Question about SimpleTech (sti-u2f36/250) 250 GB Hard Drive
I have a simpletech, about 100 gig. 96300 40001 001 91000 40479 813 m052 335 It is not backing up for 1-1/2; cant open a file on backup. Is it compresed. Want t Window delayed write fails. Can see files but cant open a document. George@GeorgeKeen.com 937-387-8909
    President:
  • 3,278 Answers
Hello, George.
I'd suggest to connect your SimpleTech drive to another computer to see if your USB ports are problematic. It's unlikely, though.
Unfortunately, the Delayed Write Failure error usually means that your drive is unusable.
Hope this helps.
Posted on Jul 30, 2010
Have connected a SimpleTech drive to MAC via USB and windows backup files are shown. I would like to recover Pic files out of the backup and place them on my MAC. Is there any easy way to do this?
You might have to restore the backup files from on your Windows machine, then drop/drag photos to a new folder. Windows and Mac's use different filing systems, so Mac's are unable to read the Windows backup file format.
Feb 23, 2018 | SimpleTech Computers & Internet
Changed hard drive (Mac) How to restore data from SimpleTech
If you are asking how to restore a Time Machine backup, you will need to connect and turn on your drive, then open Time Machine, navigate to the drive, highlite the backup and click on the restore button. It should then restore the files from your backup.
Feb 24, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
How to use it on my new computer
The whole point of having a "backup" disk-drive is to create one additional copy of all your files. So, if the "internal" disk-drive fails, you still have the files, on the "external" drive, and vice-versa.
Open "My Computer".
Connect the SimpleTech to a USB port.
Watch "My Computer" -- it should update after Windows detects the new hardware.
Open "My Documents".
Click "Edit".
Click "Select All".
Right-mouse click on one of the files.
Point at "Send To".
Point at the "new" drive-letter that Windows assigned to the drive,
and all the selected files will be copied to the SimpleTech.
Oct 31, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
I backed up my entire computer on my SimpleTech Pinin Farina external hard drive and now I can't figure out how to find a file on it that I need. I see all the backup files, but I can't figure out how to...
Backup software compresses the files and encodes them to an image file made up of a series of sequenced files. The same software you used to do the backup should have the restore options needed to locate desired files. SimpleTech website shows Fabrik to be the name of the backup software.
If you utilized, there's also an online backup site used to store files. Following link is the users guide:
http://www.simpletech.com/support/guides/user-guides/60000-00168-001.pdf
Oct 22, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
I have SimpleTech drive that I used Storage Sync to back up C drive. Took drive to work and since all the files are 'bpa' cannot open them. I compare this to a simulation of what I bought the drive for -...
The BPA files are the backed up copies of your data. The simpletech utility backs up your files to compresse file ending in BPA. Any computer running the simpletech restore program can extract the data from these files.
You will simply need to install this software on a spare computer in order to test the backups. Frankly though I would just use windows backup to copy the files/folders you want to the drive raw as this can be read anywhere.
Hope this helps FixYa,
Chris
Sep 23, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Hangs on large installations or data transfer
THat means that there is something wrong with the drive already. I can transfer up to 100 Gig of a single file to large USB drives so generally transferring is not a problem. Try formatting the drive then transfer again. Or your USB port on your computer is only a USB 1.1 and not USB 2.0
Feb 07, 2009 | SimpleTech 320GB SimpleDrive External by...
Simpletech 500 gig usb plug in hard drive
Is the drive running when connecto to power ans PC?
Try it on another PC.
Check the power supply if it is operated from an external power supply.
It it is self powered via the USB then this is a possible problem- the PC power supply cannot cope - Removing other USB devices may help here
Feb 13, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 320 GB
my advice to you is open it and unplug the one touch button.
Jan 11, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SIMPLETECH 320GB
One thing to remember is the some of the Simple drives requires the USB mini to conect to the drive and the TWO USB connects to be plugin to the computer.
Jan 07, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Restoring backup files
well first off you should not use teh same external hard drive for both dell and mac! and for it to work on a dell you need to go to disc utility in the applications folder and click on you external hard drive and go to the last pannel which is called restore and put in the given info and it shall work!
Jan 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech (sti-u2f36/250) 250 GB Hard Drive Logo
67 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Ricky Ostrom
Ricky Ostrom
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
