 50PFP5332D 50 in. Plasma...
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
20pf5120
Are you connecting the tv to your source using the DVI, component (Red Green Blue + 2), or composite (Red, Yellow, White)?
Try switching the type of connection you are using. If you are connected via component, then switch to composite. If the problem persists even on composite connectors, then the issue lies with the TV. If the composite cable works fine, then the problem is most likely the cable you are using.
Press the sleep button, and make sure the sleep timer is set to OFF.
Unplugging the TV from the wall outlet resets the TV.
If you have a cable or satellite box connected to the TV, then try resetting the box also by turning off/unplugging from wall outlet.
Surge protectors can cause some occasional anomalies with LCD TV's (they're still a good idea) - just reset the TV to clear up these anomalies.
-Tha Mp3 Doctor
Feb 04, 2008 | Philips 20PF5120/01 20 in. EDTV-Ready LCD...
Tv has no picture
sounds like a antenna block problem or a tuner?? Now Im wondering if this set has mutiple antenna inputs?? if it does then the antenna input switch is on the wrong mode.
Apr 06, 2006 | Sanyo DS31520 31" TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
