VAIO VGNTZ150N Laptop battery runs down when not in use
I have a laptop laptop that is about 6 months old. The battery runs down about 10% per day when the computer is off. I can charge it up completely and when i turn it back on 4-5 days later the battery is down to 50% or so. It does not run down if i remove the battery from the computer, the battery holds its charge when not installed in the computer. The life of the battery seems to be about 4-5 hours when fully charged and the laptop is in use on battery only so i think the laptop is using up the battery even when off. Is this normal?
thanks
    Scholar:
  • 61 Answers
If the laptop is gone into a suspended mode it is still powered on but sleeping. This will continue to use power and will power down the battery over time.
You could enable hibernation which saves the current state of your pc so that when you activate it again it restores to your previous state of work. This will use close to no battery power to perform.
Posted on Apr 24, 2008
HOW TO UPGRADE RAM ON VAIO VPCM121AX LAPTOP
Memory Upgrade for Sony VAIO VPCM121AX Netbook Laptop, the Sony VAIO VPCM121AX Netbook Laptop takes the PC2-6400 DDR2 SDRAM SODIMM 200pin memory Memory Type, and comes installed with 1GB (Removable) of Memory.
You can upgrade your Sony VAIO VPCM121AX Netbook Laptop to up to a maximum of 2GB Memory, the system has 1 Socket to install Memory, already with 1GB (Removable) standard Memory installed.
For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
Power off the computer, and unplug it from the power source. Close the computer and turn it over.
Slide off the battery cover and remove the battery.
Locate the memory bay and remove the screws in the cover.
Remove your old RAM board(s) by pushing the metal clips and holding it down and outwards until the RAM board pops up. Then pull it out at a 30-degree angle. (If you only need to add more RAM to your existing RAM and you have enough available empty RAM slots, you will not need to remove the RAM.)
5
Insert the new RAM board into an empty slot at a 30-degree angle until you hear it click. Then push it flat down into the slot.
6
Replace the cover and screw it back in.
Upgrade the Sony VAIO Hard Drive
7
Locate the hard drive bay and remove the screws from the cover. Then slide the cover off.
8
Pull the hard drive out of the bay.
9
Remove the screw securing the hard drive with the magnetic screwdriver.
10
Pull the hard drive out of the bay by the black tab connected to it.
11
Re-insert your new hard drive into the bay and replace the cover.
hope it helps
Jul 15, 2012 | HP Pavilion dv7 Keyboard (483275-001)
My laptop Sony Vaio CS 320J is shutting down with out any notice(not proper shut down but poweroff while running) and not booting again for @ least 2 mins. recently this issue started and this is...
Remove the bottom pan to expose the cooling fan, clean all dirt out of the heat sink and fins,and clean fan, next remove the heat sink to expose the processor ic, remove the old thermal grease with rubbing alcohol, and apply fresh thermal conductive compound to the heat sink and processor, "not to much! just enough to cover the critical areas and assemble. In most cases this will solve the shutdown problem.
Apr 15, 2011 | Sony VAIO VGN-CS320J Notebook
On starting my Sony Vaio laptop, I am getting the message: Battery may not be compatible or is not inserted properly.Click OK to hibernate and reinsert the battery. On doing this, it works fine for 2...
This is because you didn't install the Sony Share Library or Sony Firmware Extension Parser.
As a work around you can disable the pop up with the following steps:
1) Click on Start
2) Click on Run
3) Type "MSCONFIG"
4) Press Enter
5) Click on the Startup tab
6) Scroll down and locate ISButility
6) uncheck it
7) Restart the PC
Sep 25, 2017 | Sony VAIO VGN-SZ260P/C PC Notebook
Sony vaio power up issue
hi
u carry out your laptop battery and then restart and if you find still problem, and want technician help contact http://tinyurl.com/msfzw7
Jun 20, 2009 | Sony VAIO VGN-NR160ET Notebook
Laptop Battery Wont Hold Charge
change original battery. check dc jack charger.
Jun 02, 2009 | Sony VAIO Notebook
Bought 6 months ago and will not boot up, with battrey out it will attempt to start for a couple of secs and then nothing
After 8 days of no life at all in the laptop , having 2 computer technicians around saying it was probably the motherboard and just about to send to Sony I pressed the power button and hey presto it worked again..Guess it was just sleeping or hibernating...after all it is spring now....Actually one guy of the many forums I have visited advised just to leave the Laptop alone and perhaps it would mend itself..and hey presto he was right, although having said that I have yet to turn the laptop off and startup again..HMMMMMMM...
Apr 14, 2009 | Sony VAIO VGN-FS630/W Notebook
What is the Sony Vaio VGN-N250N battery life expectancy.
nope..that's just what happens with batteries that are older, tired, and dried out..
Mar 11, 2008 | Sony VAIO VGN-N250N/B Notebook
Laptop fails to start
bad mobo do u ever use it on your bed overheating died kiled power chips on mobo best to get new one mobo or sell on ebay its 1 yr warenty call maker
Jan 24, 2008 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
200 people viewed this question
David Payne
David Payne
