Question about HP Color LaserJet 2600n Printer
Faded edges on a HP2600n
Printin starts to fade off the closer you get to the vertical edges. Black cart is lo if that has anything to do with it. Others read as half full.
    Scholar:
  • 79 Answers
Im not sure if this would make it worse since I don't personally own this printer but try taking out the cartridge and shaking it a little. This may spread the power ink more evenly. Be careful because i've seen on some printer that even if you move the cartridge a little bit more then your supposed to power ink spills out of the cartridge and is not a good thing to breathe in.
Hope this helps!
Posted on May 01, 2008
EPSON XP400 SCANNED IMAGE FADED B&W OR COLOR
try to reinstall drivers or try to scan connected to other pc, if problem remains, scanner is done
Feb 02, 2015 | Epson Office Equipment & Supplies
Why do I have white / faded print when printing black? It also has problems printing straight lines - sometimes jagged sometimes just faded.
I do not know for sure but it sounds like the paper is not griped properly, this would cause the jagged lines. I would try another ink cart when the loose paper problem is resolved. I hope this helps.
Jul 23, 2014 | United Stationers HP Officejet Pro 8600dn...
Faded screen
Hi Isobel,
Not much information there...
iMacs tend to start displaying vertical lines, lie white faded strips as they age.. unfortunately, it's like iMac Alzheimers.. nothing to be done under $600
May 09, 2013 | Apple iMac Computers & Internet
Starts off faded
If you do several test pages it should eventually clear up. If you get new Dell cartridges this will likely go away immediately. Dell carts have a tendency to "sludge up" if the printer remains idle too long, so print something every other day. Also, don't use refilled Dell carts, they may be good at first, but they are old and usually never last long as they should.
Apr 25, 2010 | Dell A920 InkJet Printer
All toner cart's replaced, new toner heads about 1000 pages ago, new waste tray. Printing colors ok but anything with black in it comes out blotchy or faded.
(1) If it takes developer as well as toner you will need to change the black developer.
(2) Also check the voltage is correct
(3) check that the toner path is not blocked
lets know how you get on
Feb 23, 2010 | Minolta magicolor 7300 Laser Printer
Problem with inkjet indicator
sometimes the ink level report does not reflect the true picture. what you should do is see whether it is printing faded or not printing blank. If printin normal you really shouldn't worry. If it were not printing I would suggest you returned it but that is not the case.
Oct 27, 2009 | Lexmark X6575 All-In-One InkJet Printer
Faded on left hand side
If it only happens with the black then you need to change out the black toner cartridge. The good news is isn't doesn't happen with color so it more than likely not the printer but the toner.
Jan 09, 2009 | Samsung CLP 300 Laser Printer
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
HP Color LaserJet 2600n Printer Logo
110 people viewed this question
Ben Johnson
