Question about Akai LCT2715 27 in. LCD Television
Help!!!!! tv will not turn on, will not start, blinking red light, popping noises. i took it to the shop and they said something about a power module. it cost 290.00 for it too be repaired. IS IT WORTH GETTING REPAIRED BY THE SHOP?
  • 30 Answers
I can repair these boards with quality parts and I do not just replace the failed parts I replace the parts that caused the failure if needed. Cost is approx $100 +s/h
Posted on Jun 25, 2008
Jaime867 would u be willing to do the same for me?
Posted on May 19, 2008
  • 2,323 Answers
That is a bit expensive.
I would fix that module for you for about $110.00 with shipping and handling both ways.
The only thing you'll do is to remove the power supply module and send it in for repair.
Posted on Apr 24, 2008
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
Was watching TV, heard a pop and the screeen went black. Now when I turn it on, the pwoer light blinks green but their is no picture or audio. The light then starts blinking red
Is is standby light blinking red or any other light? Let me know how many times red standby light blinking after three seconds long pause to provide you helpful info.
It seems pop sound was due to broken lamp, please check lamp inside tv and if it is broken, replace it to solve tv problem.
Hope this will help.
Thanks.
Mar 09, 2011 | Sony KDS-50A2020 Television
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
TV will not turn on Yellow power ind. Light blinks three times tried to reset no luck took to repair shop diagnosed with bad SEIN module internet post suggest bypassing Sein module but I don't know where...
Toshiba Regza 37in - 37HL17
TV will not turn on Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
cc46e8cd-c98d-439a-bc78-207613c68534.png 76bab8a5-e5dc-4d5d-9d56-589661460254.png
Jan 13, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Did my tv just blow up?
Yes, I think you have lost the bulb and maybe the color wheel is on the way out too. But try a bulb first. If the old one has a broken "glass tube" in the center--be assured it is bad.
Oct 10, 2009 | Samsung Televison & Video
Power light flashing all 3 colors TV will not turn back on
Sounds like the Power supply module. I would take it in to service center ASAP!
May 21, 2009 | LG 32LC7D Television
Panasonic PT-53TW53G 1 Blinking red light, will not stay on.
just got back today for same problem. convergence went out. took to repair shop. $200 part plus $60 labor. second time in a year convergence went out. was told it will happen again.
Mar 19, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Akai LCT2715 27 in. LCD Television Logo
87 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
