Question about Whirlpool Refrigerators
Water in consate pan is not evaporating fast enough, ran over ruin lamiate flooring, new motor and also coils are clean
  • 4,793 Answers
A high humidity area will also cause this to happen...fit a drain plug and water your houseplants with the condensate.
Posted on Jul 30, 2010
Ice forming on bottom of freezer compartment under freezer baskets...then finding water on the floor. Frequency is once every few days...Fridge is a Kichenaid KFIS27CXMS5
The unit defrosts itself and the water runs down a tube into the drip pan under the base. There is a coil (condenser) that gets warm and helps to evaporate the water in the pan. These things get very dusty and gross. Remove the front kick panel and clean the drip pan, check the drain hose for obstruction all the way to the evaporator coil in the freezer and make sure the unit is level.
Mar 12, 2018 | Refrigerators
Drip pan full
Check if the drip pan is fixed to the motor or if it's using the evaporator element make sure it is warm enough to evaporate the water.
Jul 26, 2013 | KitchenAid KSRP25FNSS Side by Side...
Water leaking in the inside of home.
Air conditioners take the moisture out of the air. When the air passes through the coils on the evaporator, they are cold. This causes the air to condense and water to form on the coils. It then drips off into a pan. When the pan is full if it is not drained, you will have an overflow and things get wet. How much water the unit collects depends on how much humidity is in the air, how much air you are moving through the coils and the temp of the coils.
Jul 22, 2013 | Royal Sovereign White 1200 BTU/12,500...
Maytag mbf2258xeq leaks but it's not connected to a water line. Where's the water coming from?
water is coming from condensation from the compressor coil. usually this will evaporate fast enough to not puddle on the floor. check the plastic line running down the back of the fridge to see that it's not broken or pulled out. while you have the fridge out, clean the coil by blowing it out with compressed air and clean the pan under the compressor as best you can. Hope this helps
Nov 30, 2011 | Maytag MBF2258XEW
Water is leaking down the back of the refrigerator ruining food on the back of the shelves. have seen some dripping in the freezer at the back wall in the middle. the refrigerator is 6 yrs. old
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Apr 19, 2011 | Whirlpool Refrigerators
Freezer not cold.
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
Hope this will help in solving the problem.....
Oct 07, 2010 | Frigidaire Refrigerators
Collected water in evaporator pan does not
you obviously live in a high humidity area.(or you are putting warm/uncovered food inside) but the answer is yes,or you could collect the water to use on you indoor plants.........better than tap water...
Jul 08, 2010 | Frigidaire FRT18KB2CW Top Freezer...
Hotpoint 18.2 cu ft refrigerator -water pooling on the floor
Was it the tubeing that drains the defrost water that you cleaned. Did you clean it at the top where it would be stopped up with ice. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If not
Aug 15, 2009 | Refrigerators
Nor-Lake walk-in cooler water leak
The evaporator drains into pan with a coil from the discharge line. The design is intented to sub-cool the liquid refrigertant as well as evaporate the condensation from the coil. Unfortunately the engineer started as career a shipping clerk and never received any further training.  There isn't enough heat or running time to evaporate the condensation from the coil.
The solution is fairly simple
A plastic tube  drains water out of the evaporator in the pan. You can extend the tube and add a defrost pan handled by your refrigeration wholesaler. Wire it so it is on whenever there is power to the unit.  This should get rid of the excess water. These pans are also used on some self contained coolers and freezers. They come in either 120 volts or 220 volts. kasgirls@tds.net
Jul 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerators Logo
53 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
