Can I connect my wireless microphne receiver to a multi chanel receiver?
    Prodigy:
    An expert who has answered 500 questions.
  • 611 Answers
You would typically need a mixer between a wireless microphone receiver and a home hi-fi receiver. The Shure SCM262 will work well.
Posted on Aug 27, 2010
The center chanel port does not produce sound and sparks when i plug the wires into the jack. all other chanels work except the center.
It seems that the center channel has DC voltage at the output terminals, center channel amplifier is blown and you need to bring the receiver into a repair shop. You can use a voltmeter to check DC at speaker terminals, all channels should have 0 volts when no input signal applied (or volume control set to minimum).
Do not connect your speaker you can damage it.
Jan 09, 2011 | Audio Players & Recorders
I need to know how to pair my phone to my c.d player
Turn the bluetooth on in ur phone.
Use MULTI-CONTROL to select
Connection open in the function menu.
Press MULTI-CONTROL to open the connection.
Always waiting is displayed. This unit is now
on standby for connection from Bluetooth
device(ur phone).
If your Bluetooth is set ready for
Bluetooth wireless connection, connection to
this unit will be automatically established.
Jul 04, 2010 | Pioneer DEH-P7900BT CD Player
I have an Edimax 802.11/n wireless adapter installed on a desktop. We moved and the new location barely picks up the signal from my Linksys access point. In my previous house, it did okay, although it was...
check your edimax setting for the adapter if teh wireless signal is the same as the routers chanel the edimax defaul channel is always set to chanel 1 for the signal of its wireless and if your router has a different channel most probably channel 11 or 6 which is the most likely chanel that many use
May 22, 2010 | Computers & Internet
Have wireless G plus MIMO router and lapto using a
Please enter to the router page and decrese the chanel. make it to 6 or 11
May 01, 2010 | Belkin (F5D6230-3) Wireless Router
No image at menu 'digital'
you connected the converter to AV1 that is the ONLY place you will recieve any signal leave the tv in av1 and run setup on the converter ONLY you should be all set
Nov 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My wireless doesnt broadcast. im using a dlink dsl 2740b router
Under your wirless tab. Make sure Enable AP is ticked. You have named your SSID, usually the same name as your workgroup network.
In windows your workgroup is called WORKGROUP.
Chanel is set from 1 to 13
Security is set to WEP
Authentication Type is set to OPEN
Encryption key password is set to a 10 hexadecimal code.
ie: abcde12345 ( choose something you will remember)
On the device you are recieving make sure you have the same password, SSID, Same chanel as router and is set to WEP. If they are not the same then the units will not connect.
This should resolve your connection. When you first connect have the two units close to each other and reset the router. Then reset your other device. If it does not connect chect the antenna is screwed in firmly but not too tight to the router.
If it still fails then change your chanel up or down on both devices. Does not matter what channel you choose just as long as they are both the same.
Oct 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
Cant get all of my channels
I LOST MY BOOK HOW DO I PROGRAM MY RECEIVER
Feb 18, 2009 | Motorola DCP-501 Receiver
I cant get my laptop to connect wirelessly to my router
if you click on the properties of the wireless that u are using and go to configure you will be able to set the chanel that you will need like my belkin is chanel 6 or 11 and my region is 49-165 the device is set to default when it is installed i had to learn this on my own but now it is pretty easy to do hope this helps you a little bit ok best regards mike
Aug 24, 2008 | Computers & Internet
 Grubhead
Grubhead
