Question about GE APN10AA Portable Air Conditioner
Compressor does not come on. Error code E4 - GE APN10AA Portable Air Conditioner
  • 2,133 Answers
E-4. Short of gas or no gas /Abnormality of out door unit.Due to no gas oil would have pumped from compressor.
Find leak and arrest it. And then vacuum and gas charging.
Posted on Jan 04, 2011
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4. I press the program button, i select the washing program i want, but on the display the error code "E4" is being blinking. How do I fix it please?
The E4 Dishwasher Error. According to the manufacturer the E4 error will be given if the vent for overflow when water level exceeds the set level overflow water triggers the lower float, terminates operation and gives E4 warning.
Clean the level sensors.
May 15, 2016 | Dishwashers
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
Hw do i remove error code E4
E4: Indicates lack of refrigerant, or the compressor is not running, or the thermistor is out of
calibration.
Action: Check that the compressor is running by listening.
If it is apparent that the compressor is running, then check the
temperature difference across the evaporator.
i.e. Measure temperature of return air at inlet filters and
measure temp. of discharge air at grilles. This temp diff.
should be 14 to 18 C. with fan on hi speed. If temp diff. is less than this,
suspect lack of refrigerant.
Fit a suction gauge to access valve at rear of unit. See fig 12. On a 35C
outside temp. then suction should be 380 to 450Kpa.
Good luck
Feb 14, 2015 | Heating & Cooling
E4 error code beautyrest electric blanket
beauty rest electric blanket error code - akaQA
www.akaqa.com > Uncategorized
beauty rest electric blanket error code. What does error code E4 mean? Answer this. 0 Views: 2487 Answers: 1 Posted: 3 years ago. Comment this question.
E4 error code beautyrest electric blanket - Fixya
www.fixya.com/support/t22178587-e4_error_code_beautyrest_electric
Dec 13, 2013 - E4 error code beautyrest electric blanket One side works the other returns an "E4" error code - Simmons Beautyrest Microfleece question.
Dec 13, 2013 | Simmons Beautyrest Microfleece Electric...
Error code e4 unit airconditioner
Not sure about E4 , but 4 blinks or flashes usually means the compressor isn't starting properly. It could be a faulty start capacitor or wiring or faulty indoor PCB (Board)
Oct 18, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
What causes e4 in an airconditioner
Read your instruction manual section troubleshooting for to see the error code.
if you do not have go to www.fitness.manualsonline.com or www. retrevo.com or www. manualsfactory.com
God bless you
May 09, 2012 | Heating & Cooling
Dometic rooftop air conditioner with a e4 error code
Possible fault in the compressor not taking up. Please check the main capacitor to the motor for failure.
Remove plug and reset .
Sep 13, 2010 | Heating & Cooling
I get a E4 errror code.
The broken water tank flipper will directly cause the unit to not function and the E-4 message will appear on the display screen.
Jul 15, 2010 | Soleus LX-140 Portable Air Conditioner
E4 Error
york hvac unit e4 error code Troubleshooting
Aug 05, 2008 | DeLonghi CF210 Portable Air Conditioner
Danby DWC283BLS Wine Cooler - Error message E3 & E4
Is the compressor running? I don't know this unit, but know that if you are too warm that is the first thing to check. In reading about another unit that had a different problem, it was mentioned that there is a ciruit board. If it has relays on it then these are the most likely culprit. They are either not making contact or staying in contact too long... sometimes just tapping each relay usually a black plastic component will cause it to work intermittently..Not sure if you can get these but call the company help line at 1-800-263-2629.
Jun 12, 2007 | Danby DWC283BLS Wine Cooler
GE APN10AA Portable Air Conditioner Logo
140 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
