Question about Delta ShopMaster 8in Grinder with Light GR350
To sharpen tools
At what angle do I position lets say a shovel to shapen?
Thanks Paul
  • 2,100 Answers
The angle things on the grinder are usually set up for drill bits and never moved again. If you need to sharpen your shovel, I would get a 4 1/2 grinder with 80 grit disc in there and grind away from the edge, Not into it, it cuts 10 times faster, cleaner, straighter, than the grinder, use fit or the lawn mower blades too, and the machete, use the grinder for your drill bits and other precision type stuff, don't let the wheels get rounded off or uneven, use a wheel dresser if they do. I have a couple grinders set up in my shop, one wheel for finer stuff, then a wire wheel, then a green wheel for carbide, and then another wire wheel. I use a 1 inch belt for knives and finer stuff, and a 10 disc for serious stuff along with the 48 inch belt. So you can see, I use them a lot. But if you need to use the grinder for your shovel, I would not use the angle stops, I would do it freehand and you can only cut the outside edge, and it will be hard to get it around there. You might have to take the angle stops off. Hope this helps.
Posted on Jul 30, 2010
Chain saw sharpening angle
For cross cutting is 30 degrees and if you only do ripping it is 10 degrees.
Apr 22, 2015 | Poulan 16" 38cc Gas Chain Saw P3816
What is the edge angle when sharpening a knife?
This is the angle between the blade and the stone.
Jan 24, 2013 | Kitchen Appliances - Others
How to sharpen the blades on my Swiss army knife?
You can sharpen your Swiss Army Knife is using a circular motion. Start by holding the blade away from you at the proper angle. Run the blade of your Swiss Army Knife in a clockwise motion on the stone until you have sharpened that side of the blade. Turn the blade over and repeat with a counter clockwise motion.
Jul 09, 2012 | Camping, Backpacking & Hiking
Looking for sharping stone from efco fl64 /8 chain
There are multiple chain sizes 1/8", 3/16", 1/4", 5/32", 7/32" and 3/8" chains so the /8 chain number has me guessing. After the qurestions below, here is my best guess.
Also is this for a chain grinder?" or
Are you looking of a hand held type stone?
Aluminum Oxide Chainsaw Sharpening Grinding Stone
or Ceramic stone?
I will assume that your looking for aluminum oxide stones at this time.
http://www.oregonchain.com/homeowner/products/accessories/replacement_stones.htm
This is wide selection of sharpening stones.
You can also use hand held chain sharpening files of the same size that have shapening angles marked on the file set fixture.
Hopefully you have a sharpening guide that will keep your angles correct while shapening.
A safety note: Improperly sharpened chainsaw blades can be very dangerous to the user.
Thanks for using FixYa.
Kelly
Mar 10, 2010 | Oregon Scientific Garden
Ineed to sharpen my wood chipper blades on my
It takes me about 5 minutes to Remove, Sharpen, and Re-install my chipper blade for my Bolens mc2500. First, If your using a screen or rollers in the discharge, then remove them. Look underneath, and you will see the thick flywheel. Make sure the spark pug wire is disconnected, then slowly turn the flywheel by hand until you see the two hex head bolts that hold the chipper blade to the flywheel. Also remember which way you take it off, so it goes back together the same way. using an open end or combination wrench remove the two hex bolts. Now to sharpen, I use a medium/ coarse honing tool made for lawnmower blades. I clamp the blade to the top edge of my Bolens with a pair of visegrips, then a little oil, and the sharpening tool, and I'm done sharpening in about 2 minutes, and then re-installing, reversing the removel process. I hope this helps.
Apr 29, 2009 | Garden
Black&decker ccs818 chainsaw
Each type of chain may be a little different but for the most part it's about 45 degrees for the teeth that have a square outside to topside angle and 35 to 40 for the rounded outside to topside teeth.
Apr 12, 2009 | Black & Decker CCS818 Chain Saw
Blunt Clipper blade
www.sheareaseltd.com £5.90 incl VAT & Postage for sharpening.
Apr 04, 2009 | Sunbeam SBCL 802 Hair Trimmer
Drill doctor won't sharpen bit
Proper using of drill doctor can help to sharpen your drill bit. You have little idea on drill bit structure then only the drill doctor user manual is enough to learn how the drill doctor drill bit sharpener works and you will become a DIY drill guy, no doubt. Best Drill Bit Sharpener Here How This Is Thousand Bucks Worth Tools Freak
Jan 02, 2009 | Dynamic Drill Doctor Large Chuck, Black,...
Electric sharpener for chainsaw
what type of chain are you trying to sharpen.need size,pitch and gauge of chain......
Dec 23, 2008 | Garden
Which dremel bit do i use for sharpening some scissors and how?
any fine grinding stone will work the main thing to remember is to make sure you maintain the correct angle of the blade
Dec 04, 2008 | Dremel 700 03 Super Accessory 185 Piece...
Delta ShopMaster 8in Grinder with Light GR350 Logo
125 people viewed this question
Top Delta Grinders Experts
Marvin
Marvin
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Delta Grinder Expert? Answer questions, earn points and help others
