Question about Western Digital Caviar WD400BB 40 GB Hard Drive
I would like to add this hdd to my system as a second drive ....what are the pin settings needed?
  • Western Digital Master
  • 27,725 Answers
Hard drive pin settins are usually printed on the top or the back of most hard drives you Press either f2 or delete during the boot process to enter computer BIOS you can change the drive settings in there
be very careful
Posted on Jul 30, 2010
Cannot see second drive.
I am sure your missing jumper setting.
so you should change hdd jumper setting.
how to change u r hdd jumper just visit this site.
http://itexpertinbd.blogspot.com/2012/11/hard-disk-problems-jumper-settings.html
Nov 11, 2012 | Computers & Internet
NEED JUMPER SETTINGS FOR MASTER HARD DRIVE
Set The Jumper Setting On Your Hard Disk Drive
The hard disk drive will be detected as 32 GB if the jumper is set to the 32 GB clip pin setting. The common jumper settings for Samsung hard disk drives are listed below. Please check the label on your hard disk drive for the correct jumper setting.
Important: Use the alternate jumper setting listed below under General Pin Setting. After changing the jumper, partition and format your hard disk drive.
Configuring your Hard Disk Drive (Master, Slave, or Cable Select) - Setting the Jumper
If this is the only HDD in your computer, set the pin setting to Master.
If this is the second HDD in your computer, set the pin setting to Slave.
If this is the second HDD in your computer, and the first drive is set to Cable Select, set the pin setting to Cable Select.
If you are replacing the HDD in your computer, set the jumper setting to match that of the drive you are replacing.
Cable Select:
This setting is the default setting for PATA/IDE hard disk drives. With the Cable Select jumper setting, the BIOS determines whether a hard disk drive is Set as Master or Set as Slave by it's position on the UDMA cable.
If the hard disk drive jumper is set to Cable Select and is connected to the black connector on the end of the UDMA cable, it is recognized as Set as Master for that PATA controller.
If the hard disk drive jumper is set to Cable Select and is connected to the grey connector on the middle of the UDMA cable, it is recognized as Set as Slave for that PATA controller.
Note: When using Cable Select, your system must meet the following conditions:
Your systems host controller must support Cable Select.
Your hard drives must support Cable Select.
Your cable must support Cable Select.
Set as Master:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Slave, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
Use this setting if you are installing an additional hard disk drive to a single UDMA cable and the Cable Select setting is not recognized.
Set as Slave:
Use this setting if you are installing an additional hard disk drive to a single UDMA cable with a hard disk drive Set as Master, jumper one hard disk drive to Set as Master, and the other to Set as Slave.
32 GB Clip Pin Setting:
Use this on computers manufactured before November 1998 when either you start up your computer and see the message, "Hard disk drive controller failure", or your system stops responding during the boot process after installing a new drive. This occurs when the hard disk drive is too large for the BIOS to support.
If after performing the troubleshooting procedure listed above, the full capacity of your hard disk drive is not recognized, click here for information about obtaining a system BIOS update. If you are unable to update your BIOS, another option would be to create a second partition with the remaining unallocated disk space.
Aug 18, 2012 | Computers & Internet
I need to know the jumper setting for my hard drive to set it to a slave
Here is the jumper settings for Samsung hard drives. Assuming that your hard drive is bigger than 32GB you have to use the "General Pin Setting"
Note that after changing the jumper, it's suggested to partition and format your hard disk drive.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 04, 2011 | Samsung Computers & Internet
How can i make my Samsung sp0802 hard drive become the master instead of the slave... thank you very much
Hi Good day!!! follow this
1. Decide which hard drive will be the startup (master) drive. If this drive was the startup drive previously, or if it's a new hard drive, then the master drive designation will already be set.
2. To change the designation of a new drive to be a slave drive, skip to step 4.
3. To change the designation of an existing drive to be a slave drive: Turn off the computer, unplug the power cord, remove the drive from its drive bay, and disconnect the drive from its power cord and ribbon cable.
4. Check the hard drive documentation or the label on the drive itself for master/slave jumper settings.
5. Find the jumpers on the circuit board of the drive. Jumpers are plastic plugs with metal sleeves that form a circuit between a pair of pins. Jumper locations are labeled on the board with a J followed by a number (such as J20).
6. Use tweezers or very small pliers to remove or reposition the jumpers to the configuration shown in the documentation or on the disk label.
7. Install (or reinstall) the hard drive in the computer. (See "How to Install a Second Hard Drive.")
Don't forget to vote thanks!!!
Nov 02, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Failed to unlock HDD System Locked
What you need to do is unplug pc, open up the door panel to your pc and remomo cell battery from mother board then find the jump pins on the mother board they look just like the one in back of the hard drive. The jump pins are connected with a jumper similar to the pins jumper that sets up your hard drive to master, cable select, or slave. You need to reset the mother board the way you do that is by removing that pin jumper and replacing the cell baterry then the pin jumper. If done correctly you will reset your motherboard password setting and bios allowing you to boot your operating system. If you need help google your pc manufacture and model number and search mother board jump pins. Or email me with your pc info to andreioneluv@yahoo.com , and I will try to help you find it. Please rate if this was helpful...
Jun 08, 2010 | Seagate (9W2892-337) 80 GB Hard Drive
Not deteck hdd & cdrom
Power down you're system and remove the power cable from the PS.
Open you're case. First clear the cmos jumper. See bottom of page 14 in manual. The GA-8VM533M-RZ motherboard was made Jan-1-2004. It is very likely that the cmos battery needs to be replaced. Average life span is 5 years or less. Pull the cmos battery and check its voltage with a voltmeter, it should read no less than 2.7volts DC.
I'm guessing it’s the bios that’s not seeing the CD-ROM drive and the hdd? Suggest you check both the data cables and their power cables.
Since the GA-8VM533M-RZ motherboard only supports ATA IDE hdd's, check the drives jumper. (It should be jumpered as a Master) and so should the jumper on the back of the cd-rom drive. See the link provided; http://www.easeus.com/resource/install-ide-hard-drive.htm
The link above helps but you're hdd may be different. See the sticker on
you're hdd for the correct jumper setting.
If you are using a single data cable to connect both cd-rom and hdd to the motherboard don't. Use an 80-pin data cable for the hard disk drive. You can use a 40-pin data cable for the cd-rom but if you have a spare
80-pin data cable connect the cd-rom drive to it.
Connect the hdd to IDE1 and connect the cd-rom to IDE2. See motherboard layout in the manual page 5. Need the manual? Download it from Gigabyte; http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1766
To view the manual you will need to download and install Adobe reader;
http://www.adobe.com/products/reader/
Re-connect the power cable to the PS. You can leave the case opened for now. Power on the system and press the Delete key every 2 seconds until the bios menu opens. (Make sure the time and date are set current). See page 19. Than turn to page 23. Make the settings as follows;
First Boot Device [Floppy] - (if one is connected)
Second Boot Device [CD-ROM
Third Boot device [HHD-0]
Password Check [Not needed]
CPU Hyper-Threading [Enabled]
Check all settings while in the bios, save and exit. The system will auto re-boot. If after replacing the bios battery (If needed), and the bios still
does not see either drive than the problem is either the bios or the motherboard's controller. The bios can be flashed but the MB controller can not be repaired.
Cheers'
Mike
Feb 15, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
How to set master, slave settings in sata hdd
In first HDD put the jumper in first vertical pair of pins from power socket side, it will become master and second HDD put jumper in second vertical pair of pins from power socket side it will become slave.
Regards
Ashly
Feb 02, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Pin connection for 'master ..slave
I assume these are IDE drives since SATA doesn't require jumper settings. . .You will need to set the primary drive jumper to master[ma] & the secondary drive jumper to slave[sl]. Some systems require dual hdd systems to have both set to the cable select[cs] jumper. Check your motherboard or system manufacturer manual to see which setup your system requires. If you lost the manual most manufacturers have it availablr on their website under the support link. Hope this helps.
May 23, 2009 | Excelstor Technology J880 Hard Drive
Have maxtor 40gb hd want to add 2nd WD hd in DEll dim8200
(if both drives on the same cable):
Your boot drive goes at the end of the primary data cable.
Your second drive goes on the middle connection of the same cable.
The red stripe on the data cable needs to be closest to the power connection (red stripe to pin 1).
The jumper on the boot drive set to master.
The jumper on the second drive set to slave.
Look in the BIOS to make sure it sees both harddrives.
Boot the system.. it will need to be partitioned and formatted if not already..
Regards..
Apr 04, 2009 | Dell Dimension PC Desktop
ASUS K8V-MX Motherboard with 250GB SATA HDD and 250GB IDE HDD Problem
Hi LP,
I’ am very familiar with ASUS motherboards. I am thinking you have posted two questions or more referring to the,
ASUS K8V-MX board. When you sign into you're FixYa account you than need to click on you're profile. Within you're profiles are the questions you have posted. Click that question to add or see the expert's answer. If you need another question (about the same item) re-post within that same question. You can even copy the link to an older post & past that link into you're next question. (Than I can read you're last question & my responce).
LP you have me all mixed up. I'll answer the question you have posted above. In the future please provide you're old post so I understand better.
There is nothing wrong with IDE 250GB drive or the SATA drive.
The problem you are haveing is setting the correct settings.
The ASUS K8V-MX can support two serial ATA SATA drives. The SATA drive's can only run at 1.0 version. 1.5GB transfer speed & not SATA II, the 3.0GB speed.
How to setup the SATA drive?
Please disconnect any other drives (IDE) & a second SATA drive that may be connected to the system. Except the CDROM drive.
Using you're manual the SATA drive should be connected to SATA1 port. Page 1-24 in you're manual.
Put you're windows CD into you're CD-ROM drive & boot the PC. You will see, Press any key to boot from CD... (press any key on your keyboard). Windows will start to install. Durring installation of windows the system will restart. You will again see, Press any key to boot from CD... (DO Nothing)!
Just allow windows to conintue on its own. Windows will continue to install it's self. This will happed once again, & again do nothing. Windows will finish installing it's self.
After windows has finished, load the ASUS CD into you're CD-ROM drive & install it's driver software. Restart the PC.
You must register windows. Do so.
Than update windows through windows update service. (This will take some time to complete). (Do not install service pack 3).
If you have an IDE drive 250GB in size & you installed windows on it. You must erase the drive or it will conflict with you're new installation on the SATA drive. To do this, look on the IDE drive & you will find a large white sticker. Printed on there is instructions of how to set the drive pin. Set the drive up as a slave drive. (This is only temporary).
Power off the PC & unplug the power cord. Connect the 250 IDE drive's power cable & data cable. Plug in the power cord to the PC & turn on the PC. Windows will load. Right click once on the start button & slide up to & left click on Explorer.
Find the 250 IDE drive, it should be drive letter D or E. Right click the proper drive letter & format the drive.
( Do Not format, Local_Drive C:\ ). Once the format is complete, power down the PC by clicking on the start button & click turn off the computer. Once off, unplug the power cord. Change the pin on the 250GB IDE drive to Master with a slave. Take the 40GB drive & change it's pin so the 40GB drive is a slave.
Connect the 250GB drive to the end of the IDE data cable & connect the 40GB drive to the next connector of the same IDE data cable. Re-check all power cables & data cables for good connections before closing the case. Plug the power cord in & power up the PC. Everything should run just fine.
Setting the pin for you're IDE drive's can be very confusing. Click on the link below. This will give you an idea of how to set you're pin for a master drive, master with a slave drive. If you post the name ST****** of you're two drives I can post the correct pin locations from Seagate's web site.
http://www.seagate.com/images/support/en/us/mxo_ata_jumpers.gif
Have more questions about this post?
Mike
May 21, 2008 | ASUS K8V-MX Motherboard
Western Digital Caviar WD400BB 40 GB Hard Drive Logo
126 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
