I have quite a lot of experience building PCs. Have just installed Asus P5E3 MoBo Core2 Duo E8400 CPU 2MB OCZ DDR3-1333 memory. It will not power up properly. All fans spin up briefly and HDD LCD flashes once, then it goes down again. This then repeats every 5 seconds ad-infinitum. Same symptoms in a different case/power supply/HDDs/graphics card, even with memory removed. Cannot even get into BIOS. Any ideas - MoBo, CPU? Pete how
  • 1 more comment
  • zelazny Apr 24, 2008
    This is all brand new kit, and I see the E8400 CPU has been supported since Jan.2008, so thought the BIOS may be OK. Various forum posts suggest that the BIOS should run and report any unsupported CPU - but not in my case. I will investigate whether any Asus BIOS Utility I have will work, but do wonder whether I can get anything to run at all. I have downloaded the latest BIOS 0904, which comes with their AFUDOS utility, and see what happens.
  • zelazny Apr 25, 2008
    My gut feeling was for a MoBo fault. I logged a call with Asus Support, and they asked me to start with just the CPU and power up and listen for the bleeps, then add memory and then graphics card. Initially however, just clearing the CMOS solved the powering up/down cycle - all fans and disks spun up fully and the front power LED came on, but NO display.With CPU alone, I got the bleeps for no memory. After adding just the memory there were no bleeps to indicate the lack of graphics card. Adding two different graphics cards did not get anything on the display. I have relayed this back to Asus suggesting the MoBo still has a problem.
    Thanks to ALL who have made suggestions - very helpful! I'll keep this open until Asus reply again.
  • zelazny Apr 28, 2008
    Asus confirm that it is likely to be a MoBo fault, and it is being returned for replacement. Thanks to all contributers.
    Genius:
  • 1,447 Answers
If your computer does not display such a prompt, consult your owner's manual or contact the manufacturer for instructions. Your computer manufacturer may have selected a different keystroke sequence; the following sequences are commonly used:
Ctrl+Alt+S
Ctrl+Alt+Esc
Ctrl+Alt+Ins
Note: If you press the keys too early, the BIOS may display an error message.
Posted on Apr 24, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 24, 2008
    You will need to consider these issues:
    Voltage --The CPU voltage is selected with motherboard jumpers.
    Clock
    Rate -- the clock rate written on a CPU refers to the maximum rate
    recommended by the CPU manufacturer. The CPU does not necessarily run
    at that rate. A CPU will run slower than its maximum rating if the
    motherboard's clock input frequency is too slow. Some CPUs can protect
    themselves from too high a voltage or too fast a clock rate by slowing
    down. Others cannot do this and may burn up after too long an exposure,
    even if there is active CPU cooling element, such as a fan. Motherboard
    jumpers specify the clock rate that is fed into the CPU.
    Note on P
    Rating -- some CPU manufacturers rate their products with a P rating. A
    P200 rating does not necessarily indicate that the CPU is running at
    200 MHz; it is only a measurement of expected throughput compared to
    other CPUs. Contact the CPU manufacturer for an explanation of this
    feature.
    CPU Socket -- not all CPUs use the same size and shape socket.
    BIOS
    Support -- your BIOS may not support the type and speed of the new CPU.
    If you cannot get confirmation (and upgrade instructions) from the
    motherboard manufacturer about the CPU upgrade, then it is not
    advisable to change the CPU. Because BIOS is customized for individual
    systems, only your manufacturer can tell you for certain whether the
    CPU you are considering is supported or not, and if it has been tested.
  • 563 Answers
Hi zelazny
First try the Asus support , I would personally think it would be the Motherboard if the PC doesn't even want to start up in another box - like you mentioned. Highly unlikely the CPU !
  • 19,396 Answers
It is overheating or faulty cpu, check that the fan is well in contact with cpu, try a replacement fan
  • 1 more comment
  • Ginko
    Ginko Apr 24, 2008
    Always test MB with a minimal set of devices connected. RAM, PSU, CPU and FAN, and only power on switch connected. See if it starts. Ensure the fan you are using is enough for your CPU.
  • Ginko
    Ginko Apr 24, 2008
    Once you exclude all other causes, (see above) remains only fauty MB or CPU
  • Ginko
    Ginko Apr 24, 2008
    Ensure also that you are connecting PSU properly, New psu have more than one connector (CPU power) refer to MB manual for PSU connection
  • 13,433 Answers
I would recommend you get your hands to a 4digit post card
http://www.pc-diagnostics.com/pc_diagnostics_tools/flippost_isa_pci_bus.shtml
Cpu, memory or motherboard
There are also cheaper 2digit models available not so accurate but they work too.
    Genius:
  • 3,587 Answers
That's the issue..BIOS access...you may need to flash the BIOS...adding all those components, can make the system 'loop' causing that cycling issue...you have a BIOS configuration utility?
  • Patrick Michaels
    Patrick Michaels Apr 24, 2008
    One other thing..make certain that your housekeeping voltage monitoring chips are configured correctly...I never assume anything on mobo's out of the box anymore..
  • Patrick Michaels
    Nods and winks to see Ekse and Ginko up and about mid day, eh fellas?
Want to upgrade my HP TouchSmart IQ504 Desktop PC 2.0GHz processor for a 3.1 ghz ?
First, have you ever changed/upgraded a CPU? It take quite a bit of research to upgrage. If you look at this spec of the Mobo your options are very limited, The Mobo only supports 2 different type Processors, 1, Core 2 Duo (Merom); http://ark.intel.com/products/codename/2683/Merom , 2 Core 2 Duo (Penryn): http://en.wikipedia.org/wiki/Penryn_(microprocessor) If you have a 64bit OS consider a memory upgrade, if you haven't already. More info : http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01481519&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3752240#N298
Dec 20, 2012 | HP ALL-IN-ONE HP TouchSmart IQ504 PC -...
Will an asus p5gd1-fm motherboard support an intel e8400 core 2 duo 3.00ghz cpu?
No, that motherboard is 915P socket, and the E8400 is Socket LGA775, you will need a new motherboard to use that CPU.
May 07, 2011 | ASUS P5GD1 Motherboard
I have a gateway 831gm. it has an Intel (Augsburg) 915G Motherboard and a Pentium 4 630 cpu 800MHz fsb & 2MB L2 cache. i've been looking for a cpu upgrade and saw that the Pentium E5200 Dual Core has...
If both motherboards are LGA775 socket, then the next concern is whether or not the case is capable of having the new motherboard installed into it. Disconnect all power cables to all dv drives or cd drives and hard drives. Disconnect all ribbons from drives to the mother board. If you can get to all of the screws that hold the motherboard into the case, you get away without removing drives. Once you've got the motherboard then you can disconnect the power cable from the motherboard. Remove the memory chips, disconnect the sound cable from the old motherboard. install the memory chips onto the new mobo, Connect the power cable to the new mobo, then install the new mobo into the case. Replace the ribbons from the drives to the mobo, replace the power cables to the drives and reinstall the sound cable to the cd or dv drive. You should be done now.
Dec 13, 2009 | Gateway 831GM PC Desktop
I have a ASUS Asus P5E3 Deluxe Motherboard. i installed and used for about a month and it took a **** on me. i turn it on and the MoBo turns on, but doesnt give me anything on the screen. MoBo isnt in...
i have same problem i have a ASUS P5E3 Deluxe Motherboard but everything was new but when i on allthe light is runing good but no beeps on my bord or signal on my screan?
Sep 24, 2009 | ASUS P5E3 Deluxe Motherboard - Intel X38,...
Asus P5KC motherboard problem ???
Does your system give off any kind of beep or beeps before its shuts down? from what it sounds like, you might have a short some where , a bad mobo or bad cpu. Try using another cpu on the mobo and see what it does.
Jun 25, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Can i use nvidia 8600 video card for my mother board asus p5pe-vm and processor intel core 2 duo to my motherboard
this are the CPU -s that you're mb can support (core 2 duo)the numbers after "All" are the bios version's you need for the cpu: Core 2 Duo E4300 (1.8GHz,800FSB,L2:2MB,65W,rev.L2) ALL 1201 Core 2 Duo E4400 (2.0GHz,800FSB,L2:2MB,65W,rev.L2) ALL 1202 Core 2 Duo E4500 (2.2GHz,800FSB,L2:2MB,65W,rev.M0) ALL 1406 Core 2 Duo E4600 (2.4GHz,800FSB,L2:2MB,65W,rev.M0) ALL 1406 Core 2 Duo E4700 (2.6GHz,800FSB,L2:2MB,revG0) ALL 1501 Core 2 Duo E6300 (1.86GHz,1066FSB,L2:2MB,rev.B2) ALL 0604 Core 2 Duo E6300 (1.86GHz,1066FSB,L2:2MB,rev.L2) ALL 1201 Core 2 Duo E6320 (1.86GHz,1066FSB,B2:4MB,rev.B2) ALL 1402 Core 2 Duo E6400 (2.13GHz,1066FSB,L2:2MB,rev.B2) ALL 0604 Core 2 Duo E6400 (2.13GHz,1066FSB,L2:2MB,rev.L2) ALL 1201 Core 2 Duo E6420 (2.13GHz,1066FSB,L2:4MB,rev.B2) ALL 1402 Core 2 Duo E6600 (2.40GHz,1066FSB,L2:4MB,rev.B2) ALL 0604 Core 2 Duo E6700 (2.66GHz,1066FSB,L2:4MB,rev.B2) ALL 0604 Core 2 Extreme X6800(2.93GHz,1066FSB,L2:4MB,revB2) ALL 0604 and for the graphic card ...no because you motherboard has the "AGP" interface and the nvidia 8600 has "PCI - express" interface as is described here: http://www.nvidia.com/object/geforce_8600_8500_tech_specs.html
Jun 14, 2009 | ASUS P5PE-VM Motherboard
ASUS P5VD2-VM SE support for intel core 2 Duo E8400
Doesn't boot correctly?
If the CPU isn't supported, in my experience, the pc doesn't boot at all. If this is the case, you will have to buy a new MB to support your CPU. Sorry.
Jan 07, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
NO video @ bootup
Are you sure that the memory you have installed is compatible with your motherboard.
It is weired but some memory do not work with certain motherboards, irespective of speed or voltage rating.
Aug 05, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Why won't my computer boot?
phill-29
To solve this problem at first clear CMOS by removeing CMOS battery then replace ur CPU.
if it not solve ur problem then check ur bios verson 1002 or not if it 0940 then update ur bios. u can download this update file from this link: http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5E3
Jul 03, 2008 | Computers & Internet
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
