Question about Acer Aspire 5330-2339 Notebook
Three symptoms with Acer 5330-2339-hope they are all the same problem. Touch pad will navigate, but when I press the left button nothing happens. Mouse works, but keypad doesn't. Page up & page down no work. Screen occasionally comes on white. Please help-it's really bugging me..........
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
This is a hardware problem which will require repair by an engineer, contact your manufacturer or a PC store for assistance.
Posted on Jul 30, 2010
I HAVE BLOCKED MY CURSOR ON ACER LAPTOP BY MISTAKE
When your mouse pad is not functioning, it's hard to get most anything done on your computer. The fortunate side to all this is that getting a mouse pad to work again on a laptop is not an overly complex procedure. A few troubleshooting techniques will quickly lead you on your way to productivity again.
Examine your mouse pad. Dirt and grime can affect performance and slow down mouse sensitivity, if not shut it down altogether. Make sure the surface of the track pad is clean and that there is nothing that has managed to get beneath it or around any trackball buttons that could affect the pressing and depressing of the component. Check to see if your mouse pad has been turned off. If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad. To enable your mouse pad on a Windows PC go to the Control Menu. Under the Printers and Other Hardware option, click on Mouse. Then, click on the tab on the top of the pop-up menu that says Device Settings. The touch pad for your computer should come up as a selectable option. Click on it and you will see the option to enable your device, then click OK. If this does not work, proceed to the next Step . Check the manufacturer of your laptop (for example, Toshiba) and then navigate to their official website. Find an area for Software and Drivers, and move on to that area. Enter your laptop number (check your documentation/manuals and/or the bottom of the computer) and look through the drivers that are presented as a result of this number input. It could be that your mouse pad simply needs updated drivers. Find the driver that corresponds to your computer and mouse pad (for example, most Acer laptops use a Synaptics touch pad). Then, click on download. Once the drivers have downloaded, double click them to ensure they install, restart your laptop, and your mouse pad should be working again. Hope this helps.
Jan 08, 2013 | Acer Computers & Internet
Unlock cursor for acer laptop
Your laptop comes with a touch pad that acts as a mouse. Instead of connecting a mouse each time you want to use your laptop, you can use the touch pad that is integrated underneath the keyboard. This comes in handy when you are in a tight spot such as in a classroom or on an airplane. At times, you may need to unlock the laptop touch pad because someone who borrowed your laptop disabled it. It may also be locked due to a slight malfunction that you can easily fix by enabling the touch pad in your computer settings.
Click the Windows "Start" button in the bottom-left corner of your desktop. Scroll up and click "Control Panel." Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner. Click the "Enter" button and then click the "Mouse" link. Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have. If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button. If you are under the touch pad tab, click the enable button. Click the "Apply" button and then click the "OK" button. Hope this helps.
Dec 08, 2012 | Acer Computers & Internet
How to open unlock mouse pad
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
Hi I recently got myself a Acer Emachines Em350 nav51 but the touchpad/trackpad will not work. I have tried using fn+F7 to active it but nothing happens. Tried diffent drivers as well with no...
Maybe go to the device manager in control panel and click on Device Manager look for the HID Compliant mouse or touch pad and un-install the driver completely after that restart your computer as soon as it boots up it will find new hardware and take you through the setup process most computers does this for you after it says installation complete try the touch pad if nothing happens try pressing the Fn keeping it down press the F7 button then release them both if still nothing happens then it will be your motherboard as it will required going back to them under their warranty to be fixed.
Jun 27, 2011 | E-Machines emachines (emachinees) CD-ROM...
How do I do the right click function of a normal mouse on the pad mouse of an acer aspire 4741g laptop which does not have a right click button. I have tried to press and hold the Ctrl key and press the...
On your laptop, directly beneath the touch pad are two oblong buttons. They act as mouse buttons. The left one selects and the right one gives extra options.
Hope that helps.
Feb 03, 2011 | Computers & Internet
My touch pad wont work
By the power button, there is another button on the left side of the power, if it is amber color you may have accidentally pressed it and locked your mouse and touch pad. Press it once again and try your pad. Let me know if this works!! Ive done the same thing, many times and couldn't figure it out!
Oct 15, 2010 | Acer Aspire 4520-5582 Notebook
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
My Acer emachine E627 the touchpad doesn`t work. what do?
Mine stopped working too, and it turns out to be that button to the left of the power button that disabled it. Check that...if the
light is on the mouse pad is lock... Hope it helps!
Jan 22, 2010 | Acer eMachines 520-2890 Notebook
Acer Aspire 5315 Touch pad problem
go to the control panel, mouse configuration , and try to turn on the touch pad
Aug 30, 2009 | Acer Aspire 5315 Notebook
ACER ASPIRE 3690
That's happened to mine today, I had to lift the left plastic square and just tap the spare metal bit to select things, I think you can buy replacement parts, but a friend of mine thinks you have to buy the whole touchpad.
Aug 20, 2008 | Acer Aspire 3690-2196 Notebook
Acer Aspire 5330-2339 Notebook Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
